Venturer PLV 1615 15 inch LCD TV
TV doesn't come on. Standby light off. Fuse ok.
The problem is in the power supply. If I had a schematic I could fix it myself. Can anyone tell me where I can get a schematic? I sent several emails to Venturer support but they don't reply. Benjamin
Posted on Mar 27, 2008
Polaroid 3700 lcd
GOT SAME PROBLEM NOW IS THERE A FUSE WHERE POWER CORD PLUGS INTO THE SET ON THE BACK MINE HAS A GLASS FUSE NEXT TO THE PRONGS THAT COME FROM TV YOU HAVE TO USE A SCREW DRIVER TO POP IT OUT SHOWS A PIC OF IT IF YOU DON'T SEE IT DON'T TRY TO POP IT OUT
Feb 24, 2013 | Polaroid FLM-3732 Television
03 chevy venture rt.front parking light&turn light don't work replace bulb&socket
The rapid flashing occurs because of the light problem. If the 20A PARK LP fuse in the underhood fuse block is OK, the front marker lamps and the park lights should turn on when you set the headlamp switch to PARK. If the 10A T/SIG fuse in the instrument panel fuse block is OK, and the ignition switch is on, moving the turn signal multi-function switch to signal a right or left turn should cause the turn signals to flash. If this doesn't happen, check for a missing ground connection to the socket you replaced and check to be sure the replacement lamp was not forced into the socket backwards (it happens).
Sep 17, 2012 | 2003 Chevrolet Venture Passanger
No picture or sound
how about a light indicator, is there a light at the front panel of the tv?. if none check the power supply first, which may have blown fuse at the primary of the power supply.
Jul 18, 2012 | Sanyo PLV-55WM1 55" HDTV-Ready LCD TV
MY tv is not getting turned on Manually/ Remotely..!
First if now total dead it has a fuse inside to look at.
Jun 14, 2012 | Venturer 19 inch flat screen TV
Tv will not power on!!!
most likely will need a new power supply, google it
Jan 01, 2010 | LG 32LG30 32 in. LCD HDTV
Ilo 32 inch LCD tv will not turn on
replace bad cap in the power supply the top will be put up
Aug 28, 2009 | iLO 3200 32 in. LCD Television
I have a venturer tv, no sound?
I found an audio amp IC and indicated on the top of the chips is CHMC S0723. It should have cross reference can be found in ECG semi-conductor guide or NTE ICs manual. The pin#12 is the Vcc in 12VDC, pin#6 & #7 are audio input L&R.
Other solution is just hook an RCA cord right into its audio out of this set to your receiver and it will works.
Feb 09, 2009 | Venturer PLV36220S1 22 in. LCD TV
Sanyo Television PLV-55WHD1
i heard same popping sound and my power button flashed red and will not turn back on.?
Sep 15, 2008 | Sanyo PLV-55WM1 55" HDTV-Ready LCD TV
Televison & Video Logo
311 people viewed this question
Top Televison & Video Experts
