Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Gray Screen I pressed the button to stretch out my HD picture last night and when I did it the screen just went gray. There is still function and sound, but no matter what channel you turn it to it is just a gray screen. Help solutions.....
    Genius:
  • Panasonic Master
  • 1,689 Answers
Them main video processor driver board may have to be replaced. It is also possible that the power supply may have a fault.
The factory service tech will try the modules to test for which one has failed, and then leave in the module that fixes the fault.
Jerry G.
Posted on Apr 30, 2008
My LG HD tv screen has a wide, gray band on either side of the picture
Try changing 'perspective' or screen ratio.
This may work, but could also stretch the picture too wide,
On my non-LG TV this is called 'aspect ratio' under the 'picture' menu.
Nov 20, 2017 | LG 42LB1DRA 42 in. LCD Television
Last the picture . have a white or gray screen. It was working fine one minute then the picture was gone. It's not the PC ,I check.
Gray glowing screen can be due to bad T-CON board (blown fuse, bad IC), or the main baord is not sending the 12vdc to the T-CON board. See my giudes.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 23, 2010 | Gateway 24" Widescreen Flat Panel TFT LCD...
Gray bars
Hi, you can removed this bar by using the picture size function in you menu this is du to the signal
you receive in your tv;if your tv got a full hd signal
choose the 16:9 picture format the bar will disapear
if you dont have 16:9 signal that normal but you can choose full screen mode it should gone , that is 4:3
format extend it to ful screen mode.
good luck and have a nice day.
Mar 13, 2010 | Televison & Video
Picture is too big for screen
You will have a button on the _original_ remote that says Format, Aspect Ratio, Zoom, Size or just AR. It will cycle through Normal, Stretch, Partial Zoom, Zoom, Gray Bar, or the like. You are not in Normal but in one of the Zooms. Stretch is used to make 4x3 movies fill a 16x9 screen, may not be desirable. Zoom is used to fill the 16x9 screen with movies that have been letter boxed. Gray Bar fills the sides of a 4x3 picture on a 16x9 set with gray to "avoid" burn in. Use normal except zoom on LB. -Ken
Oct 04, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
IVA-W203/P1 starts screen shows than gray and wont do anything
Pressing down the reset button for at least 10 seconds may solve the problem. Sometimes media units glich like computers.
You may also try disconnecting the battery for 30 minutes.
Keep me up to date.
Mar 31, 2009 | Alpine Car Audio & Video
Gray spots on screen on a JVC HDILA model HD 56G 787
The HD-ila sets accumulate a lot of dust in the light engine. The worst offender is the little fold mirror just under the lens. I take my set apart about every 8 months or so to clean all the dust from the light tunnel and all lenses, mirrors, diffusers etc. The picture really regains it's pop when this is done. Unless you are a skilled technician though, I would recommend against attemptimg this procedure as you need to disconnect the individual color lcds. Check with a local service center to get it properly cleaned.
Oct 16, 2008 | JVC HD-56FN97 56" Television
Gray borders on the HD channels
Have you tried to change the screen size? To do that press the "Psize" button on the remote till you find what you need.
Dec 29, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
200 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
