Question about JVC MV-P612U Professional Microphone
Is a dual XLR adapter available for the MV-P612U JVC stereo mic.
I would like to build or buy a dual XLR adapter for the MV-P612U JVC stereo microphone? Does anyone know of an adapter or have the wiring diagram for this Stereo microphone
    Problem Solver:
  • 7 Answers
The MV-P162U is a stereo mic designed to plug into a JVC professional camcorder. dates from the 1990's and was very expensive.If the 6 pin plug has not been cut off, and you can get a socket to fit, then going clockwise around pins (or wiring side of socket) from the locator.
1) R phase +
2) +8V supply
3) -ve supply/gnd
4) L phase +
5) L phase -
6) R phase -
suggest a small breakout box. tested it with a 9v battery - the drain is 14ma. could run from 12v via a 285 ohm (approx) resistor with a 47uf cap across the mic supply.
Posted on Feb 12, 2013
2 Suggested Answers
rockmeister
  • 2047 Answers
SOURCE: I need to create or
Usually the best option is to get one if it is available for sale. But always xlr adapters are universal regardless of the make of the device. All you have to do is go to the stereo shop close to you with a sample of the previous one and tell them you need one mostly they stock such things.
If on the other hand you are not in such a hurry you can order a replacement on ebay.com or amazon.com usually they stock such items and they come with top notch quality.
Creating it would also go trough the same procedure as you have to purchase the components to make it and these components still have to be gotten from the previous sources mentioned.
hope this solution has been helpful?
Posted on Dec 23, 2010
Connecting r21s to laptop
The input to the laptop usually requires a stereo or TRS type 1/8 inch plug If the mic has an XLR type connector, you need a special cable that connects the XLR pins 1 and 3 (adjacent pins) to the shield of the 1/8 inch plug and pin 2 of the XLR connector to BOTH the tip and ring of the little stereo jack. Such a cable is not commonly available so the best is to make one from parts you get at Radio Shack.
Mar 12, 2013 | Samson R21S Microphone
Can you get an adapter to run 5 microphones. Channel 5 does not have a mic jack. Is there an adapter to plug to a mic that will connect with this channel?
What I think you are looking for is an XLR to 1/4" adapter. This will let you plug a standard mic cable into a line in or 1/4" channel. You can find them online pretty easliy if you search xlr to 1/4 adapter.
Hope this helps!
Jun 22, 2011 | Audio Players & Recorders
JVC MV-P612U Professional Microphone Wiring to XLR
1) R phase +
2) +8V supply
3) -ve supply/gnd
4) L phase +
5) L phase -
6) R phase -
Apr 15, 2011 | JVC MV-P612U Professional Microphone
Hello My name si Christopher and I have a Sennheiser E815S microphone and was wanting to know how can I get it to work on my PC?
Christopher, your microphone is a dynamic type with XLR connector. This means that you can connect this microphone at your pc (at the mic in connector, the red one) using a cable with XLR female connector at one end and 3.5mm jack male connector at the other end (like this). Keep in mind that the 3.5mm male connector has to be a mono type, a stereo one will not work. In case you have the connectors and a suitable cable you can connect as follows:
YOU MUST CONNECT BOTH 1 & 3 pins from XLR side at the ground point of the jack.
The whole setup won;t give the best sound quality, but it's the simplest and cheapest way to use your mic and the pc. In case you need better quality, clarify me what you are trying to do order to give you some suggestions.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jan 31, 2011 | Sennheiser E815S Professional Microphone
How do you use the mixer with a regular combo amp and stereo mic cable?
This is not hard to do, but it will require some adapters. Hosa company makes adapters to accomplish this. For example, if your Stereo mic has "1/4 inch male phone plugs" Hosa makes and adapter that has 1/4 inch female plug to Male XLR connectors. The Mackie, and just about every mixer in the world these days has Female XLR connectors for it's microphone inputs. So that will handle tha.
I'm not sure what you mean by the "combo" amp. If it has XLR inputs you can use Tip Ring Sleve male output jacks to the output. If your amp as conventional 1/4 inch female input jacks. Than a simple
1/4 inch Male to Male Guitar Cable will work fine. DON'T USE A SPEAKER CABLE as it is uninsulated and you will get 60Hz hum.
I hope this helps,
That looks like a great quality mixer you have!
Happy New Year,
Mark
Jan 01, 2011 | Mackie 402vlz3 Mixer 402vlz3 402vlz3 Vlz...
How can I connect my mackie mixer 1202-vlz3 to my mac mini
use the xlr (3 prong) main left and right outputs of the board. get xlr to 1/4 inch cables. one end will be 3 prong, to plug into the mixer, then the other end will be a mono 1/4 inch plug, like a big headphone plug. Then you have to get a dual mono 1/4 inch to stereo 1/8 inch adapter and plug it noto the line in. if there is no lone in, but a microphone jack instead, you will get a mono signal instead of a stereo signal. in this case, just use 1 channel of the mixer, instead of both of the stereo outs, and use a single mono 1/4 inch to mono 1/8 inch adapter.
the xlr to 1/4 inch cables can be purchased at a music store. the 1/4 inch to 1/8 inch adapters will probably need to be purchased at radio shack.
Nov 03, 2010 | Mackie 1202vlz3 12 Channel Mixer
My school uses Sennheiser Mic's for it's PA system. Is there an adaptor that would let me connect my CD player to the PA sytem's mic jack via the CD player's 3.5 mm headphone outlet?
The CD is STEREO whereas the MIC is monaural.
One could make an adapter that merges the left and right channels before sending on the balanced XLR input. This involves using an audio transformer or direct input box for the balanced line and is not DIY unless you are elctronically skilled.
The best way to do this is to instead plug the output of the CD into the TAPE inputs that are usually available on the mixer.
One uses usually a 3.5mm stereo splitter cable with RCA plugs for most of them.
Sep 10, 2010 | Sennheiser Epack-835 Professional...
My computer isn't detecting my new microphone?
Check if its plugged in the MIC port or the Headphone port.
Jul 06, 2009 | JVC MV-J3BK Microphone
Need of codes....
Hi I hope this will help http://www.dvcentral.org/tricks.html Tricks 4 XLR ins: Get the Canon MA-300 adapter and get yourself 4 XLR inputs. Perfect for a couple of wireless lavs, a boom, and another mic. Sure, it's less data for the audio channels, but it's plenty for voice recording. Sure, you can't digitize audio 3&4 easily, but it is possible, and it's just so darn useful to have four audio channels in the field. (Also, you can easily mount the wireless lav receivers right on the back of the camera.) Using the Canon on-camera mic via an XLR input: Say you're using a single boom mic, inputting via XLR 1. You've got XLR 2 doing nothing, and the on-camera mic doing nothing. Seems a waste. Well, all you need to do is adapt the on-camera mic to input through XLR 2. A short female-mini-to-male-XLR adapter will do for the audio signal, but the mic needs power. Simple, just get a short micro-mini extender cable, plug one end on to the mic, and the other into where the mic's connector would normally plug, on the camera's handle. Make sure the mic is switched to stereo, and voila, you have a second XLR mic. Monitoring in the field: Though many people told me it couldn't, the XL H1 downconverts to NTSC on the fly during recording, so you can plug a little monitor or deck into the video and audio out jacks and have yourself a video tap. Perfect for the director who wants to see what's going on through the camera. I used a little DV camera, and recorded it all so we could have a playback tape if needed. Very useful. (Note that the output NTSC is anamorphic, stretching the 16:9 image over the whole 4:3 frame. A monitor with a 16:9 switch is useful, or something that automatically adapts, such as what I used, a Sony PD-100 DVCAM camera.) Native slow motion: In a 24F project, shoot 30F and use Cinema Tools to slow down the footage to 24fps for a slight slow motion effect. Use 1/60 shutter speed for a standard look, or 1/30 for a slightly dreamier feel. Good Luck.
Sep 15, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
External stereo mic into camcorder not recording audio
You cannot simply attach a mike with a 3.5mm jackplug by using an XLR adaptor, the connections are all wrong. The only way to connect an XLR mike to the XM2 is by using an adaptor like the Beachtek XLR adaptor which is a superb bit of kit. I can't be certain of your problem but may I suggest possibilities? I wonder if the adaptor you bought was a stereo adaptor. If it looks like a larger version of the original plug then fine, if it has only the one long metal contact along the pin and then the tip separately, it is a mono adaptor. Using this on a stereo mike would work but it would be combining both channels into one which would degrade the sound and could give rise to your noise issues. If you have got an adaptor that is stereo, is it just the push in type? You can get adaptors that have a threaded barrel to screw the adaptor to the normal plug to lock them together tightly. If it hasn't got that, I would try putting the adaptor on the mike's 3.5mm plug and then taping it together to hold them very tightly together. This will stop minute movements between the two causing buzzing and other noises. I hope you find that of some help, my apologies if not. Rob
Mar 08, 2007 | Canon DM-XM2 Mini DV Digital Camcorder
JVC MV-P612U Professional Microphone Logo
398 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
