Question about Dometic Rooftop RV Air Conditioner
The fan on my Dometic AC wont turn on.
I have two Dometic Penguin AC units (model 630516321) and the fan on one of them won't work. Any ideas on how to fix it would be greatly appreciated. I have noticed that if I leave it in the fan only mode it will occassionally start up all by itself (sometimes in the middle of the night). If it does run- then the compressor seems to work okay until the next time I try to use it. The compressor tries to come on but won't stay on if the fan doesn't come on. The other AC (the one I've not used that often) works well. Please help.
  • ssmith_pac May 05, 2010
    How do I obtain a new fan motor and then replace it?
    Genius:
  • 1,354 Answers
Dear sir
better go to technition becoz your A/C is on roof
it has a fan bilten on A/C
Posted on May 05, 2010
    Genius:
  • 1,400 Answers
Hello
Your going to need to replace that fan motor.Whaat happens is the compressor will come on and the coil will freeze, with no air moving across it,so the compressor will shut down.
You will do damage to the compressor.Which is alot more expensive then the fan motor.
Dometic penguin air ac
either the fan motor or heat strip
Apr 02, 2014 | Dometic Rooftop RV Air Conditioner
I have a dometic penguin ac rooftop unit. Model no. 630215.421. Fan blows Compressor does not kick on. Fan blows just no cold air. If put on auto and go up or down in temperature On the thermostat The fan...
Bad run capacitor or bad compressor. If you hear an occasional click from the compressor try a new run cap and then a hard start kit. Otherwise it's more economical to purchase a new unit.
Sep 25, 2013 | Dometic Rooftop RV Air Conditioner
AS I SAID BEFORE my problem is not ac connection its the 2 blue ,,2yellow and one red and one black..where to connection these color wires..coming out from the roof top unit. My unit is Dometic Penguin...
Unfortunately I have no access to any previous information you received from other experts, but I will tell you that without knowing which ceiling assembly/control box, thermostat etc., that you are using, the most I can do is tell you this.
Blue wire is for the compressor circuit.
Black wire is for high fan .
Yellow wire is not used, unless for heat pump circuit reversing valve.
Red wire is for low fan.
White is the common AC connection.
Green/yellow striped is for ground to chassis.
Jun 08, 2011 | Dometic Rooftop RV Air Conditioner
My Duo-therm Brisk-Air by Dometic rv ac wont cool.(The fan runs )
Usually just listening closely will give you a rough idea where to look for problem. When you have the fan on and switch to cool, (with temperature turned down low obviously) do you hear any type of "moaning" sounds from AC unit, or see lights in RV dim slightly indicating that compressor is trying to engage? Is the breaker tripping when compressor tries to engage? Do you hear a "click" from AC unit when switched to cool? If none of that happens, then I'd start thinking thermostat, or compressor relay. Normally if it's a faulty capacitor, the compressor will try to engage but will make a "moaning sound" and usually trip the breaker due to excess current draw. Someone experience in electrical should be able to test relays etc, but whoever does work on it, should be aware that those capacitors, as well as hydro in general are very dangerous to work with. The ("zap",- Shock) that you can experience from a capacitor or hydro, can be fatal.
May 27, 2010 | Dometic Rooftop RV Air Conditioner
I have a 13500 btu ac dometic penguin model on pan that is old and would like to replace with 15000 btu ac of any other manufacturer or another dometic what are my options ..I do not have ducts and do not...
Your choices are another Dometic or a Coleman
I prefer the Coleman But the amount of extra cooling you will get by stepping up to a 15K unit will probability not be worth the added cost
Mar 11, 2010 | Dometic Rooftop RV Air Conditioner
Penguin 13500 ac short cycling
UNITS THEMOSTAT IS BAD REPLACE THERMOSTAT IF DONT SOLVE PROBLEM MAKE SURE UNIT IS NOT FREEZING UP AND BOUNCING OFF A "FREEZE STAT" CASING COMPRESSOR TO SHORT CYCLE
Jul 31, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
112 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
