Question about Brother MFC 210C All-In-One InkJet Printer
Scanning pictures and saving to compact flash card for sharing
Is it possible to scan photographs with the Brother MFC 240C scanner and save them or output them directly to a compact flash card for easy sharing? In other words, can you scan and save the image to any accepted storage media without having the MFC hooked up to a computer? Or are the media slots intended just for photocapturing and then printing with the MFC? The reason for the query is that I have a stand alone MFC in one room and the USB cable is too short to reach the desktop in another room. I guess I could move the MFC to the other room but that means having to move phone cables for the fax function as well, kind of a hassle.
Thanks!
  • 903 Answers
You might want to try to be sure, but I believe the SD card slot is only for printing, not for saving images. You would have to have the copier hooked up to a computer or to a network in order to send the scanned images somewhere.
Posted on Jun 01, 2010
UNABLE TO CONNECT TO MY PC
I am not sure this machine has an automatic Scan to PC option. Brother seems to like to avoid this part of most machines. Depending on your Operation System you will still be able to access the scanning system. The operation system would define which method it uses. Win XP you can access the scanner through the Printers and Faxes option on the start menu. Go to printers and faxes and then from there access scanners on the sidebar. Find your machine and open the inbuilt scanner software to scan your photos and save them to your computer. Then e-mail the saved files.
Aug 13, 2014 | Brother MFC 240C All-In-One InkJet Printer
How do i scan from my brother printer to a memory card
When you save the scanned file you can save it to your computer and then copy the file to the memory card.
When the scan is completed you can Save As (the file) and select the file location - the memory card to copy the file directly onto the memory card.
Sep 01, 2012 | Brother MFC 240C All-In-One InkJet Printer
HOW TO SCAN A DOCUMENTS BY USING CANON PIXMA MP145?
Hi
Scan the document using Canon PIXMA its very simple follow the mention below instruction to scan to document, picture & email.
  • Turn on the computer and thescanner.
  • Open the lid of the scanner andplace the photograph face down on the glass scanner bed. Close the scanner lid.
  • Click "Start" on the computer.Click "Programs." Double-click "ArcSoft Photostudio 5.5."
  • Click "File" after Arcsoft programopens. Click "Select Source." Click on the scanner model.
  • Click "File." Click "Acquire." Thescanner will begin to scan the photograph.
  • Click "Select Source." Click"Preview." A preview of the photograph will appear on the screen.
  • Drag the selection box to select theentire photo to scan or a portion of the photo. To crop the picture, click anddrag one corner of the selection box. Adjust the position of the photograph onthe scanner bed if the photo is on an angle.
  • Click "Scan" to begin the finalscan. The scanned photo will open in PhotoStudio editing window.
  • Click "File." Click "Save." A "Save Picture"dialog box will open. Type the name of the picture in the "File Name" field.Click on the arrow located on the "Save as Type" pull-down menu to choose theformat of photograph (JPEG or GIF are the usual formats for internet use).Click "Save." The photograph is now saved on your computer.
Sep 01, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Am I able to scan a picture into my computer. I have windows 7, the model is a mfc-5440cnz and do you need ink to do this? thank you for help
The best way to scan images to save on yourcomputer is to use the scanner software on the computer. Not the scan functionon the scanner.
You don't say what type of scanner software you have but usually scannersoftware works this way:
1) Place photo on scanner
2) Open scanner software
3) Using the software, Initiate scan
4) Name the Scanned item and save it to your desired location/folder
Note: some applications will automatically save to --My Documents--My Pictures
5) Repeat process for each pic to be scanned
Also, if you are just scanning, it should not matter what the ink situation is.
May 01, 2011 | Brother MFC 240C All-In-One InkJet Printer
Can I scan a document to PDF?
any scanner, indeed any document, picture format can be saved as pdf. i would suggest first scanning the document as text (for example to words, or openoffice or indeed whatever you use as your document management program) and then port it (sort of print operation) to any free available "translator" program which allow you to save file as pdf. alternatively you can scan your document as jpeg and then save it as pdf, but this tend to produce very messy outlook and results are usually horrible.
Jul 27, 2010 | Brother MFC 8440 All-In-One Laser Printer
How to scan on a brother MFC-240C printer?
Use your paint program under accessories.
Start - accessories - paint - file - from scanner or camera - choose your device and follow the directions
May 28, 2010 | Brother Multi-Function Center MFC-240C...
Cant scan??
if installed right it should bring up the program on computer when you change printer to scan and hit start. should be able to select computer on scanner after you switch function to scan on printer.
May 21, 2009 | Brother Multi-Function Center MFC-240C...
Can't email scanned files.
hell csnevels you will need to uninstall the program and then reinstall the cd that came with the machine, if not you could download the cd from brother.com brother tech
Jan 17, 2009 | Brother MFC 240C All-In-One InkJet Printer
Won't scan
I would uninstall the dodgy mydvd program, and use Spybot to clean up the malware it has spread on your system.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie Brother MFC240c) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 04, 2009 | Brother MFC 240C All-In-One InkJet Printer
Not able to scan to pdf file with Brother MFC-240C
What you seem to want to do is not possible. Let me explain:
A file that has its data in the Adobe company Portable Document Format (or a pdf file) contains various objects that are described to the computer using a superset of the PostScript language, some of them can be images.
A file that comes from the scanner is first a very organized set of pixels and gets put into a more compact form by using a well known process as defined by the Joint Motion Picture Experts group. This is a roundabout way of saying that it has a format that isn't PDF.
What you CAN do:
a) open the jpeg file with a Macintosh, using the Print command from the file menu make a pdf file that has the image in it.
b) buy and install a PDF printer driver on a Windows machine, and then follow the same process as A above.
c) Use your favorite PDF creation program to make a file with the image embedded.
Carl
Dec 10, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
135 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
