Question about Nokia Intrigue 7205 Cell Phone
Dropped in toilet - Nokia Intrigue 7205 Cell Phone
    Guru:
  • 109 Answers
Congratulations!!! remove every parts you can i.e. battery, SIM card and memory card. Make sure each and every single drop of water is out. Wrap the mobile phone thick with a piece of cloth and keep it on a warm place ( Not too warm ) like Above the TV( thats the best i can suggest) for couple of days, 3-4 days will be sufficient. Make sure you don't switch it ON while its wet otherwise the Flash IC might get fried by the battery. After 3-4days of evaporating the water from your Mobile, keep fingers crossed and switch ON the Mobile. If switched ON perfectly for 10-15 minutes (try checking all the feature in this time period) the mobile phone is in good status and if it doesn't kindly purchase a new Phone because i won't suggest you to get it repaired as once Nokia phone goes for a repairing it will always ask for repairing after 2-3 months.
Posted on May 05, 2010
Loose water pressure after flushing toilet
That is normal. If you want less pressure fall turn the water supply line half off.
Oct 21, 2017 | Drops Home
Do you turn the screw to the left or right on a american standard toilet to adjust the water level in the toilet tank
Usually to the right will drop the float, deceasring the water level, left will increase the water level.
Aug 25, 2014 | Cadet Manufacturing American Standard...
Soft close toilet seat
Mine is a Bemis and does the same thing. Seat drops and lids does a slow close! Are you going to takes yours back for a new one?
Jan 18, 2014 | Home
Hinge on quiet close stopped working
A lot of these slow closing toilet seats don't work well, so I suggest an alternative, Drop-a-Seat cushions. They stick on to the bottom of the toilet seat, allow you to drop any toilet seat, gravity does all the work, and the cushions absorb the impact. They're non-absorbent, stick on for easy installation (permanent yet removable), and are only $4.99. Check them out at www.drop-a-seat.com
Aug 14, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
Our toilet bowl's water level drops to maybe an inch depth, Why?
it could possibly be cracked inside the bowl sometimes its not noticed only way to find out is to replace flapper if stlii loses water replace toilet bowl
Mar 11, 2010 | Home
An old eljer toilet with the drop ball and brass guides. I cannot get the ball to seal well. What can it be?
I think I have a similar toilet--I found at Lowes a new "drop ball" that seals the hole in the tank. You're drop ball might be disintegrating from the hard water in the tank. Take the tank cover off and shut off the water before flushing the toilet. Once it's flushed pull up the drop ball. Feel if it's still solid or not. It is easily removed by unscrewing it from the rest of the assembly connecting to the flushing handle. Unfortunately for me, the one they had at Lowes was slightly different in shape than the one I had, so I had to return it and deal with the older one. good luck!
Sep 22, 2009 | Eljer Home
American Standard Elongated toilet bowl water level slowly drops
The tank holding the proper amount of water is a good sign. The inside of the stool is like the GOOSE NECK under you sink. It always holds water. This may sound like a bit of a hassle to do but if all 3 toilets are identical, here is what you can try if you are a bit handy. Go to the hardware store and purchase 4 toilet wax rings with a plastic flange and a few sets of toilet floor flange bolts(they are cheap and you can always return if not used, as It is better to have xtra parts on hand). Turn off the water supply to the "Mystery Toilet". Leave the tank and everything connected to the stool. Flush the toilet and remove all excess water from the tank and bowl. This can be done with a shop vac, sponge or towel. Disconnect the water supply to the tank. Remove the bolts holding the stool to the floor and carefully remove toilet. Scrap off all the old wax from the floor flange and bottom of stool. Now go and repeat this proceedure to one of the toilets that is working properly. In other words Switch the "Mystery Toilet" with a "Working Toilet" and see how they react. If the working toilet does it in the same bathroom and the "Mystery Toilet" does not do it in the other bathroom then you probably have a VENTING PROBLEM. If the "Mysery Toilet" Does it in the other bathroom then you most likely have a Defective Toilet. This Job is best done by 2 people, as it can sometimes be challenging to center the new wax ring on the toilet flange. Reconnect to the floor and reconnect water supply to the tanks. DO NOT OVERTIGHTEN BOLTS to the floor flange as you may crack the toilet. All drain lines must be vented properly for water to flow. If you are curious check out drain venting on the internet. Also, sometimes a vent can become obstructed with debris, ice, bird nest, etc.. I would 1st check the vent on the roof visually and then have someone flush and listen. If you believe the vent is clear....Then do the toilet switch and go from there.....Hope this helps and Happy Holidays....Joe
Dec 21, 2008 | American Standard Cadet 3 Right Height...
Nokia Intrigue 7205 Cell Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
