Question about Kenmore 98702 Stacked Washer/Dryer
How do i open washer of stack dryer washer to get to motor area. is front panel snaped on?
  • 122 Answers
Remove the angled panel between the washer and dryer, you will see either 3 or 4 screws holding the top of the washer in place or 2 gold colored clips. remove the screws(or clips) and the top should slide forward and come off. this gives you access to the screws holding the front in place.
Posted on May 05, 2010
How do i replace a stack washer dryer dryer door switch?
when you open washer door you hit a stopper pin that holds the door open. there are 2 screws located around that area on both sides of panel. remove them and you'll see vent hook up and water line hook up and power cord. Now at the backside of washer door panel there are two screws remove them and pull washer door panel towards you. under the door panel connected to panel is where you will find door switch. if you jump out door switch and it works then you need new door switch.
Apr 30, 2014 | Whirlpool Thin Twin Washer and Electric...
Water fills but wont agitate
you may have a snaped belt or the electric motor might be shot.
Dec 14, 2013 | Maytag Washer and Dryer STACK KIT for...
My LTE5243D top load stacked washer is about 10 years old. How do you take the front panel off to access the washer's motor coupling?
To gain access to the washer components, the front panel between washer and dryer must be removed first.
Remove the two top screws securing thethis panel to the unit.Tilt the transition panel down and pull itstraight out.Remove the two screws located behind the washer top.Pull the washer top forward to disengage the top locks. Disconnect the washer lid switch harness. Lift the washer top off the unit.Remove the two screws from inside the top of the washer front panel.Lift up on the front panel to release the catches near the bottom of the panel andremove the front panel.
Apr 24, 2012 | Whirlpool LTE5243D Top Load Stacked...
Hi! How do you replace a water valve(part#22002437) on a Maytag Neptune Stack? I know how to do it on a washer only, but how do I get to it on a stack Model# MLG2000aww?
wow it's quite a job you need to disassamble the control panel area between the washer and dryer,take off the washer front panel,then reach in the back of the inside of washer to remove and install new valve and also get to the back so ya can remove and reinstall the hoses from the valve.
Wish you well i've have a few busted knuckles when doing that repair
Aug 11, 2011 | Maytag Neptune MAH5500B Front Load Washer
Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
May 28, 2009 | Kenmore 43042 Front Load Washer
How do I replace the washer belt
Remove the front panel to the washer. Screws across the bottom. Push down on the front panel, then pull it out. Belt should go around transmission, motor pulley and tension roller.
May 13, 2009 | Frigidaire MET1041ZA Top Load Stacked...
Removal of front panel of a stack washer and dryer mod
Their are screws between the washer and dryer. Undo those and the screws inside the dryer, next too and below the lint trap.
Jan 17, 2009 | Maytag LSE7806A Top Load Stacked...
Removal of front cabinet panel of washer section
Should be two screws on each side of the bottom of the front panel. Takes those out and push the panel up and out. (There are two "tabs?" in the middle of the front panel that lock into the side panels, so you have to push up and then pull out.)
Jan 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
494 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
