Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag model BCRE955 electric range the top of stove works but can't turn oven on or broiler. Can't use the timer button. Is it the circuit board. How much to replace
F1 MESSAGE
Posted on Sep 23, 2011
Where are fuses in Kenmore stove C970
Stoves generally do not have internal fuses they rely on the house circuit breaker to protect the circuit. Some stoves have what is called a thermal fuse. These can trip when the oven or broiler has overheated. Some are located on the back panel and some are located on the top panel under the top of the stove. Since this is a smooth top model there may be one on the back panel. More than likely there is a problem with the oven control circuit possibly in the electronic control. The relays can go bad on the control and the oven will not work.
Oct 11, 2014 | Kenmore Electric Smooth Top Stove
My maytag range broiler works and stove top but not oven what could be wrong
Likely causes are;
Oven element faulty - needs to be tested;
Burnt wiring at oven element terminals - visual inspection;
The electronic timer is set to auto. mode - must be in manual mode.
Feb 18, 2011 | Maytag MER5775Q Electric Kitchen Range
Maytag Gas Range broiler burner not working
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
May 21, 2010 | Maytag MER5775Q Electric Kitchen Range
Kenmore electric range: oven & broiler will not work.
All your oven features are controlled by the Electronic Range Control (ERC) board. This is your clock/timer assembly. Unfortunately, most do not have fuses and are not serviceable. You will probably need to replace the board. The following link explains how:
http://www.fixya.com/support/r3727366-replacing_control_kitchen_range
Replacement circuit boards can be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. For the model number you have listed, the part number for a new board is 316207511.
NOTE: The overlay, which is the plastic template with the numbers and letters preprinted on it, does not come with the new board. It has to be purchased seperately. However, if the current overly is still in good shape, it can be peeled off the old circuit board and reused. The part number (if required) is 316220841.
If you have questions about this repair, please post back and let me know. I hope this helps you.
Jan 21, 2010 | Kitchen Ranges
My oven and stove top in inoperative. the clock,
If everything checks out fine, and you have no wires grounding out, then the issue is the control or circuit board( same thing).
Jan 02, 2010 | Frigidaire FEF366 Electric Kitchen Range
I'm having trouble with the lower heating element not heating on my GE Electric Range. Its probably 10 + years old. The broiler element heats. Will I be able to replace the element or circuit board? ...
Most of the time it the heating element.
(recheck your model number)
Here is a good source for replacement part
http://www.partstore.com/Content/CategoryPages/Kitchen-Cooktops.aspx
Or directly to GE
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=LANDINGPAGE&AppliancePart=Cooking%20Products
Dec 24, 2009 | General Electric Stove/Oven/Range Chrome...
Looking for Manual for Maytag Range BCRE955
This is easy simply call Maytag and provide them with the model number (usually located in storage drawer or broiler drawer) the and serial number. They will email it directly to you within minutes free of charge! The phone number is 1-800-688-99900
Sep 24, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Oven will not work unless range is lit
You probably have a neutral return that is open. By turning on the stove top you are completing the path of return for the bake element. Work back from the element (unplug the oven first!!!) and check continuity back to the plug. Again, make sure you unplug the darn thing from the AC outlet!
Mar 12, 2009 | Maytag MER5775Q Electric Kitchen Range
Maytag ceran top stove
MY CERAN SURFACE TOP HAS CRACKED ON MAYTAG MODEL BCRE955. CAN IT BE REPLACED AND ARE THE TOPS AVAILABLE?
Feb 10, 2008 | Maytag MER5775Q Electric Kitchen Range
Maytag gemini gas oven
you have to allow the broiler to warm up. give it a few minutes (maybe even ten) eventually the broiler will come on.
Nov 12, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
163 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
