Question about HP LaserJet 2820 Printer
HP Laserjet 2820 getting error 10.1004 supply error when installing a new imaging drum. Anyone ever got this error msg? Thanks
    Scholar:
  • 141 Answers
Does it work with this error....if so you wanna
make sure that you have a HP cartridge, sometime the chipset is not recongnize....and you have some function that doesn't work. If you try all this, call HP.
Posted on Mar 26, 2008
Hp color laserjet 1025 cartridge memory error on imaging drum
If the ground spring located on the left inside wall of the printer is ok, and you have tried cleaning all the ground contacts on the cartridge, then it may just be a bad toner cartridge. Especially if it's a third party cartridge and/or especially if this problem happened right after or shortly after installing a new cartridge.
Jan 19, 2015 | HP RB3-1025 Hewlett-Packard Color Laserjet...
Codigo de erro 59.99 na hp 2820
59.99-T2 Clutch error:
Check the cable connections to the DC controller. If the error persists, remove the imaging drum and
check the clutch. If the error persists, replace the T2 clutch. If the error still persists, replace the DC controller.
Jul 11, 2011 | HP LaserJet 2840 Printer
I have a hp color laserjet 2820, it says "replace supplies" and "device busy" . It was working fine yesterday and now won't print.
The replace supplies means that something has either reached end of life or has failed and needs to be replaced. Device busy usually indicates that there is a print job queued in the printer that needs to print, but the supplies out is stopping that from happening. Clearing the print queue on your computer and then restarting your printer might clear the device busy error, but the supplies error will likely require replacement of something.
May 01, 2011 | HP LaserJet 2820 Printer
LaserJet 2820 Printer: can the drum be cleaned. it is asking to replace t...
no try to restore the factory default if prob resolved then ok either u hv to replace the drum
May 18, 2010 | HP LaserJet 2820 Printer
Supply error 10.1004 on HP laserjet 2820 printer
this error comes when the printer not reco the cairtages & drum if u replaced the print cairtages then replace the drum & calibrate the printer & restore the factory default.
May 12, 2010 | HP LaserJet 2820 Printer
Hp 2820 prints only on right side of page
Yes, you will need to replace the drum unit as well. be sure to shop around so you can get the best price because some people mark up the price for that part. You can check the status of your supplies from the printer itself by pushing the "menu" button the printer and scrolling through until you see something about supplies status then press the check mark button.
Jun 02, 2009 | HP LaserJet 2820 Printer
HP 2840 10.1004 SUPPLY ERROR I am getting a 10.1004 error meassage after replacing the chip on the imaging drum. Previously I was getting a "replace drum"message so I know that it was the imaging drum...
there is something wrong with your drum.. try to replace a new chip for the drum make sure that the chip is working.... if that did not work. see if there is any damage in your drum.. If not replace a new drum..
Apr 20, 2009 | HP LaserJet 2840 All-In-One Printer
Hp2820 noise when printing
Try substituting a new imaging drum. The problem may be a bad bearing.
Oct 09, 2008 | HP LaserJet 2820 Printer
????????? ??????????? document viewer ÷?? ???????
Dec 07, 2007 | HP LaserJet 2820 Printer
HP LaserJet 2820 Printer Logo
379 people viewed this question
Seeker5211
Seeker5211
