Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Remote control not working
The remote control has lost contact. It has new batteries and the LED surface is clear of obstacles.
  • 10,594 Answers
It could be either remote is bad or remote sensor located at tv front is not working.
You can test remote with help of any digital camera, watch remote front through camera and press few buttons on remote, you will see infra red led blinking at remote front, that means remote is good and working. Remote sensor in tv is defective and need to be replaced by qualified tech.
If infra red led of remote does not blink pressing any button while watching through digital camera then problem is remote, buy new one to solve the issue.
Thanks.
Posted on May 05, 2010
Remote stoped working
Hi, Check and replace batteries with new ones. Make sure there is no obstacle between the remote and TV. If remote still won't work replace with new or compatible remote. Good luck.
May 03, 2015 | Televison & Video
Tip
Remote not working. Remotes can be saved.
Ok, your remote is not working and you have replaced the batteries and it still does not want to work for the device that you are trying to control. I have listed a few tips below that may be of some help to you; these are all considering you have the original remote that shipped with the unit that you are controlling.
Sometimes the chip inside can become overloaded with commands and lock up the processor.
The remote can be saved.
1. Remove the batteries and press every button on the remote control and then install new, not the batteries you took out, but new batteries and see if that works.
2. If step one does not work, then you can remove the batteries and unfold a small paper clip and bend it into a U shape and use it to touch the contacts on both ends of the battery contacts together and clear the memory.
3. If your remote is still not working then it is time to test the remote control, if you have a camcorder or a digital camera, and a cell phone will work. Point the remote at the device and press any button, you should be able to see the IR (Infrared LED) lighting up on the display.
If after all of these procedures are followed and you still do not have command of the device that you need to control. You still have more options.
Either replace the remote control with a new or compatible one, I use 1-800-remotes, www.remotes.com.
Or have the device that you are trying to control diagnosed by a technician and see if the remote IR receiver in the unit is damaged. Unfortunately there is no simple way to test the remote receiver, and 90% of the time the remote will fix the problem.
I hope that this helps you with your remote issues and as always, Thank you for using FixYa.
asnowman
on Mar 16, 2010 | Audio Players & Recorders
MB QUART WIRED REMOTE WRC-S1 NOT WORKING
test the LED hit any key viewing with digital or cell digital. see the diagram THE LED must be TURN ON, if not open the remote and clean the keypads contacts from dirty+corrosion+bad contacts+clean the contacts battery too and replace by new ones.Try it again.
God bless you
Jul 14, 2013 | MB Quart WRC-S1 Round Wired Remote Control
Remote key control won't work on my 2004 95
use camera digital or webcam cell, touch any key from remote control and the LED must be ON, see the picture attached. Otherwsie open the r.control clean with some solver for to clean contacts from dust, corrosion, etc, clean the contacts battery too, and replace by new ones.
Jul 03, 2013 | Televison & Video
Logik L32LCD11 remote not working!
use this simple test see the video.the led coming with the r.control must be light to the digital camera. If the LED is not lighting. Open the remote control, and clean, replace battery, and resolder any cold solder in the r. control. clean the contacts battery.
May 22, 2013 | Televison & Video
My remote control has stopped working ,i have tried new batteries but it not work
good day... well you said you already replace w/ new battery..try to check the batt. terminals if still intact...if you can disassemble it to clearly check the wires.. if still good I suggest that you replace the infra red LED...goodluck
Feb 12, 2011 | Abt Television 1745 Remote Control
Won't change channels. Batteries are fine.
The remote does not operate your component?
  • You must put the remote in the correct mode by pressing the corresponding component key (TV, VCR•DVD, SAT·CBL) so the remote knows which
    component you want to operate.
  • Remove any obstacles between the remote and the component. Make sure to aim the remote at the IR sensor on the component.
  • Make sure the batteries are fresh and are properly installed. (See Battery Installation on page 3 of the User Manual). Replace the batteries with two new AAA batteries, if necessary. Reprogramming may be required.
  • Reset the remote. Remove the batteries, then press and hold the number 1 key on the remote for several seconds to reset the microprocessor inside the remote. Release the number 1 key, reinstall the batteries, and press the ON·OFF key. If the LED indicator light turns on, reprogram the remote and try again. If it doesn't light up, replace the batteries with new ones.
This and other details can find in the troubleshooting-the-rca-rcr350-universal-remote-control
I hope this help to solve it (remember to rate this answer) Good luck,
Oct 02, 2010 | RCA RCR350 Remote Control
Cannot turn on by remote controller. Want to
Ok, here is my little spin on remote controls.
Sometimes they can be overloaded with commands and lock up the processor that is inside the unit.
3. Test the remote control, if you have a camcorder or a digital camera, and a cell phone will work. Point the remote at the device and press any button, you should be able to see the IR (Infrared LED) lighting up on the display.
Or have the device that you are trying to control diagnosed by a technician and see if the remote IR receiver in the unit has gone bad.
asnowman
Mar 16, 2010 | Onkyo TX-DS777
Remote and manually not working ,batteries ok,power on ok ,no obstacles blocking remote,turned off power worked for short time, stopped again.nec high definition receiver,model nhd-2000
one of the batteries was not making proper contact and was loose,had to gently stretch spring contact out to make it stay in place .kept dislodging itself,so far so good.thanks
Dec 06, 2009 | One For All URC-5705 Remote Control
Remote wont operate sound dock.
hi , To check wether the remote is outputting a infra red signal when a button is pressed try viewing the little LED at the top of the remote through your mobile phones camera , these little cameras pick up a fuller spectrum of light and you should see if flickering. IF you dont then check the batterys/. then the connectors for acid errosion from previous leaking batterys./pull the remote apart and with a pencil rubber clean the contacts on the surface of the circuit board/.The rubber membrain that has the buttons on wash it with warm soapy water , dry thouroughly.last test --go to mapplins and buy a replacement infra red led and change that? , see haow you go whith these tips and report back
Mar 20, 2009 | Bose RC-18S Remote Control
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
689 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
