Question about Dometic Rooftop RV Air Conditioner
Fan will not turn on. AC unit does, however. Any ideas about the fan? Thanks
    Novelist:
    Champion:
  • 246 Answers
More than likely the fan motor is hot to the touch which indicates a electrically burned up motor.
You're only chance would be a bad fan capacitor. This will be a small gray or silver thing about the size of a large cigerette lighter. If' it's bad - it will invariably be 'bulged' somewhat. These capacitors are cheap - probably less than $15 retail, and easy to change out. Problem is finding one. You'd need to go to a Air Conditioning Supply House (Wholesaler) to find one.
Note: if the fan motor is 'not' hot to the touch and the fan capacitor is bulged - then it's a good bet that the capacitor is bad and you'll get off fairly cheap - even if you call a service tech.
If it's a bad fan motor you'll probably looking at $200-$300 repair bill.
good luck!
Posted on May 05, 2010
Fan motor was bad replaced it the relay circuit board was burnt also replaced, all parts are same as old, heater furnace comes on with the blower motor also tested the thermostat and is fine but still no fan for the air conditioner comes on
Posted on May 18, 2010
  • 18 Answers
SOURCE: maytag window ac unit
Feel the motor and see if hes hot ...... spin the fan by hand and see if it spins freely  if not the bearings have seized up.   So either rebuild the fan motor simply by replacing the bearings and oiling them and that should fix your problem.    IF the fan spins freely   OHM out the fan  and make sure there is no shorts or openings in the fan.     if your fan motor checks out good both mechanically and electrically  then your next step is to check the capacitor and control board
Posted on Oct 14, 2007
  • 73 Answers
SOURCE: AC unit fan won't turn
Yes those are the Thermostat Wires to the Unit Reconnect and you should be Fine.
Thanks
Please Rate me
George
Posted on Apr 28, 2009
  • 227 Answers
SOURCE: my outside ac unit is humming and warm..but fan not turning!
Souns like the compressor is running but the cooing fan is not. First you should see if the fan is blocked . Then see If the fan motor is getting power. If the motor is getting power it could be that the motor is bad. If the motor needs a capacitor to start that could also be the problem. Look for a cylinder shaped protrusion on the side of the motor. If these all check out then whatever tells the fan motor to come on is not working. Sorry but I cant help with that. Good luck!!
Posted on Jul 05, 2009
  • 227 Answers
SOURCE: Outside AC Unit Making Noise but the Fan is not working
It could be the capacitor on the fan motor has gone bad.
Posted on Jul 20, 2009
  • 674 Answers
SOURCE: The ac is not fully
The first thing you should do is make sure the fan turns freely by hand. If it does then check the capacitor and replace it if it's bad. If the fan doesn't turn freely then you may need a new fan.
Posted on Aug 18, 2010
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
AC unit not kicking on...
You need a "Y" terminal. "Y" is pretty standard on every heat pump. It is the wire that will energize the compressor contactor at the outdoor unit, allowing the compressor and condensor fan to run.
Apr 03, 2010 | Heating & Cooling
Jul 20, 2009 | Heating & Cooling
2004 liberty - air conditioner
sounds like the reiculation door is not moving, listen for a change in sound when you
move the knob from fresh air to recirculate. if no change, you will need to check the recirc, actuator or door inside the blower
case.
May 18, 2009 | 2004 Jeep Liberty
Thanks
Please Rate me
George
Apr 26, 2009 | Dometic Rooftop RV Air Conditioner
Outside unit come on for ac but inside won't come on for ac or heat
Turn Tsat to fan to see if inside unit will come on. If it does Tstat needs replaced. If not it is fan motor or fan relay. Possible cap. Do you here the fan relay come in. If it is a Good man unit it is time delay and you wont here it. Need to know your make of unit. Rusty
Apr 25, 2009 | Heating & Cooling
Engine fan doesn't run with or without ac
Check the cooling fan switch/ cooling fan control. as their job is to monitor temp. of engine, and turn the cooling fan on and off.
Dec 30, 2008 | 1997 Chevrolet Monte Carlo
Maytag window ac unit
Oct 07, 2007 | Maytag M6D24E7A Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
748 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
