Question about Whirlpool GS5SHAXN Side by Side Refrigerator
Water leaks from freezer onto top shelves on my kenmore coldspot model 106.78202890. where can i find a manual to unclog the drain?
  • Whirlpool Master
  • 1,606 Answers
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or Copper solid wire , ( a ground wire or fence post tie ) 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on May 05, 2010
    President:
  • 949 Answers
There is no manual per say for this unit that would show service procedures. I have put together a generic guide to cleaning a defrost drain and put the link at the bottom of this message. Here is a parts breakdown showing what you will have to take apart to get to the drain.
You will have to take out the bottom shelf 25 then the screws holding 28 in and remove it. Then the screws holding the back panel (16) off.
If you have an ice maker in there that will have to come out. After all this you will see the ice and follow the instructions on the link below. I hope this helps.
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
Water is leaking into teferagerator, seemingly from the freezer compartment. It is a Kenmore Coldspot model 106.72132101 type 21 TFA.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 01, 2011 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Kenmore coldspot model 106: top freezer leaks water slowly into botton refrigerator. how do I repair it?
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
Dec 19, 2010 | Kenmore Refrigerators
My Kenmore coldspot 71182100 which is almost 9 years old just started leaking water from the freezer onto the shelves in the fridge. I just cleaned out the freezer and got the ice out. There was not...
I have a Kenmore Coldspot Model #69207990 and have the same problem. Water from the freezer drains into the refridgerator onto the shelves and sheets of ice form. A repairman pointed out that the tube leading down from the freezer onto the drain pan was frozen. By pouring hot water down the tube, he reopened this drain line. Problem solved for six months and the drain line froze again. My question is how to stop this drain line from freezing up again.
Dec 16, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
I have a 10 yo kenmore coldspot refrigerator. We
I had the same problem. The water resovior in the back of the refrigerator had a pin hole in it.
Jun 30, 2009 | Kenmore Refrigerators
Water is leaking on the top shelves in my kenmore refriderator water is leaking on the top shelves in my kenmore I have water leaking onto the top shelf of our Kenmore refrigerator. I believe it goes into...
During the defrost cycle heaters inside the walls of the freezer turn on to melt the frost. The melted frost "water" is supposed to drain into a pan under the fridge where it will evaporate. I think the drain line from the freezer to this pan may be blocked. I'd also check the seal on the freezer door. If it's not sealing well it lets a lot of moisture into the freezer which means more water during the defrost cycle. I'd also recommend checking to make sure the ice maker is not leaking.
May 31, 2009 | Kenmore 64802 Top Freezer Refrigerator
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Defroster leaks
you have a cloged evap. drain. the rf is defrosting properly but with the drain be clogged the water has to go somewhere which is generally in the crisper draws on top and bottom models. two way to clear up this issue. turn rf OFF for at least 48 to 72 hrs. to allow the drain to de-ice or take matters into your own hands and take the back panel off of the freezer and using boiling hot water pour it down the evap. drain tube until it flows like you just flushed a tiolet
Jun 01, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore 63712
if there is water on the top shelves in the fresh food section you may have a drain problem when the freezer defrosts. one other possibility is there is a air leak somewhere could be a bad door seal. when warm air enters it will cause condensation and water will drip on the shelves.I suspect it might be comming from the freezer though. a easy way to check is to remove the back panel in the freezer and check for ice in the drain pan. if there is a blockage use a hair drier to melt the ice and hot water to clear the drain. let me know if this helped you solve your problem Good luck
Aug 02, 2007 | Kenmore 63712 Top Freezer Refrigerator
Whirlpool GS5SHAXN Side by Side Refrigerator Logo
596 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
