Question about SanDisk 4 GB Memory Stick PRO Duo Card with Rezo 15 Camera Pouch (MS4GBRZO1
Just got a SanDisk 4gb SDHC card. Put it in my camera took some pics and my card reader doesn't work with it. Works with other cards (not SanDisks) The only way it will work is if I plug my USB cable directly to camera, but that is VERY slow.
    Brigadier General:
  • 3,006 Answers
Upgrade your card reader.
SDHC cards are a very different animal under the skin to a standard SD card and so they're not back compatible with plain SD card readers (although SD cards can be used in SDHC devices).
Posted on May 07, 2010
Will a sandisk 4gb sdhc card work in a dx7590 easy share
The DX7590 works with MMC and SD cards, which max out at 2GB. It will not work with higher-capacity SDHC cards.
Jan 08, 2013 | Kodak EasyShare DX7590 Digital Camera
Sigma 4in1 card reader not working
Try a different / all other USB ports on the computer, and if possible, a different computer if no USB port on your computer works with it. If it still doesn't see the drive, the drive is probably not working. If it does see the device, but is asking for drivers, provide a disk with drivers that came with the reader - or check the Sigma web site for drivers that work with you OS (Windows, Mac, etc.), download and install / extract.
If it sees the device, but doesn't see the memory card, the reader may not recognize the newer, larger capacity memory cards. SD cards are smaller than 4GB in capacity, and SDHC cards are 4GB and larger. Make sure that if you're trying to read an SDHC card that the reader SPECIFICALLY says it works with SDHC cards. Most SD readers can NOT be upgraded with firmware to be able to read SDHC cards - a new SDHC reader is required.
Jan 30, 2012 | Cameras
It will not format a 4gb SanDisk SD card
Your 4GB card is actually an SDHC card. The DX6490 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to go with SD cards 2GB and smaller.
Nov 28, 2010 | Kodak EasyShare DX6490 Digital Camera
SanDisk ImageMate 12in1 cannot read SCHC 4GB or higher cards
Correct!!!! This card reader cannot address cards that are higher then 3gig and cannot read sdhc cards. Most older readers will not be able to read the HC type card, and by older I mean if its 6 months old or more. To read these cards you need to purchase a new card reader. I know, My camera uses 4gig cards and I was unable to access the pics until I bought a new reader..
Dec 02, 2009 | Computers & Internet
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Feb 02, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
Will Sandisk yltra II 4gb card work with Nikon D40?
I assume you mean Sandisk Ultra..and the answer is Yes it will work fine.
A good choice card also..
Just beware that some computers will need the SDHC reader.
For example my SDHC cards can be read in XP without the reader but my Vista machines need the reader.
Good luck and happy shooting :-)
Nov 04, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
Hi - You will need to get an SDHC reader and then try the following procedure.
You can either plug in you camera to the PC as it should appear as a “Removable Drive” or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/prwindetail.html
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
Sep 10, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Feb 16, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
Dec 13, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
SanDisk 4 GB Memory Stick PRO Duo Card with Rezo 15 Camera Pouch (MS4GBRZO1 Logo
141 people viewed this question
Top SanDisk Cameras Experts
Henry
Nikki  Mclean
Nikki Mclean
Are you a SanDisk Camera Expert? Answer questions, earn points and help others
