Question about Brother ML-100 Typewriter
Need to clean the platen
We need to clean the rollers under the platen and the platen as labels have gotten stuck on them. Some typewriters you can remove the platen to get to these rollers but we can't seem to be able to do that with the ML 100. Do you have any suggestions as to how we can get these sticky labels off?
  • Anonymous Mar 31, 2014
    SL560 how to remove label stuck on the platen
  • 168 Answers
IF you can't get the platen roller out, then what you can do is get a cleaner called " GOO GONE". Take a rag or paper towel, and pour some of the goo gone on the rag where the labels are located. IMPORTANT PART: You want enough Goo Gone on the rag so you can saturate the label. I have even CAREFULLY poured some Goo Gone right from the container onto the label.
Just don't go crazy with the Goo Gone.... You do not want to pour sooooo much onto the platen roller where it drips down it the frame of the machine and possibly onto the main board.
REMEMBER.... Just enough to saturate the label.
After the label is saturated.... WAIT AT LEAST 3 minutes. I usually wait closer to 5 minutes, and then you will notice that the label can be easily pulled away from the platen.
After all of the labels are removed, go over the entire platen with the Rag with Goo gone, and then go over it again with a clean dry rag.
I hope this works for you as well as it has worked for my customers.
Good luck.
Mac =)
Posted on Mar 27, 2008
Gx 6750 carriage daisy brogham
If you can remove the platen, roller, you may find a label stuck on the deflector. Remove the label from the deflector. Make sure the deflector is installed properly.
Nov 05, 2013 | Brother ML-100 Typewriter
How do I take off a label that is stuck on the metal strip under the roller?
Hi:
Trying to disassemble the typewriter to remove the platen (roller) will most likely be too difficult to do.
Try this instead. Pour some rubbing alcohol on a piece of paper and try feeding that into the typewriter
As the alcohol loosens the label then try pushing it out with a flexible piece of plastic like a credit card or even a piece of cardboard..
Good Luck
Andrew
Feb 22, 2011 | Brother SX-4000 Typewriter
Need to disassemble the unit to get at a sticker that is lodged under the platen/roller. Anybody know how to do this on a Brother GX-6750?
Hi!
This is a common problem when typing address labels.
There are no instructions on how to do it, but one should never roll the sheet with labels back in order to take it out.
To remove the sheet with unused labels always roll it out to the front. That is, feed it through.
Please don't try to remove the label using any type of a sharp object. This will only damage the feed rolls and score the platen.
Yes, I have done it many times.
First you need to remove the top half of the cover.
Then you need to remove the platen to get access to where the label is stuck.
You'll need a medium Philips screwdriver and a Hex wrench.
I don't remember the size, but there is a multy-wrench set from Canadian Tire has the right size.
Please feel free to contact me. :)
Feb 08, 2011 | Brother GX-6750 Typewriter
How do I take apart my Brother typewriter to remove a label stuck to the metal bar where the paper feeds in?
I wish I had one in front of me, but I don't. Brother used two ways of holding the Platen (big black roller in place. Open the top cover and look at the frame where the platen is held. You will likely see plastic clips holding the axial that runs through the platen (85% of brother machines have clips), or you will see that the axial runs directly through the frame. If you see clips just squeeze the tabs and lift up. Note which side has the gear, so that it is reinstalled the same way. If you don't have clips you will need to loosen the Allen screws holding the knob to the platen roller, and the roller will lift right out. If the label left any of the rollers sticky they must be completely cleaned before reassembly, Goo-Gone is a good product to remove gummy labels.
Best of luck, Ron
Jan 06, 2011 | Brother ML-100 Typewriter
In typing a label, it got stuck on the roller and the daisy wheel. The only wat to remove the label was to remove the roller. I did that and replaced the roller. Now the daisy wheel is only printing part...
The platen (roller) is not fully seated in the side frames check to be sure the latches are lined up then press firmly on both ends of the platen it should snap into place.
DickyO
Dec 22, 2009 | Lexmark Wheelwriter 15 Series II...
Label stuck under typewriter platen/roller of Adler Royal
Roll a new piece of paper the best you can. Dribble a little paint thinner on the paper, letting it run down under the roller. The thinner will disolve the adhesive on the label. After a couple minutes, you should be able to roll out the paper and the laber with no problem.
Aug 28, 2009 | Office Equipment & Supplies
Remove platen on Swintec 8011 typewriter
I can't remember which models have which features, but some Swintecs have pop out plantens, and some don't. If it is pop out, you will find a plastic V clip in the frame of the typewriter through which the platen shaft passes on both sides of the typewriter and platen. Pay close attention to which side the gear of the platen is situated before removing to make sure you put it back on the same side of the typewriter. Squeeze the V clips and pull the platen up and out. When re-installing, make sure the metal paper table is in correctly by aligning the fingers on each side into their mounting guides, or you will have paper jams, paper feed trouble, and other issues. You can clean the labels out with something that will not leave an oily residue on the paper table, paper feed rollers, or the platen. Re-install the platen by aligning the V clips to the frame on each side, and press them down until they snap into place.
Mar 23, 2009 | Office Equipment & Supplies
Remove stuck label
THIS IS COMMON FAULT WITH PEOPLE WHO USE LABELS ON TYPEWRITERS. U MUST NEVER TURN THEM BACKWARDS OR U WILL GET ONE STUCK IN MACHINE. THE ONLY WAY TO GET IT OUT IS TO REMOVE PLATEN AND CLEAN THE JAMMED LABEL FROM THE FEED. AND ON SMITH CORONA MACHINES THIS IS NOT EASY TO DO ONESELF.
Mar 18, 2009 | Smith Corona Wordsmith 200 Typewriter
Brother ML-100 Typewriter Logo
233 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
