Question about Toshiba MW27F51 27 in. TV/VCR/DVD Combo
VERTICAL HOLD NOT WORKING PICTURE TUBE HAS HORIZONTAL LINE
HOW TO FIX OR REPLACE VIDEO BOARD.
  • Toshiba Master
  • 12,061 Answers
OK below is a service manual to download, this is what engineers use to troubleshoot and repair.
http://elektrotanya.com/toshiba_mw27f51.pdf/download.html
Posted on May 05, 2010
I have a Panasonic TV CT-34WX50 every time I change channels
it sounds that have problem in the chroma board ( video board ) a small board that hooked up in the neck of the picture tube. if the color is greenish the cause is dead in red video driver transistor or open resistance. hope this can help good luck.
Jul 26, 2012 | Panasonic CT-34WX50 34" TV
My TV's video is out. A straight line goes horizontally along the screen. The sound is fine. It use to come and go, now it is gone for good. Does a tube need to be replace?
Hello.Theres a loose connection in your CRT board of your television.The problem is in vertical section maybe the vertical output IC is cold solder.Thats why harizontal lines appear in the screen of your TV.Your picture is good the problem is in the CRT board at the vertical section.
Jul 03, 2011 | Toshiba 27A45 27" TV
Picture go into a thin line.
You have a thin horizontal line in the center of the TV. You, in this case have vertical IC that has bad grounds. Resolder the vertical IC pins and check the capacitors in the immediate area and replace these caps as necessary. If you still have a horizontal line, you will have to replace the vertical IC. Find a TV tech or someone with electronic experience to do this for you. Should be reasonable to fix. Thanks for asking and Good Luck!
May 30, 2010 | Sanyo AVM-3659S 36" TV
Distored picture
Well, if your horizontal is off frequency and you have diagonal lines then there's no need to look at the Horiz Output Transistor or the Vertical section. You will have to use your scope to check the oscillator freq. and go from there.
Jan 14, 2010 | Toshiba 50H82 50" Rear Projection...
JVC AV-27730: horizontal bright line across screen in the
it could be an electrolytic capacitor or the vertical output I.C. in the vertical circuitry,if you remove the rear cover tap on the board in different places and see if the picture fills out or atleast jitters like it might fill out,then it could be just a cold solder joint,then remove the main board and resolder all joints and this should repair the condition you have
Nov 18, 2009 | JVC AV-27730 27" TV
Flatline!
the vertical drive ic that drives the yoke for vertical sweep has blown.
sometimes it is solder problems like sharp and toshiba had.
the part is 10$ the pc board will label it ,the yoke is the coil setup on the picture tube.if you follow the wiring half goes to the horizontal drive,and the others to the vertical section.the chip drives the coil directly.there are VERY high voltages in there ,even turned off. the pix tube cap on top is 30000v. like a stun gun.the horizontal drive 2000 volts and the main power supply 165 volts dc high current.you need a special setup to discharge the picture tube.
May 15, 2009 | Mitsubishi CK-35308 35" TV
Line across picture tube
It's a bad solder connection on the vertical IC.It will be mounted on the main board.It is vertical in length and will have thirteen pins..should be marked "LA7838" or similar.
Apr 04, 2009 | Emerson TS2587D 25" TV
Had the same problem with mine. The vertical hold chip broke loose from the solder,Resoldered it works fine. You will need a magnifying glass to see this on the bottom of the board.
Jan 13, 2009 | Sanyo DS31590 31" TV
Hitachi 51GWX Scrambled Picture
STK392-560 STKS convergence CHIPs Replace both of them.
Feb 24, 2008 | Hitachi 51GWX20B 51" Rear Projection...
No picture
gets white horizontal streaks for a split second, then back to no picture. i think sound will be alright. while horizontal streaks are called retace lines & is due to video section failure. please call skilled tech to fix it it is not a major problem & can be rectified. at your place without replacing much parts. your tube is ok. good luck
Sep 27, 2007 | Zenith SY2551S TV
Toshiba MW27F51 27 in. TV/VCR/DVD Combo Logo
720 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
