Machine errroe service call 0070
When i copy any thing the will be running and after some time it will stop and shwow machine error service call 0070
    Novelist:
  • 142 Answers
Restart the computer,
Can you try reinstalling the driver, may be that will fix the issue for your machine
Posted on May 05, 2010
Status code 4174-0000-3080-0504-8007-000D
This is very simple: you seem to not have enough hard drive space for a system update that your console is trying to install.
Error 8007 0070 occurs when you install an update or buy content on...
(I've pasted some bullet points for you)
" Error 8007-0070 occurs when you install an update or buy content on Xbox 360
Problem
You may see the following error code and message when you try to update your Xbox 360 console or purchase content:
xxxx-xxxx-xxxx-xxxx-8007-0070
Note
The "x" characters in the error code vary.
This may mean that there's not enough space on your storage device (mostly likely the Xbox 360 hard disk) to install the update or the content.
Solution
A console update or content download may require significant hard disk space. If you don't have enough free space, you need to move or delete some items."
You can probably get around this by using a 32gb USB thumb drive and moving some of your content that's hogging up your console's space onto that thumb drive temporarily.
Heres the Xbox.com info to get you started about moving and deleting hdd space--which also has info about using a USB thumb drive, too. Copy move or delete Xbox saved games profiles and avatar items
Jul 21, 2014 | Microsoft Xbox 360 Console
Tip
Konica Minolta Copier service code C0070 C-0070
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the front door or toner door and remove the toner cartridge/bottle from the machine. Close the toner door and if needed open then close the front door to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
If the code comes back after the cartridge is re-installed then there is either a priblem with the cartridge or with the toner bottle drive.
Most of the time though the problem will be resolved by the outlined procedure.
on Jan 04, 2010 | Office Equipment & Supplies
Help me to reset error codes c0070 & cof32 on minolta bizhub 210
C-0070 is the toner bottle, remove it, power off the machine, then with the bottle out turn the machine on, let it go thought its routine when it ask for toner install it PROPERLY if the knub on the bottle dented damage in anyway replace do not use the damaged bottle. the C0F32 is the toner is not properly mixing in the the developer because it is not getting any toner see above, Might need to replace the developer also.
Jan 27, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Download Cannon resetter for error code 5B00 model MX416
FIRST STEP : ENTER SERVICE MODE
<Service mode operation procedures>
1) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release the
buttons). The COPY button lights in blue to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset buttons. (Each
time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately, Alarm in orange and COPY in blue, starting
with Alarm LED.)
4) When the COPY button lights in blue, press the Stop/Reset button 4 TIMES
SECOND STEP : DOWNLOAD THE FOLLOWING PROGRAM.
www.4shared.com/get/zc4OMn2_/Service_tool_v3400.html.
1. Run the program
2. Set the region according to your location, then klik set
3. klik set on the Ink Absorber Counter
4. Prepapre 1 sheet of paper.
THIRD STEP : TURN OFF YOUR PRINTER AND THEN TURN ON AGAIN.
FINISH
Sep 06, 2012 | Canon Office Equipment & Supplies
How to fix problem code 0070
C0070 indicates that the toner bottle is not rotating as it should.
Open the toner door and see if the "UP" label on the toner bottle is on top of the bottle. You should be able to see it as soon as you open the door. If it is not then turn the machine off then on again to reset the C0070 and try and get the bottle to it's home position.
If it is visable, remove the bottle carefully so as not to spill the toner. Set the bottle aside and close the toner door, turn off the machine for 10 seconds then turn it back on. Allow the machine to run for as long as it needs to and see if the code comes back. 1 of 3 things should happen. 1) The machine will warm up as normal and come to the "ready to copy" state and you can make a copy. 2) The machine will run for quite some time, then shut down and say replenish toner.
3) The C0070 comes back even with the bottle removed. In this instance you may need a service technician as there is a drive problem with the bottle rotation system.
If 1 or 2 are true then try re-installing the toner cartridge if and only if all machine noise/running has stopped. Then run copies and see if the code comes back. If it does then you most likely have stripped the toner bottle drive gear and it will have to be replaced.
Good Luck and Thank You for using Fixya.
Sep 23, 2010 | Minolta DiALTA Di350 Laser Printer
MACHINE SHOWING THE 0070 CODE PROBLEM
If the code comes back after the cartridge is re-installed then there is either a problem with the cartridge or with the toner bottle drive.
Jun 30, 2010 | Minolta EP4000/5000 CS/PRO Copier
Error E061 & 0070
rewire your corona and change your grid if the error still presis change your drum
Oct 04, 2008 | Canon CLC 1120 Color Copier
Error 0070
I don't see this error in the book. Are you sure of the model CLC-1120 )?
Jan 29, 2008 | Canon CLC 1120 Color Copier
Error E061 & 0070
grid bias at upeer limit
Dec 19, 2007 | Canon CLC 1120 Color Copier
Waste ink absorber -mp500
Service mode operation procedures 1) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release the buttons. The COPY LED lights in green to indicate that a function is selectable.) 2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.) 3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset buttons. (Each time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately, Alarm in orange and COPY in green, starting with Alarm LED.) 4) When the COPY button lights in green, press the Stop/Reset button 4 times. (Each time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately, Alarm in orange and COPY in green, starting with Alarm LED.) 5) Press the ON/OFF button 2 times. You're good to go! Bear in mind that if the ink absorber is full then you risk getting ink everywhere! Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 31, 2007 | Canon Pixma MP500 All-In-One InkJet...
78 people viewed this question
jasbo
jasbo
