Question about Vulcan 36L Gas Kitchen Range
Hi, I'm considering converting my Vulcan Solitaire
Hi, I'm considering converting my Vulcan Monte Carlo gas oven from natural gas to LPG but am having trouble sourcing parts is there a website that deals in these parts?
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Coverting a Vulcan 260L commercial range to Propane
Yes you can convert to LP gas. go to this web site to get the parts.
http://www.vulcanhart.com/manuals/F-30536.pdf
Go to page 9 and look at parts # 57 - 60 that is the part you need to change. You need to know the sea level that you are at though so you get the right part.
Now if you go to page 8 you will find where it goes part # 53 thru 61
To order the parts go to this web site
http://www.vulcanhart.com/parts.cfm
If any ? please fill free to ask.
Posted on Dec 17, 2008
TheMobilian
  • 8220 Answers
SOURCE: Having just converted my Vulcan
The oven safety valve has to be cranked down for propane.themobilian_815.jpg
Get a good fitting wrench and tighten this spud down and open the air shutter on the burner.
This video shows how to tackle a crank down and flip type LP conversion whilst yours might be a bit more fancy it still must be adjusted like any other stove:
Posted on Jan 10, 2011
I need to change valve from LPG to Natural Gas how to disassemble front of oven
Are you converting a range from LP to natural? If that's the case, you don't change the gas valve. In the installation manual there will be detailed instructions on how to convert. Good luck!
Jan 29, 2016 | Kitchen Ranges
Why does Oven soot up during use?
Are you on propane (LPG) or natural gas? I would guess that you are on propane, and that your oven has not been converted over to LPG correctly. The regulator needs to be set up for LPG, and the oven gas orifaces need to be tightened down, and the air valves opened up. If you don't know what these terms mean, then you need to contact a professional, because you don't want to monkey around with gas!
Aug 31, 2014 | Kitchen Ranges
Having just converted my Vulcan Endurance G36L Range from Nat. Gas to LPG Using the following parts recommended by Vulcan : New 1/2 psi pressure regulator, 6 size 51 hood type top burner orifices,1 size...
Jan 10, 2011 | Vulcan G36L Gas Range
Converting fromTown Gas to LPG in gas cylinders
Hi
Thanks for using FixYa. If your range/oven doesn't seem to work at all, check these:
Fuse/circuit breaker
Check to see if power is getting to the range/oven. If even a light won’t turn on then check for a blown fuse or tripped circuit breaker.
Main wiring
Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Range/oven wiring
There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Ovens
I have a rangemaster 110 LPG Hob and double oven cooker. I will be moving to a mains gas area and would like to convert it to natural gas. Is this possible?
Hi, a complete shot in the dark as its a while since you posted - we have a mains gas rangemaster 110 and need an LPG one, do you still need to change or have you sorted it now? Cheers
Dec 04, 2009 | Rangemaster 110 (Gas) Kitchen Range
Can you convert any natural gas hobs to LPG?
They are convertible. Most come with converting parts attached to the interior of the range.
Feb 21, 2009 | Stoves 1200DFa Dual Fuel (Electric and...
CONVERT FROM NATURAL GAS TO PROPANE GAS
Pat, it is very important that all appliances that used natural are guaranteed to be LP Gas approved. Fact is natural gas uses about 1/4 oz. psi where Lp Gas uses 8lbs. to 13psi
This is critical that the person doing the work has experience in converting the two types to prevent fire or property damage. I hope I helped answer your question, let me know if this works out for you. Thanks, Sea Breeze
Feb 01, 2009 | Vulcan SG44D Gas Double Oven
Injectors for hobs convert from LPG to natural gas
try to call wat brand u have to buy a injector for convertion,big different the injector for LPG and the natural gas,the LPG injector is small hole & the natural is have big hole.
Nov 21, 2008 | Cooktops
Vulcan 36L Gas Kitchen Range Logo
Top Vulcan Kitchen Ranges Experts
Treefrog15
Treefrog15
Paul Carew
Are you a Vulcan Kitchen Range Expert? Answer questions, earn points and help others
