Question about Logitech X-530 5.1 Surround Sound Speakers&Subwoofer - 970114-0403 Computer Speakers
I have a logtech x-530 5.1 speakers i have
I have a logtech x-530 5.1 speakers i have contected all cables to the woofer except the 3 wires from the right speaker...black,green orange. where do i connect these please or do i have something missing thanks
I have a surround sound and i am having problems connecting it. I have tried following the colours on each wire but when i come to plug the connectors into back of tv I am stumped. should i plug them into tv/cable or dvd
Posted on May 13, 2010
    Genius:
  • 1,354 Answers
Creative SBS 2.1 370 Speaker. hello how are you today, i have a question regarding the wiring in the volume on and off switch in the Creative SBS 2.1 370 Speaker setup, ive lost the little contoller some...
posted by Sandeep Sharma
hai, Here is the solution. when u cut the PCB from both sides u will find 4 cables i.e. green blue yellow and a copper wire coming from woofer and 3 cables white, red, yellow coming from audio lead. connect the green cable to copper cable and yellow to blue coming from woofer. Now take white cable coming from audio jack.connect this with yellow blue cables of woofer. Now attach Red and Yellow, connect these to green and copper cables of woofer and enjoy. if problem persist then make experiment to make interchanges with red white yellow coming from audio lead to the 2 sections of woofer side. woofer connections green/copper and yellow/blue remain same.
an.astrologer@gmail.com
Aug 30, 2011 | Creative Labs SBS 370 Computer Speakers
Only have the sub itself, Can I still use it and if so how?
Unfortunately you will not be able to use the sub-woofer by itself because the input for the Logitech X-530 has a special cable to connect to the sub-woofer. You could always try looking on eBay or Craigslist for replacement parts.
Aug 18, 2011 | Logitech X-530 Computer Speakers
I am attempting to reconnect my home stereo but do not see a cord or wire to connect the bass to the system. is there supposed to be a connective cord for the bass speaker? it is a 530 watt MHCGX99 model...
Hi from one Lakers fan to another 8^) - Yes you do. You need a cable to plug into the
sub-woofer out port on the receiver to the connection on your sub-woofer.
If you can't find the original cable, get a short (three ft.) standard stereo cable (one that has two cables, a white and red). Just plug one of the cables (the red or the white but it has to be the same color on both connections) into the receiver and the sub-woofer.
You'll be ready to pump up the bass.
Enjoy and thank you for using Fix Ya
Mikeywaf
Mar 12, 2011 | Audio Players & Recorders
Logitech X-530 speaker set plugged in as per instructions delivering sound from only front speakers and sub woofer. Nothing from centre and rears. XP system with ASRock ALiveDual-eSATA2 mother board....
Make sure the cables are plugged in the correct places on your PC. You may need to use the headphone out on the back panel. This depends on your audio card in your PC.
Aug 08, 2017 | Logitech X-530 5.1 Surround Sound...
My logitechh x-530 speaker system just quit, all of it. i moved my computor location from across the room and it no longer worked. i have connected and re-connected but no luck.
Just try testing the fuse in the 3 pin plug first, off chance it may have gone. Then, if that shows as OK, and you feel confident, remove the back of the Woofer and make sure that the AC wires have not come loose (can't remember if there is an inline or separate fuse in the woofer, if there is, i'd check that
Dec 29, 2010 | Logitech X-530 Computer Speakers
Something wrong with motherboard in sub woofer, Sound doesnt from front 3 speakers...but coms form subwoofer and back 2
Make sure you`ve connected all the 3 jack from the system,you need to connect all the tree of them using the adapter you got in the package
Jul 03, 2010 | Logitech X-530 Computer Speakers
Short in subwoofer wire - Altec Lansing computer speakers & sub
yes, you can splice the cables and put on a new connector, goto radio shack with the old connector and im sure they will have one you can splice right onto it. ive done this many times with varios equipment "headphones speakers etc" it may take a couple of tries to get the wiring right but if its just one speaker there will most likely be just 2 wires, if you wire it up and it doesnt quite sound right, wire it the other way. speakers will work wired backwards but wont sound quit right so if it doesnt, rewire it and it should. good luck and i hope this helps!
Jan 15, 2010 | Altec Lansing ADA 885 Computer Speakers
X-530 logitech surround speakers how do I install please
coming from the speaker with volume control, there is a cable with 3 jacks, connect them while your computer is running, yellow to pink, green to green, black to blue. a window should open asking what you connected. green is front, yellow is center/sub, black is rear
Dec 27, 2009 | Logitech X-530 Computer Speakers
Bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Sep 20, 2009 | JVC RX-554V Receiver
The model #under my speakers is X230-07 but a picture of these say they
Hi Arty, if you have a nice sound card, like Creative Live, or Audigy, or Sound blaster X-fi, use your cables that came with the x-530 depending on the cables provide, the cables are well identifid by colors, put in the same way in your computer, and of course, you need to make adjustment on control panel, in sound setting to use 5.1 computers, this may do the trick
Carl
Nov 06, 2007 | Logitech X-530 Computer Speakers
240 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
