Will not cool off house but fan outside is blowing
    Novelist:
    Champion:
  • 246 Answers
If the outside fan is running, (assuming the inside fan is too) then you can bet you have a compressor 'not' running. You know the fuses/breaker are good, otherwise, the outside fan wouldn't be running.
If you're lucky you have a wire burnt off the compressor and a honest tech will fix that for you - fairly cheap - probably around $150.
Or, you could do it yourself.
1) shut off all electricity to the unit, i.e. turn the breaker off or pull the fuse block. You'll find the breaker and or fuse block in the little gray electrical box mounted usually on the side of the house, but in any event somewhere close to the outside unit. If you're not sure - just follow the electrical conduit from the outside unit to the gray electrical box.
2) go to the compressor and pull the little plastic cap from where the wires all are. Usually this little plastic cap has a metal snap of some sort holding it in. But once you get the cap off - if you're lucky you'll have a wire burnt off one of the compressor terminals. If that's the case - all you have to do is get a new connection back on the wire and slide it on the vacant terminal.
Note: it's possible to have 'two' wires burnt off - in which case it might be a little more difficult - because then you will have 'two' vacant terminals. At this point it might be wise to get a service tech to help you out - to make sure you get the wires back on correctly.
3) once you have the formerly burnt wire back on the compressor terminal - you just need to be sure the new connection is 'tight.' Remember when it comes to electrical connections - 'make them tight,' otherwise you'll have problems.
4) put the breaker back in the up position or insert the fuse block back in - and turn the AC back on using the inside thermostat.
5) if it's not a burnt (off) wire - then my guess is you're looking at compressor problems and it's time to call a service tech.
good luck!
Posted on May 05, 2010
  • 478 Answers
Check to see if a circut breaker tripped if not the cause then go to the power box on the outside of the house and see if there is a breaker outside or that the pull breaker is making a good contact by pulling it out and pushing it back in a few times (WITH the breaker for the ac in the OFF posistion
4 Suggested Answers
22yooper
  • 828 Answers
SOURCE: outside makes loud noise
I would take a very close look at every solder joint there is between the inside unit and the outside. If you observe oil at any point it indicates a leak at that point. That is an expensive price for what you say was done. Check your invoice for the amount of refrigerant they or he added to the system. Compare it with the amount stated on the outside unit nameplate. Check for frost on the suction (big line) by the outside unit. If there is frost your coil is frozen up. If this is the case turn the fan on and the cooling off. Allow it to run in this manor for about an hour to defrost the A coil. Then return to the cooling mode.
Posted on Jun 16, 2008
shastalaker7
  • 1515 Answers
SOURCE: the a/c unit outside doesnt come on but the fan
Hi, this is a split system Goodman. With the j36 in the model number, that tells me it is a 3 1/2 ton unit. If the outdoor condensing unit is off and doing nothing at all, no fan on top running, no compressor or anything, it sounds as though you have lost power to it. The high voltage to the outdoor unit is seperate from the indoor unit. When it is not running, you have only warm air from the indoor unit. Before I have you do anything, go out to the unit. Take a water hose being careful not to bend the fins on the coil, and wash just the coil very good. If its dirty, it can cause the pressures in the system to rise very high and blow a fuse or trip a breaker. When you are done washing it, you should have a electrical box mounted on the wall that feeds power to this unit. First, find your main breaker box to your home. It should be where the meter is. Find it and it will have several different breakers in it. They may or may not be marked. Look for a double - pole 30 to 40 amp breaker that should say a/c, if it was marked. If not, look and touch them, it will be 2 breakers together and feel if they are tripped. If so, turn it off with a hard motion. Then, back on the same way. Watch to see if it holds and does not trip on you. If its ok, go to the outdoor unit. Make sure the thermostat is on auto/cool and turned way down for it to come on. If it was a breaker and its running, more then likely the dirt from coil caused it to over amp and trip. Now, if there is power and breaker is on but still not on, open the box at the unit. It may have a pull out type plug, or breakers. If it has a breaker, turn it off and on like the other. If it doesn't, behind a plastic panel you will have 2- fuses. Turn off power at main box breaker, and remove both fuses. They are cheap, so go get 2 at a hardware store and replace them. You can have them ohmed out to see if one was bad. After installing the new ones and you turn it on, and all is good, that was your problem. May sure you have power to this outside unit. If it was a blown fuse or tripped breaker and this continues to happen, you may have a internal compressor or condenser fan motor problem. Try the things I have said first. This may be the only problem you have. I do this for a living, 33 years and a licensed contractor. Please keep me posted and I will continue to help you if you need me. Let me know after you check everything.
Sincerely,
Shastalaker7 :)
Posted on Apr 11, 2010
  • 2006 Answers
SOURCE: The central air turns on, but does not cool. The
There should be an electrical box next to your exterior unit. Open it up and there should be a pull handle on an electrical bridge. Usually when it is turned one way it will make an electrical connection and if it is rotated 180 degrees and plugged in it won't make an electrical connection.
Posted on Jun 04, 2011
Testimonial: "Thanks so much! I found the box and turned the pull handle and now our central air is working!Thanks again!"
Not cooling
are you talking about a central a/c system? the fan that blows is the indoor air fan? check breakers for outside unit. one breaker in the house panel box and a breaker at the outside unit. because other wise tha cap or contactor (for the outside unit) may be bad. both of witch may keep unit from turning on. unless you are knowledgeable about electricity I would not recommend opening the outdoor unit. you could get electrocuted. safety first
Oct 11, 2015 | Heating & Cooling
Why is my Weather King A/C Model #10AJA4201 not cooling house? Fan blows warm air. What is problem?
check the outside unit to see if it is running. If its not check the run cap which is the big silver round object. Make sure you are getting 240 volts to the contactor;
Sep 13, 2014 | Weather King Heating & Cooling
Why is my heil Air exchanger fan not blowing
Sounds like you may have a bade blower motor.
Aug 17, 2014 | Heating & Cooling
Unit not cooling inside below 72 degrees lines sweating
how hot is it outside??? 20 degree split is usually the norm ,,,,,outside 95 then inside will be 75,,,,,where is the line sweating ,,, it should sweat near outdoor unit
Jun 02, 2014 | Ruud Central System Air Conditioner
How do I fix my A/C
can be a bad fan motor, defective capacitor or contactor issue. capacitor is cheapest fix if bad.
May 11, 2014 | Bryant Heating & Cooling
2000 NISSAN 4X4 P/U A/C SYSTEM WILL BLOW COLD WHEN OUTSIDE AIR TEMP IS COOL, WHEN HOT OUTSIDE AIR BLOWS HOT.
your auxillary fan is not working. this fan is responsible for cooling the freon that is being circulated in your cooling system... check if there are any loose wires in front of the engine bay.
the auxillary fan is located right beside your radiator fan.
May 17, 2012 | 2000 Nissan Frontier
My air conditioner starts blowing like a fan before my apartment is cooled off, why does it kick off and on like this?
When you first turn it on the fan runs and after a few minutes the outside unit comes on, once the outside unit comes on it take time for it to cool the coils which cool the house, And a/c does not really cool the air,It removes the heat that is in the air.
Aug 04, 2010 | Kenmore Heating & Cooling
Heater not working when on Heat but working when on Fan
is there a venting fan, that may be faulty not sending power to heat
Aug 03, 2009 | Heating & Cooling
AC unit outside turns on but no air blows through the vents
The first problem sounds like the wiring is wrong up at the heating unit not turning on the blower fan in the heater when you call for cooling. Most typical is either something has chewed the wires or the wires have been stripped b something else. The AC not cooling your house can be either it is low on freon or the system is to small for your house. Also check your filter and make sure that it is not blocked and everything is clean with the filter
May 28, 2009 | Heating & Cooling
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
