Question about Vacuums
I would like to have 12 R 15 watts of outpower in my cb.I want to do it by myself.I will mod. my own equipment.
  • efgartorres1 May 05, 2010
    Sorry!I just bougth my radio and I herd something about it.Now, i know that is illegal.Thanks and good luck!!!
    President:
  • 1,851 Answers
Ok - I can't recommend you do this because technically it is illegal. The reason there is a limiter is the law makes the manufacturer put it on there.
I can tell you - there are schematics out there for educational purposes. However you do not give the make model and or s.n for your unit. Each one is different as your bypassing the limiter. Of course you will want to be CB model specific.
CLICK HERE for some Outlaw CB peeps - they will set you right -
Please VOTE me up it cost you nothing and can make me little more $$I would like to have - 774f560.jpg
Posted on May 05, 2010
I want a vacuum cleaner , how does 20volts Compare to 1250 watts
You need to understand what you are asking. One is the Maximum Draw (20 Amp) which is quite Stout in the power usage. There are better "EFFICIENCY" Vacuum cleaners that use less power. What you should be asking yourself is what is a GOOD VACUUM compared to a GREAT VACUUM and what Vacuum will do its job and last. Then you have to take into consideration that if you do not take care of your Equipment, you can burn it up prematurely. SILVER KING/RAINBOW/KERBY are High end vacuum that you are going to pay well over $1000 for. You can go to Walmart and buy their High End vacuum for less than $200.... Your Call
May 04, 2017 | Vacuums
What is the main difference between the basic dyson v6 and v8 vacuum?
Hello, this is Ava with Think Crucial.
The main difference between the V6 and V8 Dyson models is the mprovements in power and run time of the unit. The Dyson V6 has the V6 motor that pumps out 24 air watts in normal mode. In max mode that number goes up to 100 air watts. While the Dyson V8 comes equipped with the latest V8 digital motor that produces almost 20% more power than the V6 motor. It has the same 2-tier radial cyclones that capture fine dust and allergens. A post-motor HEPA filter keeps those allergens inside the bin. There is also the Bin improvement as Dyson was able to increase the capacity to 0.14 gallons for Dyson V8. This is around 0.03 gallons bigger than the V6.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Oct 22, 2016 | Dyson Vacuums
What is 700a shop vac motor size
Craftsman 17765 canister vacuum cleaner is known for its assortment of power tools especially when it comes to cleaning jobs. It is designed to give you an easier, more effective cleaning. This vacuum cleaner delivers a high capacity reservoir, power and the versatility to swap easily between tasks. Craftsman wet/dry vaccums soaks even drosp of water on the floor with one of their 16 gallon wet/dry vacuum. It is also equipped with utility nozzle, extension wands, and dust bag that makes the cleaning process easier. The extension wands can clean the hard to reach areas like cupboards, corners, and bends. It has a large gallon tank that includes convenient drain port for easy emptying when the job is done.
Number of Tools:
Attachment Type:
Brush
Details and Capabilities
Cord Length:
Tank / Bag Capacity:
12 Gallons
Weight:
Hose Reach:
Cleaning Areas:
Car
Electricity
Horsepower:
5 HP
Voltage:
110 - 120 V AC
Power Consumption:
1210 Watts
Jul 09, 2014 | Craftsman 17765 Canister Wet/Dry Vacuum
Aquamark hand held mod.am680 not steaming why
hi there did you find a solution i have the same problem thanks
Mar 01, 2013 | McCulloch MC1246 Handheld Steam Cleaner
It came with a american plug and when we put a converter to australian plug on it it only shows 220w instead of 240 which is what we have in australia. Don't want to plug it in and it blow up on me.
I think you mean 220 volts, versus 220 watts. The difference between 220 & 240 volt equipment is usually just a matter of nomenclature -- no significant difference in terms of operating the equipment.
The vacuum is 110 / 120 volt since it has an "American" plug on it. If the plug is swapped for an "Australian" plug (or adapted) and plugged into the wall, the vacuum will be connected to 220 volts -- this would destroy the motor.
You would need a transformer to step down the Australian voltage to 110 / 120 volts. If you plug it in without a transformer, it will surely burn up the motor.
More info, let me know.
Charlie
Mar 30, 2011 | Vacuums
A 40 W fluorescent lamp gives out more light than a 4o W filament bulb.explain whether the fluorescent lamp is actually using electrical energy at the same rate as the filament bulb??
The lamps are both using 40 watts of energy, but the fluorescent lamp gives more lumens (visible light measurement) than the incandescent.
Fluorescent gives at least 5000 lumens for 100 watts.
Incandescent gives 1750 lumens for 100 watts.
You can see that if you had a 100 watt incandescent, it would be 1750 and you would only need 35 watts of flourescent.
Gary
Feb 19, 2011 | Vacuums
Pushing the power switch does not turn on the vacuum.
The only fuse is in the plug if this blow then it might trip the CB out
Aug 01, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Bissell - ProHeat Mod. # 9200 05240C - No
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
hjghkl
Jun 07, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Wattage for Kirby Sentria G10D
The conversion of Amps to Watts is governed by the equation
Watts = Amps x Volts
For example 1 amp @ 110 volts = 110 watts
your case 7 amp @ 120 volts = 840 watts
unless you are running it at 230v but I don't think you can
I would look for one rated for Volt-Amps instead of watts
It's best to round up to be safe add 40 - 60 watts
Don
Apr 25, 2009 | Kirby Ultimate G Bagged Upright Vacuum
About kirby carpet extracters
The heritage 2 pulls 5.5 amps or 660 watts in hose mode and 4.5 amps or 540 watts in carpet mode.
Volts to Watts
The conversion of Volts to Watts is governed by the equation Watts = Amps x Volts
Mar 24, 2009 | Kirby Heritage II Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
