Question about Lorex Home Security
I cant get the cameras to give a picture view on the screen. All I see is blue screen.
  • Scott Sund May 05, 2010
    I have the cameras set up via factory defaults but have no image on any of the 4. What resolution settings would you recommend for daytime or night use? The system wont allow me to change the password on the included monitor/dvr; is this a problem? If so, how do I reset?
    I have a Lorex system---color 4 cam. All cams are attached but I can'yt get a picture. My password entered into the monitor/dvr combo with the st is numerical and says NOT accepted. Can I reset? How do I get a picture on the screen. Now using ONLY factory defaults.
  • 12,061 Answers
Hi, well whenever you have "Blue Screen" thats an indication that NO VIDEO, is being applied to the Input or "Source". Or that there IS, but the Screen, is faulty, you will have to troubleshoot to find out. Ensure you are connected up correctly, with all cables color to color, Video, and Audio, Video, can be, Composite, Video, Yellow, plus Red & White Audio in, Or, SVHS Cable, and Audio, Red & White, Or, Component, 3 cables, Red Blue, & green, plus the two audio, Red & White, (5 in all). Once connected with the correct cables, then select the appropriate Input, from the Screens Menu, and select the appropriate EXTERNAL Input, ensure the device, being used to output the signal, The Camera's picture,, to be displayed by the screen, is working, always check on another INPUT device, Screen, to ensure it is actually putting out a signal. If all is well, and you are getting a signal, make sure the Format is correct on the input device, NTSC, USA, PAL everywhere else. Also ensure the Screens "Format" is the same, either NTSC, or PAL. Check, cables are all plugged in correctly, choose input, and you should have a signal. You should get as manual for your exact make and model screen, inside it shows you what to do, and how to troubleshoot.
Posted on May 05, 2010
  • 382 Answers
Are you using a VGA monitor or a TV with composite video?
It is very common to have this problem with VGA monitors, you have to hook it up to a display with composite video and check the output resolution. This occurs because some of the surveillance systems do not support DDC and you have to set the resolution manually.
Let me know if this works,
Thanks,
KJB
  • Kevin Braid May 05, 2010
    Check your individual cameras and make sure they are working fine. Once a camera is plugged in it should display its picture.
HOW DO YOU CHANGE CAMERA PICTURE FROM FRONT VIEW TO BACK VIEW
Android 101 How To Use Your Front Facing Camera
Even if you don't have an android phone it should give you a hint to help you figure it out.
Jan 15, 2014 | Computers & Internet
APPARENTLY, I HIT A WRONG BUTTON AND NOW I HAVE A BLUE GRAPH LIKE IMAGE IN THE RIGHT HAND CORNER OF THE CAMERA SCREEN WHEN I VIEW THE PICTURE THAT I JUST TOOK. HOW CAN I GET RID OF THIS BLUE GRAPH?
You're seeing the histogram. To get rid of it on many cameras, simply press up-arrow or down-arrow (usually on the big circular multiselector). If that doesn't do it, please reply to this post specifying the make and model of your camera, and someone can give you more precise instructions.
Nov 02, 2010 | Cameras
Every thing seems to work but view screen is blue and takes a blue picture (has ripples that move when you point or move camera around like you can almost see something but you can't. My logo and phone...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Dec 03, 2009 | Canon PowerShot A85 Digital Camera
Sony digital video camera mode no. DCR-HC14E not showing pictures/recording
If your Sony DCR-HC14E shows fine picture in playback of old tapes and does not give live view in camera mode to record then its CDD Imager problem that Sony will repair free of cost.
Click Sony CCD Imager Support for details.
Jun 10, 2009 | Sony Handycam DCR-HC14E Mini DV Digital...
LCD Screen
cant be done you need the new 450d which has live view so you view the lcd when taking the picture
Oct 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
THE LCD SCREEN IS BLACK AND I CANT TAKE A PICTURE. BUT I CAN STILL VIEW MY PICS. THE CAMERA GOES THRU ALL THE MOTIONS LIKE IT IS TAKING A PICTURE BUT IT IS JUST COMING UP BLACK.
The LCD screen is black and I can't tace picture. But I can still view my pics. The camera goes thru all the motions like it is taking a picture but it is just coming up black.
Aug 31, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Cant take photos as it says the card is write protected
Take your memory card out of the camera and switch the position of the little "lock" tab. That should fix it and you can start saving images.
Mar 20, 2008 | Nikon Coolpix 4100 Digital Camera
File Error
File error means it cant read the file or the file is corrupt, i would try a new memory card or format the one you have.
Feb 07, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
My camera wont take pictures card read error
I took a pictures with my camera and now some I cannot view some of the pictures it says Picture error
Dec 20, 2007 | Olympus FE-100 Digital Camera
Black Screen
camera ccd is / has failed - also possible , lens iris is stuck closed ( on monitor , can see very faint snow noise against black background - check if iris opens , by shining penlight into lens );
May 03, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Home Security Logo
166 people viewed this question
Top Lorex Home Security Experts
Henry  Thomas
Henry Thomas
Lawrence Oravetz
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
