Question about Whirlpool Dryers
DRUM TURNS BUT NO HEAT - Whirlpool Dryers
    President:
  • 1,382 Answers
Hi,Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Posted on May 05, 2010
Drum turns and turns. only burns the kernals doesn't pop them
If the drum is turning, then it should work. Are you putting enough oil in the pot? Make sure you let it heat the oil for a little bit before adding the popcorn. If you dont have enough oil or heat it will not heat the kernals properly and burn them. You just need enough to cover the bottom of the pot an 1/8 inch so.
Sep 22, 2010 | Gold Medal Kitchen Appliances - Others
DRUM TURNS THERE IS NO HEAT
Check out my tips and tricks for gas dryer heating problems. Click on my username and scroll down til you find it listed on my profile.
May 16, 2010 | GE DBXR463GB Gas Dryer
Dryer drum turns, no heat, replaced thermal limiter
Your model which we call the 417, is not usually easy to work on. The heating element is located behind the dryer drum. The drum has to be removed to change the element. There is a lot involved but given the cost of a stack unit the element and labor may be worth it.
Feb 17, 2010 | Dryers
Frigidaire model FEE332ESO dryer drum turns but no heat
Your problem is probably thermostats and not fuses.
They look like flying saucers and should click when you push in the metal discs
Nov 07, 2009 | Washing Machines
Dryer drum turns but no heat. Checked fuses and
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
879hftg
Sep 27, 2009 | GE Profile Harmony DPGT750EC Electric...
Kenmore electric dryer 8662100 drum turns, no heat
you have probably lost one leg of your power supply feed 120volts+120volts=240volts,your motor will operate on 120volts, but the element won't,also if you have 240volts the neutral wire to the element can burn off w/heat and age
Aug 18, 2009 | Kenmore 84152 Electric Dryer
New Dryer, drum turns but no heat.
Check your breaker. Reset it.
Apr 22, 2009 | Dryers
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Kenmore gas dryer that turns but does not heat up
No heat at all? does the top of the machine heat up, but not the drum? could be your drum seal is damaged or slipped off.
If the firebox doesn't light up, could be your igniter, the unit's safety switch, thermocouple, or regulator; Your Gas Company may provide a service that would check it for you... some do.
Jan 02, 2009 | Kenmore 74602 Gas Dryer
Electric dryer - drum turns but no heat
If it has a conventional electro/mechaniacal timer, then the timer is faulty, as it should advance, unless of course it has a time delay function, if it has, make sure it is off.
This probably explains why it is not heating.
Plz rate this solution.Thanks.
Dec 26, 2008 | Dryers
Dryers Logo
43 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
