Question about Hand Tools
What standard wrench replaces a 25 mm wrench - Hand Tools
  • 1,606 Answers
That is just under 1 inch. 25 mm is 0.98 inches. 25.4 is 1 inch.
I'd use a 1 inch and hope it isn't too tight. If you had some real rare wrenches like a 63/64th that is very close.
Posted on May 05, 2010
Testimonial: "solved the problem very well. thanks a lot"
2006 grand caravan starter diagram and size bolts needed for the starter
To work on your vehicles, you need a basic set of wrenches and sockets, standard and metric sizes. To buy one wrench or one socket, just isn't feasible, in my opinion.
Try 15 mm
Dec 09, 2016 | 2006 Dodge Grand Caravan
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
1 Answer What do you torque the intake manifold bolts to
If it is a 13 millimeter wrench use about 25 to 28 ft/lbs, if it is 14 mm wrench use 30 to 34 ft/lbs
Oct 30, 2015 | Cars & Trucks
What size caliper bolt in a 2009 Hyundai Elantra?
12 mm ,14,mm wrench or socket that to remove the caliper 17 mm wrench or socket for the bolt holding the brake pad braket
Mar 14, 2015 | Hyundai Cars & Trucks
Replace fan belts
a few metric open end wrenches in most cases there is nothing bigger than a 21 mm so if you have 8 mm to 17 mm wrench set your set
Nov 22, 2013 | Toyota Land Cruiser Cars & Trucks
Toshiba 32D46 - Need to know weight in order to determine whether tv stand will support it safely.
Hello
Your Toshiba 32D46 model TVs weight and diamensons are
Width: 29-9/16 in. (751 mm)
Height: 25-15/16 in. (658.5 mm)
Depth: 21-3/4 in. (552 mm)
114.7 lbs. (52.0 kg)
OK
Jan 02, 2011 | Toshiba 32D46 32" TV
I need to replace the abs sensor on a 1995 Chevy
No way are they 14.5 mm. Try an SAE socket instead of metric. I think you will find that a 9/16 is the correct size.
Oct 05, 2009 | 1995 Chevrolet Cargo
Printing a full page 'background' (design) with no margins
No. The official minimum print margins are as follows
print margin specifications
Top (leading edge)
Bottom (trailing edge)1
Left
Right
Sheet Paper
U.S. letter
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
U.S. legal
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
U.S. executive
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
ISO A4
.07 in. (1.8
.46 in. (11.7
.13 in. (3.4
.13 in. (3.4
mm)
mm)
mm)
mm)
ISO A5
.07 in. (1.8
.46 in. (11.7
.13 in. (3.4
.13 in. (3.4
mm)
mm)
mm)
mm)
Sep 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Wrench size of master cylinder brake line fittings 96 Taurus w/pb
First and foremost, you will want to find and use a tubing wrench as oppossed to a standard wrench. It may require a 16 mm
Bill
Nov 19, 2008 | 1996 Ford Taurus
Hand Tools Logo
50 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Dan Apthorp
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
