Question about ASUS P4S800D-X Motherboard
Cmos problem I did try but always the same error message!!!!
  • 33 Answers
If you didn't get to the CMOS setup page then it will always show the same error. You have to press it many times (not just press it once) Or maybe it is not the DEL key. If I were you I will keep pressing DEL, F2, F10 or F12 a few time (using both hands). The timing here is crucial because the system only allow a few seconds to go to the CMOS setup menu.
Posted on Mar 26, 2008
Why do date and time keep setting to default?
Are you sure you replaced the CMOS battery with a fresh one? Did you install it backwards (the plus side should be UP). I've only seen a bad CMOS battery cause that problem. I would try one you know is new and check the installation.
Good luck.
Dec 27, 2011 | EliteGroup ECS H61H2M2 Intel H61 Sandy...
Tip
How to verify that the CMOS battery needs to replace
<p>The CMOS battery is named after the Complementary Metal Oxide Semiconductor power. The CMOS has the current date and time functions for desktop and laptop computers. It allows the computer to automatically adjust the time, even on computers that are disconnected for long time. When a computer no longer has the date and time and forget it on every boot, the CMOS battery probably needs replacing. Some computers have messages when the battery is weak, while others just lose the current date and time after each shutdown.<br /> <p>Time & Date Errors<span> </span><br /> <p><span> </span><br /> <p>1. Turn on the computer. Look in the task bar at the bottom right. Make sure the date and time is set correctly. Double-click the time and click the up or down arrow to switch to the correct time. Click on the arrow next to month to change the month. Click "OK" when finished.<br /> <p><br /> <p>2. Turn off the computer. Wait 3 to 5 minutes and start the machine.<br /> <p><br /> <p>3. Look on the taskbar to see if time was lost and said a strange date January 1, 2000. Replace the CMOS battery, if this is the case.<br /> <p><br /> <p>CMOS Error Message<br /> <p>1. Look for error messages like "CMOS checksum error", "CMOS Read Error" or "CMOS battery failure" when you start your computer. These errors are caused in the machines shut down for several months or when the CMOS must be replaced.<br /> <p><br /> <p>2. Let the computer on for 24 hours. Restart the computer and find the error.<br /> <p><br /> <p>3. Change the CMOS as the return error.<br />
on Jun 21, 2011 | Computers & Internet
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
WHEN BOOTING IT ALways stops with notice "Checksum Error"
replace the cmos battery into new one that is specified the exact volt..hope this helpful...
Oct 25, 2009 | Abit KR7A-133R Motherboard
Error message
Open Your system and there is a Battery which looks like a Coin. that is CMOS Battery (CR2032) Change that battery and then Reboot your system and try go to BIOS menu with DEL , F11 , F1 or F2. Either of these Buttons can Work.
This will resolve your issue
Nov 26, 2008 | Computers & Internet
Always display bad cmos setup
have you checked the jumper next to the cmos battery? check if its good not broken and also try and upgrade your firmware. visit your motherboard's manafacture for the firmware upgrade.
Nov 13, 2008 | Asrock P4I45GV R5 Motherboard
T23 BIOS error code #05
are you getting a date & time error ?. you could always try just resetting the bios.... remove the bios battery AND the battery itself for about five minutes or so. install it all again and boot up.
Robert
Aug 27, 2008 | IBM ThinkPad T23 Notebook
I have a HP 8595c computer. I put a DVD in and it froze. I restarted the computer and now it won't boot up proberly. I get this message. "Non-System disk or disk error Replace and strike any key...
Non-System Disk or Disk Error results when the Basic Input/Output System (BIOS) cannot find the boot sector or the master boot record is missing or damaged; i.e. the device does not have bootable media. The BIOS searches drives in the order usually specified in the CMOS Setup. This order is often, but not always, A: (floppy drive), C: (first partition on the hard disk)… The error will occur during startup if the CMOS is set so the BIOS seeks the floppy drive first and a non-bootable (or blank) floppy is in (was left in) the floppy drive. Other causes include:
No bootable partition on a hard disk drive
  • A defective hard disk drive
  • The CMOS drive settings (parameters) are not correct for the boot device
  • Defective floppy
  • Defective floppy drive
  • A virus
  • Jul 21, 2008 | Computers & Internet
    Press F4
    svjyrat
    "always message to press F4 at the time of star up". this problem happen when CMOS detect any error. is also happen if CMOS battery fail (Chack sum error).
    to solve this problem at first check CMOS battery (it voltage less then 3V or not) if it bad then replace it. u can buy this battery form any computer accessories shope.
    or if u not connect floppy drive, and controller enable. if u desable floppy drive contoller from CMOS setup (in intel mother board is show BIOS setup) then this problem solved.
    Jul 03, 2008 | Intel Motherboard
    Always f2
    If I understand correctly your saying when you exit the cmos, id doesn't save your changes. Make sure when you exit you select the option to save and exit. If that doesn't work, your cmos battery is dead. Look in the mobo manual to find out what replacement battery you need.
    Harris
    May 01, 2008 | Asrock P4I45GV R5 Motherboard
    ASUS P4S800D-X Motherboard Logo
    46 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
