Samsung PPM50H3Q 50 in. HDTV-Ready Plasma will not power on.
I have a Samsung PPM50H3Q 50 in. HDTV-Ready Plasma Television. It will not power up. When I push the power button the lad blinks red. Any ideas?
  • mboyce4 May 05, 2010
    I have 2 units, the one doesn't power up, the other has a red line horizontal through the screen. I can swap parts to try and fix the one that doesn't power up. The led blinks 9 times
  • mboyce4 May 08, 2010
    I swapped power supplies and it works great! Thanks for your help!
    Scholar:
  • 70 Answers
Could be a power supply failure or a control issue. I would take the unit to a repair shop and see if they can provide you with an estimate. You could try to buy a replacement power board and install it on your own if you are mechanically inclined.
http://www.shopjimmy.com/samsung-bn94-00494u-power-supply-unit.htm
Posted on May 05, 2010
  • Dan  Larson
    Dan Larson May 05, 2010
    you can take the power boards from the one with the bad screen and swap them into the one that does not turn on. The process usually involves the removal of screws to gain access to the boards. I recommend having the service manual close by when you do the work. the manual should contain a dis assembly procedure.
S5053 50 inch plasma HD samsung . Picture went completely black only on audio
If you shut the television off and unplug for 12hrs this will reset the microprocessor. If this doesn't help, then the power supply has at least one bad capacitor. These are not expensive to replace if you are able to do the work yourself. Most television repair companies don't bother replacing anything at the component level. It's quicker for them to replace the power supply. Hopefully this will be of some help.
Dec 23, 2010 | Samsung FPT5084 50 in. Plasma HDTV
My Samsung FPT5084 50 in. HDTV Plasma Television was working fine and now it won't power up when I try to turn it on. Is it possibly a blown fuse.
It's probably a blown fuse on the power supply circuit board, or if it has a circuit breaker maybe it can be reset.
Nov 11, 2010 | Samsung FPT5084 50 in. Plasma HDTV
Problem for Philips 50PF9631D 50 in. HDTV-Ready Plasma Television I have a pwer power problem, LED flashes 7 times and will only go on on a few occasions. How easy is it to replace the...
Before replacing the capacitors check the video from this link.
The capacitors can be found here or radio shack might have them. The value should be 3300uF/25v 105 degrees radial if they fit in the space provided by design. Make sure to install them with the correct polarity.
Let me know if you require further assistance.
Aug 22, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
RCA MM52110 tv
I had a repairman out to look at mine today. He said it was the high voltage protecter kicking off the TV as soon as you turned it on. $400 to $600. to repair.
I love this TV but guess I'll go shopping for another plasma. I have one Plasma TV in the bedroom 50" Samsung (top of the line) it doesn't have as good of a picture as my old RCA.
Jan 31, 2008 | RCA MM52110 52" Rear Projection HDTV-Ready...
PPM50H3Q
I replaced the main power board... got a multimeter from HomeDepot to test where the power was failing. Found the part @ partstrain.com for under $300. If I had taken it to a repair shop it would have cost $300 just to open the back cover & then parts & labor.
Hope this helps.
Nov 25, 2007 | Samsung PPM50H2 50 in. Plasma Television
Maxent MX-50X3 50 in. HDTV-Ready Plasma
Yes I had this problem. Unplug the power cord for 1 min then plug it back in. The tv will reset and the buttons then work again.
Sep 26, 2007 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Televison & Video Logo
256 people viewed this question
Top Televison & Video Experts
Electro Med Services...
