Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Black&D'er CMM1200 24V is running very slow unable to chew grass
My Black&Decker CMM1200 24V 19" mower 's ability to cut any size of grass blade has been compromized. It sounds as if it is spinning in slow motion, even with a full charge. Also after having it plugged in for 8 hours, I have not noticed the red or green light on the charger cord. Are these 2 issues related? Where can I get it repaired? Chicago, IL
  • 382 Answers
Sounds like a battery problem, you could have a defective cell which is causing a very low voltage to be sent to the motor which = slow spin.
Yes the charge indicator could be related.
You can take the battery apart and find out what type of cell it is and have it replaced...but personally I hate cordless lawn mowers for this exact reason so I would go but a manual push or a gas model.
Posted on May 05, 2010
Not picking up grass
maybe discharge shoot clogged or mower not running fast enough
Aug 16, 2014 | NA Black & Decker SPCM1936 19-Inch 36-Volt...
My electric lawn mower power keeps cutting out IT RUNS WHEN PLUGGED IN BUT VERY SLOW,TIPPED OVER RUNS FAST.bLACK AND DECKER CORDED 19 INCH REARBAG
if it runs slow when mowing then when its tipped upside down there is no pressure on the blades its faster the bearing is gone worn out
Sep 25, 2008 | Black & Decker 19" Electric Lawnhog...
I own a cordless Black & Decker 19" rechargeable mulching mower, CMM 1200, 24V. There are days that it starts beautifully, and others where it remains quiet and uncooperative. Temperature seems to...
Mulching mowers are notorious for needing to be cleaned out frequently. The problem usually is the cutting height. The lower it is, the faster it gets clogged up.
Cutting wet grass doesn't help this situation either, it actually makes it clog up much faster.
Set the cutting height to about 3", and wait until the grass is dry before you cut it. This should help with the cuttings buildup.
As a landscaper, I deal with lawnmowers on almost a daily basis, and on cold mornings, the mowers are sluggish and don't want to run well.
If you keep your mower stored in a weather proof building with a consistent temperature and humidity level, there shouldn't be many issues with startup. Start it up and let it idle at half choke before cutting.
I hope this helps you.
var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Jul 31, 2011 | Black & Decker Cmm1200 24v 19" Cordless...
18" Electric LAWNHOG™ Mulching Mower from Black and Decker idles very low then revs up but fails when cutting grass
Most likely the motor 'brushes' need to be replaced now.
These wear over time and most likely should be replaced by a professional.
Gary @ Fix Ya
Sep 05, 2010 | Black & Decker 19" Electric Lawnhog...
Why does my electric mower lose power in high grass? After waiting a few seconds &/or tilting it up, the engine revs back up and can continue to cut. It is a older model. Doesn't have a fan attacted to...
The high grass causes more drag than shorter grass. This means more friction. The tilting lessens the drag, so less friction, the speed increases. It ma need a sharpening but it sounds as though it is running correctly. As you say, it is older so you can't expect new performance. Good luck...Lee
Sep 16, 2009 | Black & Decker 19" Electric Lawnhog...
I would like to buy a petrol lawn mower, i have found out there are mulching lawn mowers on the market, what are your views on this type of mower
Mulching mowers are great if you dont have the time to rake the excess grass or the means ( time or ability) to dispose of te collected remains. The mower will mulch te grass right back over te top of the cut grass with minimal apperance of grass being left behind, if you kep up on the cutting schedule that is. Better for larger areas where "lines" would usually remaine with a non mulching mower.
Aug 11, 2009 | Black & Decker Black and Decker Mm575 18"...
B & D mulcher mower stop while mowing
electric & battery operation mower are not suppose to be use when grass are too long & wet, it draws lot of power that appear to runs slow.when you see try to restart i think the brake is trying to kick in.
Jun 15, 2008 | Black & Decker 19" Electric Lawnhog...
Mower won't start
13 to 15 amps electric or battery operated mower may runs slow when cutting thick grass. also recommended not to cut grass when it's wet & need very sharp blade to do the lawn. may overloading it, cutting grass too thick also draws too much power. check house breaker first.
Jun 11, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
789 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
