Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
What does SuD mean ON THE CONTROL PANEL
This is a HE3 machine
  • 5,911 Answers
This is a Suds Detect error code. The following link explains the error and some potential causes:
http://www.fixya.com/support/r3608687-sud_error
The number one cause of the error comes from using too much, or the wrong type of detergent. You are required to use High Efficiency (HE) detergent with these washers because the concentration is formulated for HE washers that use small amounts of water. Using the wrong type of detergent can also void any warranty you may have.
NOTE: HE detergent does not have a lot of suds, which often confuses consumers into thinking they aren't using enough detergent. With HE washers little to no suds if normal and preferred.
Secondary causes can come from something restricting the drainage system. Most notably, something lodged in the drain pump and/or drain hose(s). I've included a follow-on link that explains how to check the drain pump reservior if required.
Each one of these washers come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it from time to time to troubleshoot your washer.
Read through the information provided and let me know if you have any further questions. I hope this can help you.
Posted on May 05, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    What does 5ud mean on a elite he3
    I think the 5UD is SUD. It means excessive sudsing has been detected, and a suds routine has been started to reduce excessive suds. This routine will add time to the original cycle. I have had this on my display a couple of times when I guess I put too much HE soap in the machine.
    Jan 15, 2012 | Kenmore Washing Machines
    I have a kenmore he3 the erroe code says "sud" can
    SUDS LOCK (to much detergent detected during the wash cycle)
    he motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
    Potential Causes
    • If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
    • Check the drain hose and make sure it is not plugged or kinked.
    Dec 16, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Getting F02 error on Kenmore Elite HE3 washing machine............how do i fix problem?
    Hi
    Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
    • Check the electrical connections at the pump and make sure the pump is running.
    • Check the drain pump filter for foreign objects.
    • If the above does not correct the problem, replace the pump.
    There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap. Hope this helps... Please post back for more information.
    Daniel
    Nov 26, 2010 | Kenmore Washing Machines
    I have a kenmore elite he3 front loader; it gives me the "sud" code during a wash cycle. What could be the potential problem?
    either way too much soap or the wrong type,run a couple of washes,without clothes to purge excess soap and see if this clears up the sud code
    Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
    My He3 continues to stop mid cycle. Usually I see something like SUD or a P on the screen. If I push stop/cancel and then start again usually it will eventually get through the cycle. Sometimes I have to...
    The following link explains how to troubleshoot a "SUD" error on a Kenmore Elite HE3:
    First, verify you are using the CORRECT laundry detergent. If you are, make sure you are using the correct amount (some of these detergents are double (2X) and triple (3X) concentrated.
    Next, you may have an obstruction in the drain pump that is restricting water flow. Too much air detected in the draiange system can generate the error code. There is a follow-on link included that explains how to check the pump.
    These are the two MOST common causes of the problem you are experiencing. If you have any questions, or have continued problems, please post back and let me know. I hope this helps you.
    Jan 07, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    He3 elite kenmore- sUD and F21 error
    Hello there"
    Sud SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
    The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
    • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
    • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
    • Check/Clean Drain Pump Filter of foreign objects
    • Check Drain Pump
    • Check Pressure Switch
    • Check CCU
    Dec 25, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore elite HE3 front load washer won't drain or spin and displays sud and flashes FO2
    Hi there
    I have found this and i hope this gets you in the right direction. Merry X-mas and Happy New Year also.
    • Check Drain Pump
    • Check CCU
    Thank you for writing to Fix Ya.
    Best regards Richard
    Dec 15, 2009 | Washing Machines
    I have kenmore elite he3 and it is flashing f 02 and then it will flash sud. Water will not all drain out of it,
    HI. this code represents a Long Drain issue.
    If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
    NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
    Potential Causes
    • If the above does not correct the problem replace the pump
    Oct 27, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
    Probably something caught in pump. Remove lower panel if this one has it and you will see the pump. Loosen the round cover in middle to access clean-out.
    Nov 08, 2007 | Kenmore 46462 Front Load Washer
    Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
    60 people viewed this question
    Sal DeAngelo
    fordexpert
    Mike Carew
