Question about Siemens SpeedStream Modem (4100) (SS4100)
2 router connected to a modem via splitter. is it ok?
  • 382 Answers
No, you will have problems, either cascade the routers into a subnet or bridge them.
Posted on May 05, 2010
Missing link between DSL Cable and D-Link Systems HD Media Router 1000 (DIR-657)
What is the Time Warner modem? Make, Model? If you have a Ethernet port RJ45 connect the wireless device via a ethernet cable. You may need a splitter if there is only one Ethernet RJ45 port. Example: http://www.amazon.com/StarTech-RJ45-Splitter-Cable-Adapter/dp/B00009XSZE
Apr 24, 2013 | D-Link Computers & Internet
Cant seem to get the spliter thing to work properly for internet and cable tv
One port on the splitter is the "input" port -- it connects to the cable wall-jack.
Two (or more) ports on the splitter are the "output" ports; connect one port to the cable-modem, and connect one port to your TV (or Digital TV Terminal).
Note that some OLD splitters are not "two-way" -- any signals going "out" from the cable-modem will not get "through" the splitter to the wall-jack. Be sure that you have a NEW "two-way" splitter.
Aug 18, 2011 | Computers & Internet
I hooked up everything right modem to router, router to computer. but i still cant get internet to my computer. if i hook my modem directly to the compiter it works fine but not through the router
Some ISPs (Internet Service Providers) limit you to *ONE* unique computer connected through the cable-modem (or DSL-modem).
Turn the cable-modem off.
Turn the router off.
Connect the cable-modem to the router, via an Ethernet cable to the 'WAN' port on the router.
Turn the cable-modem on.
Turn the router on.
Connect, via an Ethernet cable, from one of the 'LAN' ports on the router to your computer.
Restart your computer.
You should be OK.
If not, telephone your ISP, and get them to trouble-shoot from "their" end towards your end.
Sep 20, 2010 | Linksys Wireless-G WRT54G Router
My new LevelOne WBR 3600B router does not eyncronize
Hi, If you are using dsl line, then try to add SPLITTER or FILTER between wall jack and phone.
When you connect splitter you will have one input line and two output line, one is called voice which you connect to phone and the other is data which you connect to router.
you can use LAN cable to connect modem and computer. before you set the connection please remove all the connection from wall jack to computer, wait for 2 mins and then re connect, like this it will remove if any static charges stored. If you are able to see the DSL light is up and no more blinking, Then your problem is solved. Hope this information will help you
Nov 17, 2009 | Computers & Internet
Internet Resets When Phone Rings
Logon to your router and change the bandwith you're using you might be on the same bandwith as yor phone, so when you get a call on your phone, the wireless router will get interupted,
thats if your phone is wireless !
if it's a cable phone your splitter might be bad :D
hope this helped oh..
almost forgot
on how to acesses your router.
go to run dialog box in your start menu. then type in CMD to the box
then you'll get a DOS looking command prompt, Type in IPCONFIG
then look for Defualt gateway, looks somthing like this
192.164.1.1
tpye your defualt gateway into your http bar (the top bar you tpye www.lol.com in)
then you'll probably get a box with a logon name and password. the defualt for it is
admin
admin
or
admin
password
then after you've logged on you can look for the wirless tab and change the bandwith you're broadcasting on.
if you still cant acesses or cant find how to
go to portforward.com then lookup your model and it will show you what to do :]
Sep 04, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My netgear WGR614's ethhernet light is not shining
please give the connection directly to the modem. dont use the splitter. now u can fidn if the problem is in splitter or connection. also try a different wire. also try pinging your modem from command prompt. tell me what happens
Jul 27, 2009 | NetGear WGR614 Wireless Router
My linksys router keeps dropping connectivity to the internet
does your router and your landline phone is in one connection in with a splitter..
does connection failed whenever there's a call?
if so your splitter might be broken
or you must insert your phone line with the splitter, it might be in your connection set up..
or make sure your utp cable is stable and not in exposure area of people or pet where it might be touch or something..
hope this helps...
Jan 13, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I can't receive and send fax
The splitter the technician is referring to goes on the wall jack. One should have come with the "modem" installation package.
Take a regular telephone cord and plug one end into the splitter and the other into the line jack on the Fax/printer.
When your done you should have two phone cords connected to the splitter - one going to the "modem" and the other to the printer.
Nov 11, 2007 | Office Equipment & Supplies
Internet connection
Ok I have done it a little different sometimes... try this approach... First connect up the DSL Modem to the PC via Ethernet.. Configure the modem from the PC using the Connect to the Internet Wizard... enter all ya ISP details Logon, Password etc. Once this is going OK.. Disconnect the Modem... and then connect it up to the "Router" using the "Uplink" port and when connect ya Modem to the router... then connect another Ethernet cable from Router to same port on ya PC. Then simply use the network setup Wizard to set up an Internet Connection and connect up via ya router thru ya modem... generally works for me....
Aug 31, 2007 | Dell TrueMobile 1184 Wireless Broadband...
Siemens SpeedStream Modem (4100) (SS4100) Logo
196 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
