Question about Yamaha MCR-E150 CD Shelf System
Motor noise when cd or dvd is playing when volume is low the noice is louder then the music. when you press the unit it stops
  • 382 Answers
Ground potential issue, put a ground cheater on it and unplug all other electronic devices on the circuit.
Posted on May 05, 2010
My Dodge intrepid 2003 is making a clicking noice What's wrong with my car thanks
Turn signal turned on?
Radio turned on, but volume too low?
CD-player playing something?
Noise all the time, or only when the engine is running?
Noise all the time, or only when the car is moving?
Noise all the time, or only when you hit the brakes?
Feb 09, 2015 | Dodge Cars & Trucks
My Curtis dvd player 1046 won't play dvd's, it says its loading then it says bad disc
First, try playing a regular music CD and see if that works. Next step would be to get a laser lens cleaner disc and run that in the machine. They come in both CD and DVD styles. You most likely won't get a DVD version to work since it's not reading DVDs, but you might get lucky and get a CD version to work, thus the reason for trying a music CD in the player.
If the cleaning doesn't work, or you can't play a CD either, then something has most likely died. There are really only two things that could go wrong with a DVD player, either the spindle motor (spins the disc) dies, or the laser dies. Both are somewhat common problems on low-end electronics. They can be fixed, but with low-end units, like those made by Curtis, it would cost you less to toss it out and buy a new unit.
Apr 05, 2011 | Curtis Televison & Video
When I'm playing on my amp there is a strange noice coming out of my amp. At first I thought it was my guitar, but it is really my amp... does anyone know how to solve?
"A strange noise" does NOT give us much to go on...
Please note that relatively low volume digitizing noise often exists from teh digital effects processors... it should be well below the normal playing volume.
Aug 09, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Xbox makes noise playing discs
I know what you mean , some drives are LOUD .Try wraping it
with towels ,just kiding . I have recived alot of request to quite
these drives down , I am working on a sound insulator
that will wrap around the cd rom to knock 10-20db off
but i have to watch out for heat build up. Ill keep you posted.
Bobby.
I presume the unit works fine it's just loud, right?
Rob
Sep 16, 2009 | Microsoft Xbox 360 Console
Ilo DVDR05 Vibration and loud humming noise
i experienced that problem before.one cause is the cd itself.there cd's that are too thick so the motor has hard time rotating that makes vibrating sound.the other ,don't put something over your unit.the cover is touching the holder of the cd and makes a sound.just do the necessary things to be done like don't put something on top your unit.if not, then a manual analysis of the tech is the last option.
May 17, 2009 | iLO DVDR05 DVD Recorder
My lap top has stopped playing audio
Right click the volume control - select open - this will open a larger volume control showing the volumes for each type of sound. Make sure none of the sliders are muted or low.
Apr 20, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
How to play music cd's
Stop video playback first, then press CD MODE then press PLAY.
Dec 16, 2007 | Pioneer DV-C36 DVD Player
Whining noise
The problem i had was when i would play my tv. I had it hooked from my dish to the sony then the tv. When i played a dvd,cd or the tuner it didn't make that noise. It seems my video/audio 2 channel was going bad. I disconnected my rca jacks and used the optical audio connection. The noise stopped and i got a better quality sound.
hope this helps
Oct 16, 2007 | Sony DAV-FC8 System
Yamaha MCR-E150 CD Shelf System Logo
66 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
