Question about Frigidaire Freezer FFU1724
I have a chest freezer model AFFC1526DW2 it stopped freezing. The power light is still on. What could be the problem
  • 122 Answers
The thermostat may not be turning on the compressor.
Do you hear a buzz and or clicking every few minutes when plugged in? If so the compressor is trying to start indicating a problem with the compressor. you could check the windings for continuity or a short and then try a 3-in-1 start kit.
Posted on May 05, 2010
Hi I have a Belling BCF10 chest freezer. The power light is not lighting but the freezer is still freezing, what is wrong? Also when should one use the fast freeze switch? Thanks in advance
If the freezer is working properly then the circuit that feeds the power to the power light is not working or the light itself is burned out. Either one or the other.
Sep 17, 2016 | Belling Freezers
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
I have a Kenmore 5 cu ft freezer that won't come on. I've checked the plug in and it works fine. Where would I start looking for the problem????
If, by plug in you mean the socket, then you need to check the fuse in the power plug next.
At the very lease there should be some light on the unit that illuminate even if it does not FREEZE.
If the compressor comes on wait to see if there is any drop in temperature. then it is possible the fuse was faulty.
see below links for more information on possible causes
How to fix Kenmore chest freezer model 255 19502010
Kenmore 5 cu ft 142 liter Chest Freezer 14512 Page 11 Recent Questions...
Jul 18, 2015 | Kenmore 5 cu. ft. / 142 liter Chest...
Chest Freezer Stopped Working 14 years old
The first thing you want to ensure is that power is actually getting into the unit. i suggest that you do that by plugging a night light into the outlet and verify the presence or power. If no power, check your breakers. If power is present note that A chest freezer has only two working parts; the start relay that help the compressor start and a compressor. If you are getting clicking sound, your start relay may be out (inexpensive if you can buy it and install it yourself) or a bad compressor. if you need to call a tech for the repair, you may be able to purchase a new chest freezer that now consume HALF the power and for less than cost of repair.
Mar 02, 2014 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Fast freeze light on all the time is this right new belling 100 ltr chest freezer
No check your settings. You may try to unplug it for about a minute and then restart. If that doesn't work, call the mfr. they should help since it is new.
Feb 02, 2013 | Magic Chef Chest Freezer MCCF5WBX
My kenmore model 19502 freezer is not freezing
Have the same freezer bought the warrenty glad I did services tech said that he knew the porblem before he came to fix it compressor locked up at 7.9 amps he said this is an issues with 99.9 percent of this model. Light was on flashing but food would not freeze. Sears will replace for me they are giving me a diffrent model number. I had no power surge or nothing of that manner. Faulty appliance. A recall has'nt been issued... but it should
Oct 13, 2012 | Kenmore 5 cu. ft. / 142 liter Chest...
My chest freeze just stopped working. Have checked
Your start relay or overload relay must have gone out. What is the model number of your unit?
Jul 30, 2011 | Frigidaire Freezers
THE GREEN POWER LIGHT FLICKERS, AND COOLS ONLY WHEN THE FAST FREEZE POWER BUTTON IS TURNED ON
This sounds like the freezer stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit. Whilst sourcing the part, put a standard socket timer on to the plug to stop the unit running all the time.
Dec 09, 2009 | Magic Chef Chest Freezer MCCF5WBX
Freezer stops and start
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Jun 03, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezers Logo
111 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
