Question about Microsoft Windows XP Professional for PC
Taskmanager & regedit
Taskmanager is not disabled, it comes and hides.
  • 31 Answers
When you press Ctrl + alt +delete, the task manager does not appear? Try right clicking on your desktop tool bar and clicking task manager: For regedit click Start > run and type regedit
Posted on Mar 28, 2008
How to enable control panael,taskmanager
Method 1 - Using the Group Policy Editor in Windows XP Professional
  1. Click Start, Run, type gpedit.msc and click OK.
  2. Under User Configuration, Click on the plus (+) next to Administrative Templates
  3. Click on the plus (+) next tSystem, then click on Ctrl+Alt+Delete Options
  4. Find Remove Task Manager in the right-hand pane and double click on it
  5. Choose the option "Not Configured" and click Ok.
  6. Close the Group Policy Window
Method 2: Change the Task Manager Option through the Run line
  1. Click on Start, Run and type the following command exactly and press Enter
REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /v DisableTaskMgr /t REG_DWORD /d 0 /f
Method 3: Change Task Manager through a Registry REG file
  1. Click on Start, Run, and type Notepad and press Enter
  2. Copy and paste the information between the dotted lines into Notepad and save it to your desktop as taskmanager.reg
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
3. Double click on the taskmanager.reg file to enter the information into the Windows registry
Method 4: Delete the restriction in the registry manually
  1. Click on Start, Run, and type REGEDIT and press Enter
  2. Navigate to the following branch
    HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ System
  3. In the right pane, find and delete the value named DisableTaskMgr
  4. Close the registry editor
For Control Panel
Start | Run | Type: gpedit.msc | OK |
Navigate to >>>
User Configuration\Administrative Templates\Control Panel\
Prohibit access to the Control Panel
[[Disables all Control Panel programs.]]
Jan 12, 2010 | Microsoft Windows XP Home Edition
Tip
Steps to Delete Files Used by another Program in windows
Hi,<br />Follow these steps to delete any files used by another program.<br />1. Right click the windows taskbar and open taskmanager.<br />2. Kill explorer.exe from the taskmanager.<br />3.Click file-&gt;open new task from the taskmanager window.<br />4. Type cmd.exe in the box and command window will come.<br />5. Go the directory of the file to be removed.<br />6. Delete the file using following command<br /> del fileName<br /><br />
on Jan 05, 2011 | Computers & Internet
How we will enable the task manager in windows xp
there are 2 ways..
1. just right click to you task bar (shown below) then click task manager.
20fd7c1.jpg 2. press ctrl alt del simultaneously, then click on task manager..
cheers!
Jul 11, 2009 | Microsoft Windows XP Professional SP2 Full...
Taskmanager disabled by your administrator
Click on start then run
Type gpedit.msc then ok
Click + on administrative templates
Click + on system
Click on CTRL ALT DEL options
over to the right double click on remove task manager
Click on disabled then apply then ok
You will now have back taskmanager
This is normaly caused by malware you should if you havent already run an anti malware scan.
Malware Bytes is an excelent example of a scanner and is located here: www.malwarebytes.org get the free trial version its great.
May 07, 2009 | Microsoft Windows XP Professional With...
My task manager has been disabled due to virus attack. help me
There is a registry hack to enable or disable Windows NT TaskManager. The same registry hack applies to Windows 2000 and Windows XP. Hive: HKEY_CURRENT_USER
Key: Software\Microsoft\Windows\CurrentVersion\Policies\System
Type: REG_DWORD
Value: 1=Enablethis key, that is DISABLE TaskManager
Value: 0=Disablethis key, that is Don't Disable, Enable TaskManager
As part of the enhanced management available in Windows 2000 and Windows XP, rather than risking a registry change, as an administrator you can enable or disable Windows 2000 Pro or Windows XP Pro's TaskManager using Group Policy Editor. This can be applied to the local policy. Note: if you are trying to override your organizations group policy, you can't. As soon as you re-authenticate to the domain, the domain or OU Group Policy will rewrite the registry setting. But if the TaskManager was accidently disabled or you need to control this item for a set of standalone boxes this is for you:
  • Click Start
  • Click Run
  • Enter gpedit.msc in the Open box and click OK
  • In the Group Policy settings window
    • Select User Configuration
    • Select Administrative Templates
    • Select System
    • Select Ctrl+Alt+Delete options
    • Select Remove Task Manager
    • Double-click the Remove Task Manager option
And as I mentioned above, since the policy is Remove Task Manager, by disabling the policy, you are enabling the Task Manager.
Mar 23, 2009 | Internet Grisoft AVG Security Full...
My taskmanager has been disabled by virus
Method 1 Click Start, Run and type this command exactly as given below: (better - Copy and paste)
Method 2 Download and run this REG fix and double-click it.
Method 3
  • Click Start, Run and type Regedit.exe
  • Navigate to the following branch:
  • In the right-pane, delete the value named DisableTaskMgr
  • Close Regedit.exe
Method 4: Using Group Policy Editor - for Windows XP Professional
  • Click Start, Run, type gpedit.msc and click OK.
  • Navigate to this branch:
User Configuration / Administrative Templates / System / Ctrl+Alt+Delete Options / Remove Task Manager
  • Double-click the Remove Task Manager option.
  • Set the policy to Not Configured.
Feb 12, 2009 | Computers & Internet
How to remove virus hijack.taskmanager?
Here are versions of a removal tool:
XP - http://www.scanforfree.com/download/hijack.taskmanager-remover.php
Vista - http://orderpage.paretologic.revenuewire.net/plav/download
And some knowledge about the virus:
Hijack.taskmanager is a malware hijacker generally installed on the system through corrupt video and media codec shareware and file-sharing p2p programs, e-mail attachments or via **** adult websites. Hijack.taskmanager can create random malvare records in system32 registry and overwhelm the desktop with **** popups and phony warning messages to threaten users to scan their pc. Hijack.taskmanager rojans can gather credit card, passwords and other sensitivel information and infect your Computer with additional malware.
Jan 25, 2009 | Computers & Internet
Taskmanager
use virus online scanner. you have viruses
May 05, 2008 | Microsoft Windows XP Professional
My task manger is disabled by the administrator
For Windows XP Home Edition use "The registry edit & For Windows XP Professional you still use the option I had suggested which is:
• Click Start
• Click Run
o Select User Configuration
o Select Administrative Templates
o Select System
o Select Ctrl+Alt+Delete options
o Select Remove Task Manager
o Double-click the Remove Task Manager option
I hope this Info has helped you.
or:
Click Start -> Run. Type in "regedit" (no quotes) and hit Enter.
Search for HKEY_CURRENT_USER -> Software \ Microsoft \ Windows \ CurrentVersion \ Policies \ System.
Look for: DisableTaskMgr. Click on REG_DWORD. Value: 1=Enable this key (disables TaskManager); Value: 0=Disable (actually enables TaskManager)
Close RegEdit
Reboot your machine.
Oct 17, 2007 | Sony VAIO Digital Studio PCV-RZ22G PC...
Microsoft Windows XP Professional for PC Logo
65 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
