Question about Nokia 5310 Cellular Phone
After battery down, while charging and switching it on , the answer is contact service
  • 450 Answers
Software problem, phone needs to be flashed
Posted on May 11, 2010
My Fujifilm Finespix S4200 won't turn on
Your camera will work with AA batteries.
Always be sure the batteries are charged.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work. Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
If nothing helps, perhaps you should try a new set of batteries and or another charger.
To rule out the camera is defect, put in new alkaline batteries. If the camera starts up normal, you can remove them end concentrate on the batteries and charger.
May 10, 2014 | Cameras
My Ben Q GH 600 got shut down due to old batteries. Now it is not starting despite having new batteries.
Always charge the battery before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Feb 01, 2014 | BenQ GH600 Fashion Chic 21X Optical Zoom...
Hi: I currently owned a Craftsman Lawn Tractor- 22"-18.5HP-Briggs/Stratton Engine. I am having problems with the battery not holding its charge. I'm having to jumpstart it at all times. I have...
There is a wire that comes down from the top of the motor and that is what charges your battery. Make sure it is connected, it will come down and out of the top shroud probably close the starter solonoid. Your mower will start and run without this connected, it just will not charge the battery. If it looks Ok and is hooked up, your charging system could have gone bad. Take a volt meter and check the voltage with engine off and engine running(it should be higher running). If this tests OK, then you have somthing discharging, if thats the case go to your local auto parts store and buy a battery cut off switch. This will allow you to turn a nob after useage and not allowing the battery drain. Then you simply turn the nob back to on right before you start the engine. This is a simple and easy way to fix the problem. Hope this helps.
Please take a moment to rate my answer..........Thanks
Dec 01, 2010 | Garden
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
Wont charge ....just shows colors and low battery icon
1) Ensure the cradle is plugged into an active AC outlet and the LED light on the cradle is on. There is a switch on the bottom of the cradle to control the brightness of the LED, set it to the highest. Try different outlets if needed. Does the LED light turn on and stay on (does not blink)?
ANSWER:
2) Remove the battery. Place the remote on the cradle and check the LCD screen. The LCD screen should display a 'White' screen with possible colors before going off. Try this a few times to confirm behavior. Did the LCD turn on briefly?
ANSWER:
3) Reinsert the Battery. Have you charged the battery for at least 3 hours? If no, please recharge the batteries for at least 3 hours.
4) Did the battery ever boot the remote? If yes, please continue troubleshooting.
ANSWER:
5) Remove the battery. Check the 3 gold contacts on the battery to see if there are markings on all the contacts signifying it was connected correctly to the remote. Did the battery have markings on all 3 contacts?
ANSWER:
Jan 16, 2010 | Logitech Harmony One Advanced Universal...
Remote not charging?
the battery can be charged whenever you want to charge it. There may be an issue with the cradle. can you please follow steps below and reply back with the answers?
ANSWER:
ANSWER:
ANSWER:
ANSWER:
Jan 14, 2010 | Logitech Harmony One LCD Touchscreen...
My 880 will not charge I used this 2 years ago and it worked The remote still holds the old settings I now want yo use it but the unit said battery low recharge. I tried to charge it but it would not...
There is a trick with these remotes. Take a tiny piece of paper and
wedge it in between the battery and the side of the battery compartment
opposite the battery contacts when you insert battery.
This will apply more pressure between battery contacts and remote.
Now your harmony should properly charge up overnight.
Had the same problem with mine and the paper trick fixed it.
Was even able to use the old battery again.
Has something to do with the three contacts on the battery.
All 3 need to make good contact.
Nov 19, 2009 | Logitech Harmony 880 LCD Remote Control
Canon EOS Digital Rebel 300D will not take pictures
Have you tried to take picture by switching off the autofocus to manual focus in a prperly lit environment?
If it takes a picture, then it has something to do with your auto focus system of your camera. In such a case: try taking out the battery, the memory card etc and switch off the camera and keep it for like that for about 5 minutes. And then insert only the fully charged battery and try again.
If it still gives you a problem and keep trying to focus You will need to take it to the nearest Canon Service centre.
Mar 08, 2009 | Canon Digital Rebel / EOS-300D Digital...
Uniden Power Max 5 Battery problem
Your phones have the charger built into them and that is what has gone bad. After a while the dealt-V sensing unit dies and the phone overcharges the battery. You will notice your batteries heat up when charged then your delta-V sensing circuit is probably shot.
Personal Note: I think home phone manufacturers are using old non-lipo technology because it has these faults and you will have to get a new phone after some time. Also.... Why aren't home phones half as cool as cell phones??? Hmmmm.... Yeah I want my home phone to get, wifi, contact sync, usb connection, color screen, multi-ring, infinate contact storage, calendar, timer, and all the other bs in a cell phone. At least contact sync through USB, come on. Or even a shared phonebook for all phones right.
Sep 15, 2008 | Uniden TRU8885 Digital Answering Machine
Problem during installation
Did yo first let all the batteries charge like they asked you to when you first installed it? Did you check to see if there if there is a battery needed for the answering machine? Best I can do is give you the toll free number for customer service: For customer service assistance, dial 1.800.448.0329, Contact Us via Email or, if you prefer, write to us at Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034
Jul 19, 2007 | GE 27851FC1 2.4 GHz Cordless Phone
Nokia 5310 Cellular Phone Logo
24 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
