Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
LT1000 Will not start no clicking no turning over just dead
I was mowing my lawn stop to get some water came back and the mower will not start. Checked all connections and safety switches along with battery...nothing. I tun the key and there is nothing.
    Problem Solver:
  • 11 Answers
Do you have a multitester? A multitester set on vdc, should tell you if your battery has discharged. Should have about 12.5 to 13.0 volts for the engine to turn over. Could be a fuse, or bad connection. How corroded are the battery terminals?
Hope that helps.
Posted on May 05, 2010
Mowing yard and stopped to go inside. Come back out and mower turned over but would not crank. Kept trying and it started clicking. Rocked the mower and it started. now does same thing but won't start
Check your charge in the battery. Clicking usually is dead battery. If the battery is good, starter may be bad (or at least the starter solenoid).
May 04, 2015 | Garden
LT1000 cranks but won't start
check to see if you lost spark if not spray starting fluid and see if it fires that will tell you if it's a fuel prblem
May 21, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a LT1000 riding mower,the other day while i was mowing the engine just shut off.I tried to start it back up and does not do anything.Completely dead?
If the engine doesn't do anything then it is probably a bad relay on the starter. If it turns just a little bit, but not very fast then you either need to charge or replace the battery. You can take the battery to your local parts store and they should be able to test/charge it for you.
Jun 09, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I'm having trouble replaceing the motion drive belt on my LT1000 lawn tractor. The mowing deck is off, the old drive belt is off. I can't get the belt around the transaxle pully. Any suggestions?
Often there is a keeper on the back of the pulley, and the belt must go inside the keeper. Get an inspection mirror up in there to look if necessary. Start by putting the belt on the transaxle pulley, then on the PTO pulley, then on the idler, last have someone sit on the mower and depress the clutch pedal while you put the belt over that pulley.
Sep 26, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Self propelled stops working well mowing, I
turn it off,let the drive handle go,pull mower backwards.does it lock the back wheels?if you push it forward,can you hear a clicking noise from the wheels?you should do.lift mower,spin back wheel,should either lock,or click,depending which way you spin it.they have spring loaded pawls that drive the wheel.usually easy to fix.usually dirt,or too much grease.take wheels off,have a look
Jul 04, 2010 | Troy Bilt 5.5hp Self Propelled Mower
WILL NOT START craftman LT1000 YR.2000
most likely the blades are still in the on position,but you have a seat switch, parking brake switch, and the blade switch, also the mow in reverse key switch. if mower dies once you let out the clutch in reverse with blades on and key wrong.
Apr 22, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
237 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
