Question about KitchenAid Refrigerators
KitchenAid KSSC42QM The divider between the fridge and freezer is warm to the touch and the fan on top keeps running. The freezer and fridge are still cold but I'm worried that something is going out.
    President:
  • 949 Answers
I do not think my first attempt to help you went through, if this is a duplicate response I am sorry. It sounds like your condenser is overheating, this could be due to the coils being very dirty or the fan that keeps them cool is not running. The motor you hear on top is most likely the compressor that does the cooling. Remove the grille on top and look at the coils (similar to a radiator in a car but smaller) there will be a fan behind them that will (should) be turning. If the coils are dirty use a vacuum and brush if you have one to clean very thoroughly. I have put together some instructions on how to do this but it is for bottom compressor models, but it might help, I have attached the link to the bottom of this reply.
If the motor is not running you can see if something is caught in the blades stopping it, if it is clear and not running you will need a new condenser fan motor.
I hope this helps, let me know if you have questions.
http://www.fixya.com/support/r4694132-hot_door_seal_rail_divider_strip_between
Posted on May 05, 2010
Wall dividing fridge from freezer is very hot to the touch
You either have obstructed coils (lots o dust) under the fridge or the fan that is supposed to draw air across them has ceased to work. Check the coils and clean as necessary, and check the fan. Maybe you will get lucky and find something caught in it. If the fan is not working, leave the back cover off the fridge and put a small window or box fan back there until you can get the fan replaced. The fan will keep the fridge running for you in the meantime.
Jun 29, 2010 | Refrigerators
The condenser fan is not running. I shut the fridge off because the divider between the fridge and freezer was so hot. When I turned the unit back on, the fan did run for a while. Does the fan need...
On your model it could be the fan part number 2206036 or the control board relay or both. I see your listing is a week old and unanswered and I would have be able to help you sooner if Fixya's server was working properly. Sorry if this has inconvenienced you, Sea Breeze
May 06, 2010 | KitchenAid KSSC42QM Side by Side...
My freezer temp registers 28 - 36, I cleaned out coils, I notice that there is a fan in the back bottom right side, not sure what should make that run. My Ice is slowly melting. I had the freezer setting...
That fan behind the refrig , is the fan that cools the compressor . It should be running any time the compressor runs . If not running , replace it . The center divider between the fridge and freezer ( front strip ) should be getting hot to the touch if the fan is not running .
Sep 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Problems with Whirlpool 21.0 cu. ft.
checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
Jun 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Divider strip between fridge and freezer is hot
First take the grill off at the bottom under the doors look at the grate under the frig That is your condenser it will probably be covered in dust clean it off the see if you can fill air blowing under the frig there is a fan under there that keeps that coil cool and it runs around the door to keep condensation from build around the doors if no air is blowing take the back panel behind the Frig and there should be a fan running if the compressor is running this will also cause the compressor to over heat and will not cool as well but it might just need to be cleaned Good luck
Apr 03, 2009 | KitchenAid KSRG22FK Side by Side...
Kitchenaid Refrigerator door gaskets are getting very warm.
When the center divider gets hot, it usually means that your condenser fan (the one that blows air across the coils under the fridge) is not working, or that the condenser coils are extremely dirty. Next time the fridge is running, see if there is any air blowing underneath. You probably need a new condenser fan.
Jan 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kitchenaid Side by side refrigerator/freezer
when is the last time you cleaned the condenser coils the areas you describe are supposed to be hot there is a loop there to keep the door gaskets dry but should not be too hot pull the fridge out check to see if the fan is running on the compressor then unplug the unit and clean the coils the only other thin that will make it super hot if there is a leak in the low side of the system and has drawn air in see if cleaning the coils fixes it first and we will go from there
Feb 13, 2008 | Refrigerators
Refrigerators Logo
187 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
