Question about Frigidaire FRS23R4A Side by Side Refrigerator
No water flowing into the icemaker. The water is going into the cold water on the door. However, when I take the line off for the icemaker... no water comes out. I see that there are 3 connection for the water... could it be that the one for the icemaker has gone out? If so, how can I check this?
  • atrouble3931 May 05, 2010
    Yes, I figured out just what you explained... I swapped the power inputs and when I pressed the cold water dispenser water came out of the ice maker connection... so now I know that the solenoid is not bad... I think I will either have a faulty wiring or the frozen inlet tube... I will try and check the inlet tube... Do you have any pointers on how to check this?
  • 122 Answers
The line to the icemaker won't have water coming out until the icemaker cycles and energizes the solenoid valve. check the inlet tube where it goes into the icemaker. sometimes this freezes shut. you can also check the continuity of the icemaker solenoid.
Posted on May 05, 2010
Testimonial: "It turned out to be the inlet was frozen just as you suspected. You saved me a service call. I had to remove the inlet and remove the frozen ice... now everything works fine. I really do appreciate the information. "
U-Line Icemaker is cold, but no water in resesrvoir for the ice.
Your water valve may hay a drip like a faucet. Causing the spout to freeze up.
Jul 08, 2012 | U-Line Icemaker
Undercounter icemaker is cold but does not make ice --no water getting to the ice tray --checked to srr if feed line was blocked and was clear ----will freeze water put into little containers placed in the...
The water solenoid valve controls flow to icemaker you can put 120 volt to it and see if it opens .If it is good then its not getting power when icemaker calls for fill
Jun 22, 2011 | U-Line Icemaker
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water flowing to the icemaker would not stop. It over flowed the
sounds like the water switch is stuckopen or the valve is. Is the water going to the icemaker or thru the door. If the icemaker is overflowing and doesnt shut off then unplug unit,still coming in change the valve. Not coming in then look at the switch.
Jun 10, 2009 | Kenmore 53542 / 53544 Side by Side...
GE REFRIG MODEL GSL25KGRB BS 4 YRS OLD. PROBLEM: WATER IS NOT DISPENSED BUT THE ICEMAKER IS WORKING. CHECKED ALL THE WATER LINES. LIGHT WORKING ON THE CONTROL PANEL. GETTING WATER TO THE QUICK CONNECT...
Found another post that says the water line is froze in the freezer door. They said to turn the night light on for 24 hours and see if that helps. I'll give it a try.
Dec 03, 2008 | Refrigerators
Water despenser
hi there,
check to see if you have a leak in the water line. the line runs from the wall to the icemaker. do you have any leaks on the inside of the door? any frost build up? im assuming that you have a side by side fridge with an icemaker.
Oct 11, 2008 | Refrigerators
Icemaker won't fill with water
If you would like a repair manual for your refrigerator, you can get one here. These are helpful to have in case you have other issues with the fridge.
Thanks
Sep 29, 2008 | Samsung RS2630WW Side by Side Refrigerator
Ice Maker problem
check if it has one the filter, hollow ice = lack of water flow into the icemaker
Apr 26, 2008 | Refrigerators
Samsung rs2555sl icemaker
replaced circuit board. Problem solved
Oct 17, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Frigidaire FRS23R4A Side by Side Refrigerator Logo
730 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
