Question about Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player
I have an after market pioneer car stereo and not sure how to hook the red,yellow and blue with the stripe, to the wire harness with orange lummination and orange dimmer negative,yellow batt. and blue i belive is egnition the speaker wires are easy so thy are hooked up
    Scholar:
  • 70 Answers
Red is usually ignition switched power from the fuse box and the yellow is continuous power to the deck. blue with the stripe is usually a voltage output from the deck to control the on/off of an external amplifier. If you hook the deck up and the memory stations do not save after vehicle on/off cycle of the ignition swap the yellow and the red wire and they should work. One is power all the time to allow the deck to store memory and the other is the main power to the unit.
Posted on May 05, 2010
Wiring on pioneer car stereo
Red is ignition....yellow is battery or memory....black is ground....blue or blue w/white stripe is power ant or remote for amp...orange is illumination (may not need)...white/white with stripe is front left i believe...grey/grey w/stripoe is front right...purples and greens are rear
Jun 18, 2016 | Pioneer Car Audio & Video
Im hooking up a pioneer car stero in a 2001 chevy cavalier. I purchased a chevy plug n play wire harness, and I hooked up all the wires (color coded) and plug it in, but no power, I have A ground and a...
your adapter should be color coded to the pioneer wiring, orange, red and yellow are power feeds for igntion, 12 key and lighting, veryify voltage on the orange and red wiring to the radion with key on, the yellow is for radio lighting with parking or headlight operation, some adapaters may not have all the wiring and you may have to splice around the adapter.
Jan 03, 2018 | Car Audio & Video
Im trying to install an after market radio(pioneer) in my 83 impala. i know i hooked up speakers correctly. But i have a yellow black and grey wire on car wires and yellow black and red on harness. I know...
Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Here you go. This is listed for an 85 to 89 Impala, but should still hold true.
May 30, 2011 | Pioneer Car Audio & Video
I have a 1990 Ford murcuery and i just got a 2010 Pioneer super tuner 3 D 2200UB but i cant seem to get any power to the DEH and i was wondersing if you could help me solve this problem?
Did you use a factory wire harness in conjunction with the after market wires included with the Pioneer? You might have a bad ground. The basics behind the factory should look like this: Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Red/Black Illumination n/a Dimmer Blue/Red Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Orange/Green Left Front (-) Black/White Right Front (+) White/Green Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Green Left Rear (-) Pink/Blue Right Rear (+) Pink/Blue Right Rear (-) Green/Orange
The best thing to do is to use an after market harness if you didn't before. Just in case you aren't sure, the Pioneer wires are color coded to the after market wires. You wire the two harnesses together, and then plug that into the factory wires. This would help on the chance that you decided later on to sell the car, but want to keep the Pioneer until. I hope this helps, and let me know what you come up with.
Apr 12, 2011 | Car Audio & Video
Installing Jvc KD-R610 into 02 Nissan Frontier, where I have removed older JVC. Using old harness, but blue wire labels do not match... One says "amp power" and other says "power...
well it sound like your ground wire is not connected the properly way this wire is black make sure
the other 3 are connect right are Yellow is constant power ,Red is acc.ingnition,Blue is the remote.
that would complite your conection done.
Dec 27, 2010 | JVC AM FM CD DET FACE CAR STEREO
Replace factory stereo with after market for 98 Dodge Ram 2500
Right Rear Spkr (-) Blue w/ Orange Stripe
Right Front Spkr (-) Blue w/ Red Stripe
Right Rear Spkr (+) Blue w/ White Stripe
Right Front Spkr (+) Purple
+12 Volt Ignition Wire Lite Purple w/ White Stripe
+12 Volt Battery Wire Pink
Left Front Spkr (-) Brown w/ Red Stripe
Left Rear Spkr (-) Brown w/ Blue Stripe
Left Front Spkr (+) Green
Left Rear Spkr (+) Brown w/ Yellow Stripe
ground would have to be connected directly to vehicle's frame
Jun 05, 2010 | Car Audio & Video
Red,yellow and blue with stripe hooks to what into harness
some decks have a solid blue for power antenna and blue with white stripe for amp turn on. if you have neither a power antenna or amplifier, i would not worry about connecting those two wires. do makes sure they are capped off and have no bare wires showing, as they are hot when the stereo is turned on.
May 05, 2010 | Pioneer DEH-P2900MP CD Receiver...
Wiring a after market radio to an existing Ford.
This may help.... it's for a 2004 and I believe it should be close if not right on...
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
May 24, 2009 | Pioneer Car Audio & Video
Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player Logo
156 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
