Question about Mintek DTV-233 23 in. TV/DVD Combo
Mintek TV/DVD Combo
DVD will not play it spins around and then ejects the DVD. I tried doing what the manual says but still does not work. Help! My email address is cmims420@gmail.com.
  • Anonymous Sep 22, 2008
    My DVD won't work, it keeps ejecting the dvd
  • 4,102 Answers
Hi have you tried using a dvd lense cleaner these are cheap to buy and will clean the laser lense this usually solves the problem but if not then the chances are your going to need to get the laser replaced.
Posted on Mar 26, 2008
How to reset mintek dtv-265-d telivision after replacing power supply
MINTEK DTV-373-D OWNER'S MANUAL Pdf Download.
www.manualslib.com > ... > TV DVD Combo > DTV-373-D
View and Download Mintek DTV-373-D owner's manual online. Mintek DTV-373-D OWNER'S MANUAL 37''. DTV-373-D TV DVD Combo pdf manual download.
Mintek DTV-265-D 26 in. LCD TV Factory reset - Questions ...
www.fixya.com > ... > Mintek > Mintek DTV-265-D 26 in. LCD TV
...factory reset to this TV. It will make all to factory settings. There are two types ofreset to TVs. The first is simple to do; a Hard Reset. The other is somewhat ...
Mintek reset button location Combination Televisions ... - Fixya
Dec 07, 2015 | Mintek DTV-263 26 in. LCD Television
I have a Polaroid TV/DVD combo. It took the DVD in, won't play it nor will it eject now. How do I get the DVD back?
Tries the tv unplug/replug the tv back for about an hour later for the tv power to reset itself.At this time u will able to eject the DVD disc out.Don't tries to used the tv intergrated DVD player anymore.The tv intergrated DVD player laser head and the spin motor for the dvd disc spinner it is defective now.Buy a portable cheap or a moderate unit of a outer DVD player and hook up to the tv AV input.Play it through the tv input video 1,2,3 u should have a DVD player capatablities again.
Nov 30, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
My dvd got stuck in the dvd player. ther may be another dvd in there. how do i get it out?/
Power the DVD player down and press the eject button. Try to remove the DVD carefully, without forcing it.
Mar 05, 2011 | Mintek DTV-233 23 in. TV/DVD Combo
Have a Toshiba hlv87 tv/dvd combo that will not eject a good dvd
I've had the same problem. I called Toshiba support and all they could say was to unplug it. Since I already had done that, they were going to send a service person over for a couple hundred bucks (which they get a cut of) to take it apart. Haa
Aug 02, 2010 | Mintek LCD TV Progressive Scan DVD Player
Dvd is stuck in player - won't play and won't eject
open cabinet of your dvd you will find out a lock open that pick up your disk during proseeing that is stucked
Mar 05, 2010 | Mintek DTV-263 26 in. TV/DVD Combo
Stuck DVD
Have you tried unplugging the set for a few minutes, then plug it in.
Hopefully it will reset and eject the disk.
If it is actually jambed (wedged in) this probably won't work.
Sep 12, 2008 | Mintek DTV-263 26 in. TV/DVD Combo
Toshiba tv/dvd combo
is there a tiny little hole you can insert a paperclip into around the front of the cd.
if so use a large one if you have it , insert and press hard to eject.
if not then you will need help.
even if you get it out the eject motor belt is likely slipped or broken.
Apr 28, 2008 | Mintek DTV-233 23 in. TV/DVD Combo
DVD keeps ejecting
I have the same problem.I can only get the recorded dvd's to play on the cheap dvd players like apex and such.
Mar 08, 2008 | Mintek DTV-323 32 in. LCD TV/DVD Combo
Mintek dvd
unplug tv hold eject button down and plug tv back in still holding eject button turn on power
Nov 28, 2007 | Mintek DTV-373-D 37 in. LCD HDTV
Remote doesn't work
According to Mintek support you should unplug your set for 30 minutes which is a reset/rebooting process. Then plug it in and hold the DVD eject button for 5 seconds [at least]. The DVD should eject unless there is another problem. If it doesn't eject then call Mintek support at 877-646-8358 for help. They told me you have to send the TV to them and they'll send a new one. If you have to do that then make sure you tell them you want your DVD returned when they get it out. Good luck.
Nov 22, 2006 | Mintek DTV-263 26 in. TV/DVD Combo
Mintek DTV-233 23 in. TV/DVD Combo Logo
192 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
