Question about MPC Computers ClientPro 414 All-In-One PC Desktop
It will not load windows at all. I have tried to start in safe mode and it still will not boot up. I have been told it may be a driver issue. I do not have a restore disc so I can't reinstall anything.
  • MPC Computers Master
  • 11,800 Answers
Borrow from a friend an install disk of the exact same type of Operating System and perform a Repair install.
Posted on May 07, 2010
When I turn on my Dell Latitude D600 PC, the windows xp loading page appears. After it has loaded the screen turns black and does not make any further progress.
It appears that your display works fine until Windows XP loads. Try tapping the key when powering on the laptop. Select boot in safe mode and see if the laptop works.Here's a description of safe mode by Microsoft.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
If your display works in safe mode then you have a video driver issue or virus or software issue.
Jun 20, 2011 | Dell Latitude D600 Notebook
When i boot up i can choose to start windows normally : safe mode/ w/o networking blah blah but when it boots up the screen just goes black and never loads windows, What are the suggested problems, and/or...
Well first off, when you say 'but when it boots up the screen goes black', what option did you pick? I would try selecting 'Safe Mode with Networking" and see if you can't get into windows. If you can't get into windows in *ANY* mode, you're probably going to have to reload/repair the os instalation. If you can get into safe mode, install 'malwarebytes', an antimalware software, and see if it comes up with anything. If not, I would say that it could be a driver issue.
Sep 26, 2010 | Gateway MX8711 Notebook
Black/blank lcd screen after 2 seconds
try this - boot into "safe mode" - (this loads just minimal drivers). Reboot and press F8 while it's booting - it will ask if you want to boot into safe mode - say yes - if the screen works with the low resolution inherent drivers, it's probably a driver issue, or if you have a video card, it may not be able to work at the higher resolutions (which could be a card issue)
This should help you narrow down if the screen actually works, or if it's a graphics card and/or driver issue.
If it works - try reloading the driver for your graphics card (if you don't have a graphics card - try reloading both the chipset driver and the video driver from the manufacturer)
let me know if this works...
(I had a Toshiba Tecra laptop that did the exact thing - you could see the Windows boot menu, and once it completed boot up, the screen would go black - if you started it in safe mode (crummy resolution) it worked but of course the graphics are unacceptable at that resolution)
Turns out this is common with those, it was the graphic card built into the motherboard that's shot....
Oct 21, 2009 | Dell D1728D-LS VS17X Monitor
My asus computer has just crashed, it wont open the vista it says windows could not start, a recent modification could be the cause of this problem, how do i get it started
press f8 key at early boot and choose "safe mode". if that boots, "last known good configuration" should get rid of bad added driver, if that won't work go to help and support in safe mode and pick an earlier restore point for when it did work.
Oct 14, 2009 | Microsoft Windows Vista Ultimate Edition
XP wont load in safe mode
MAY BE DUE TO LOT OF VIRUSES. DISMOUNT YOUR HARDDISK FROM YOUR SYSTEM AND SCAN IT FOR VIRUSES IN ANOTHER SYSTEM WHICH HAS THE LATEST UPDATE OF A POWERFULL ANTIVIRUS SUCH AS KASPERSKY....
Sep 23, 2009 | Microsoft Windows XP Professional With...
Emachine w3107 reboots when windows xp loads
These kinds of issues are most often related to driver conflicts. First thing you need to do is reboot your PC while holding F8, until you receive the menu about booting in to Safe Mode. Try booting in to Safe Mode.
If you can get in to Safe Mode, disable any new devices you have recently installed, reboot again, this time letting it try to boot all the way to Windows.
If it reboots again, go back in to Safe Mode and disable/uninstall something else.
Basically, it is a process of elimination. Safe Mode loads a very minimal set of system drivers, so if you can boot in to Safe Mode but not in to full Windows, the problem is one (or more...) of the drivers that load in Windows but don't load in Safe Mode.
Mar 19, 2009 | E-Machines eMachines Desktop PC
My computer is not booting up.
Try this,Start in VGA mode.Once started,update your video drivers and do a virus scan
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Safe Boot options loadTOCNode(2, 'moreinformation');
  • Safe Mode (SAFEBOOT_OPTION=Minimal): This option uses a minimal set of device drivers and services to start Windows.
  • Safe Mode with Networking (SAFEBOOT_OPTION=Network): This option uses a minimal set of device drivers and services to start Windows together with the drivers that you must have to load networking.
  • Safe Mode with Command Prompt (SAFEBOOT_OPTION=Minimal(AlternateShell)): This option is the same as Safe mode, except that Cmd.exe starts instead of Windows Explorer.
  • Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
Please rate this a fixa
Jan 15, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Toshiba equium l20-197 booting
Chances are that it is a driver problem, try booting in safe mode by pressing f8 during the initial bot up process and selecting safe mode, with or without networking, if your systems goes in to windows then you have a drive issue, as safe mode loads with only the basic drivers needed to run windows, hope that helps
Dec 14, 2008 | Toshiba Equium 100 PC Desktop
Computer crashed, won't go to windows
When you start you computer, after the bios flash. press the F8 on your keyboard before the Windows start loading. You should have an option to select to go to safe mode.
Select the safe mode option only. See if it will load the Windows under the safe mode option. If it did load the Windows under safe mode. There is an issue loading the driver of your Windows O.S. that i why its not booting under the Normal mode. Sometimes this is cause also by a Virus on your computer. You can run the Anti-Virus program under Safe mode to check for viruses
To fix this you may need the Original Disc of Windows O.S.
You can reboot the computer. Load the disc make sure that under the Bios option the CD drive is the first boot. Then save it.
after rebooting. Follow the on screen instruction on how to repair the O.S. There should be an option to repair the O.S. when you boot the computer using the Windows O.S. Disc
Note:
If you could do a backup of your files, do it first before repairing the O.S.
If it will not resolve the issue, you will have to reformat your computer.
Sep 09, 2008 | Computers & Internet
Black screen comes up "windows did not start successfully...." choose from safe mode, safe mode with networking etc Last known Configuration or Start Windows Normally. Computer then tries to...
You should opt Safe Mode:
  • On the black screen just navigate throug up and down arrow keys.
  • Goto Safe Mode and press enter.
  • It will boot your system in safe mode.
If the boot is success full:
  • try to remember any software or hardware you recently installed/change. Then remove/uninstall that software/hardware. Also remove some device driver like Video/Audio driver and make re-start. and try to normal boot. If success then install your audio/video.
If no success then I think its time to re-install your windows.
Please post your feed-back.
Gud Luck
Iqbal
Apr 20, 2008 | Computers & Internet
MPC Computers ClientPro 414 All-In-One PC Desktop Logo
111 people viewed this question
Top MPC Computers Computers & Internet Experts
Paul Bade
Muggs01
Muggs01
Mark Gough
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
