Question about Salter 3007 Aquatronic Digital Scale
My Salter Model 3007 Electronic Scale displays 8888 when I press tyhe on Button and settles down to ee after a few seconds. How do I get it to display the weight properly?
SOURCE: I have lost my instructions
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
Posted on Jun 21, 2009
evista_win
  • 10 Answers
SOURCE: my salter 1004SSDR kitchen scale won't show any
Your salter scale has a 15 year warranty. I would call the customer service number 1-866-843-3905 and ask them why it won't zero to weigh anything. They may replace your product.
Posted on Sep 10, 2009
  • 10865 Answers
SOURCE: I own the Salter Stainless steel electronic
yes. here is the link to the company http://salter-scales.com/ just click on the link and then enter your country. then you will see a place for parts or to contact them.
Posted on Mar 25, 2010
Testimonial: "Thank you! Wow, didn't expect a reply so quickly. Appreciate your help."
SOURCE: Kitchen scale, Salter, model 2006: change batteries
The 1 part just slides off.
Posted on Jun 28, 2010
SOURCE: I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Posted on Aug 29, 2010
I have a Salter 9007 bathroom scale. It stopped working so I bought replacement lithium batteries and installed them
Do you still have the manual with the troubleshooting section in it? It looks like this is an overload condiiton or an indicator that something is not right. The manual can help you to sort this out.
Mar 01, 2017 | Salter Health & Beauty
Is my scale calibrated. When I turn it on it first shows 8888 7/8, then it 0/0g
Take a ten pound bag of sugar and calibrate the scale to read 10 pounds.
Oct 30, 2014 | Salter 3007 Aquatronic Digital Scale
My Salter Model 2001 kitchen scale, shows an 'ee' on the screen. This error code is not listed in the manual. Any suggestions?
"EE" means that the scale has been overloaded. Try placing a small weight (i.e. 250g block of butter) on the scale and then turning the scale off and then on again with the small weight still on the scale. What this does is to try and re-calibrate the scale. If this doesn't work then I am pretty certain that the scales will need to be replaced. The scales in question do have a 15 year guarantee and you can try contacting Salter Housewares directly if you have your proof of purchase.
EE showing on screen
Sep 12, 2014 | Salter 2001 electronic kitchen scale
I have the Salter Scales model 2040, it is currently sent to oz, do you know how to change to grams as there is only 1 button. thanks
I just had a play with mine as I wanted to change the weight mode too.
The solution is this:
While the machine is OFF, press and hold the button for about 5-10 seconds.
The display will go from 8888 to show the weight measurement (lb oz) at the top of the display.
Press the button to select the weight you want.
You should be able to continue with your baking :o)
Hope this helps
Oct 09, 2010 | Salter 2001 electronic kitchen scale
My Salter Electronic scale (3007) got soaked and is giving incorrect / unstable readings. I am trying to take it apart ASAP to dry the board, contacts, etc. but cannot work out how to detach the weighing...
The weighing pad mates with a circular metal plate underneath and needs to be rotated clockwise to unclip from the metal plate. Peel back the lower right corner of the instruction label on the bottom. This reveals a hole through which a philips head screwdriver needs to be inserted to loosen a screw which then allows the weighing pad to be rotated. The screw only needs to be loosened, not removed.
Sep 02, 2010 | Salter 3007 Aquatronic Digital Scale
I have a Salter 307 kitchen scale. Are there any instructions for disassembling this unit? Removed 6 + 1 screws and I still cannot open the unit. Please help!!
How to open up the Salter 3007 Aquatronic Digital Scale:
1. Look for a hole (covered by a label) on the bottom of the device, not far from the L-R centre line, and about 1-3/4" from the front. Peel back the label and use a small cross-head screwdriver to loosen the screw that can be seen though the hole (needs about one turn, no need to remove it). Place the scale upright, and rotate the weighing pad slightly in a clockwise direction. This will disengage the tabs on the plastic pad which hold it to a metal base, so that it can be lifted off. 2. Remove the six screws recessed around the bottom of the scale. 3. Place the scale upright and gently "snap" apart the top and bottom shells (catches molded into the left and right ends). Be *** VERY CAREFUL *** when doing this as the display is held in place on a plastic bridge by the upper shell. When this is removed the display is loose except for a flexible plastic printed connector strip (which links it to the circuit board). It is *** all too easy for this strip to break away at one end or the other ***.
Apr 01, 2010 | Salter 3007 Aquatronic Digital Scale
E appearing on display of Salter kitchen scale
i have the same problem- did you manage to fix it??
Mar 31, 2009 | Salter 2001 electronic kitchen scale
I have lost my instructions for my Salter glass bathroom scales 9103. I have a EE on the digital mode what does this mean and what can I do to fix it so the correct weight shows
Jan 26, 2009 | Salter Stainless Steel Electronic Bathroom...
Salter 3007 Aquatronic Digital Scale Logo
176 people viewed this question
Top Salter Health & Beauty Experts
traccie
Level 1 Expert
ray gallant
solver2010
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
