Question about Zonet ZPS3611 Print Server
Lost connectivity after power outage
After a recent power outage, I lost connectivity to my printer. The printer itself is fine, I can print when connected directly to it, but I cannot print through the print server, which is connected to my wireless router.
I tried unplugging the print server and plugging it back in. I tried pressing the reset button on the surge protector. Nothing has worked yet.
The router also seems to be fine, as I have not lost my wireless internet connection.
I am using a WIN 7 PC.
Thanks for your help
  • 111 Answers
If this is a printer WITHOUT WiFi or bluetooth - and you have it connected to another computer (Print Server) via a USB cable - you need to make sure you can see that computer from the other computer you are printing from. Use the network explorer - if you can see the computer and the printer you should be able to print to it.
Sometimes, it may be secured with a password. I found if I can map a shared drive from my laptop to my print server then I can print again. So see if you can see the printer and printer server computer from the other computer. If so you may need to add that printer again to you printer list.
lost connectivity after power outage - capture-agkhgscnsed5ttrxyrg0l1ae-3-0_0.png
Posted on May 01, 2017
4 Suggested Answers
SOURCE: failed response from plugin device
Dirty fix...
When the printer errors out...stop, unplug the power to the printserver. Reset the printer, Clear the print que (delete jobs/restart print spooling service), restart the printserver software and plug the printserver power back in. Wait for the re-detect. Everthing should be good at this point. Unfortunatly the print job will be lost and you need to print again...BUT, NO REBOOT yea!!!
Note... for me, if this sequence is not followed, I will have to reboot. The printserver will be locked for the PC that was trying to print. All other PC's will be fine, and I have no idea why.
Good luck,
Posted on Jul 01, 2009
  • 4924 Answers
SOURCE: i purchased an epson stylus photo 1400 printer for
Here you have instructions about how to set a print server in the router ..and all conflicts that may appear ..Please read carefully cause some of teh steps are needed just in conflict conditions ...and you do not have to run them all ..
The actually first step is to access the server by its IP address and make teh settings for the printer ...after that you should install the printer driver in the computer ..and take the printer and faxes wizard to make the default printer settings ..(choose it from the list after it is correctly connected to the prin server and this one connected to the router )
To connect it to the router you should get into its setting and basically its the same as connecting a computer ..
Posted on Dec 30, 2010
  • 10421 Answers
SOURCE: Installed 3 Zonet Parallel print
Please get the correct driver here :
Regards, Jay__m9jch56
Posted on Feb 26, 2011
After power outage the printer won't power up.
The printer is dead, the surge got thru and fried it. Replace it and the surge-protector.
May 08, 2010 | Dell 922 All-In-One InkJet Printer
Lost ip/connection on Dell 1720dn
try resetting the "print spooler"
  1. start
  2. control panel
  3. admin. tools
  4. computer management
  5. services and applications
  6. services
  7. scroll down till you see "print spooler"
  8. left click once
  9. "restart"
Jan 06, 2010 | Dell 1720dn Laser Printer
I have an HP c7180 all in one inkjet printer and recently we had a power outage. Ever since that time the colors are all mixed up. After the power outage, I was getting this error message: ""Ink System has...
If your product is in warranty then I recommend you to contact HP support to service or replace the unit. Otherwise perform the steps given below and verify the results.
  1. Turn on the unit.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 7 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
Oct 13, 2009 | HP Photosmart C7180 All-In-One InkJet...
HP All-in-One Printer Series 1300 prints blank copies
Have you tried printing a test page from the printer itself. usually holding down the power button will instruct the printer to print a self test by itself.
Mar 10, 2009 | HP Officejet Pro L7680 All-In-One Printer
Replaced drum on printer
have u tried to unplug it and plug it back in.try this and let me know if it works again
Jan 07, 2009 | Brother HL 1240 Printer
Bizhub C350 - Print spooler not running after power outage
I would print out a copy of the network configuation of that printer and ensure it has the proper network settings (I.E. IP address, Subnet mask and Default Gateway. I just worked on a printer that I accidently pull the plug on and it lost it's network settings and wouldn't print until I changed them back to the correct settings.
Good luck
Nov 11, 2008 | Minolta C350 Printer
Printer not responding
Test the printer itself to see if it will print a configuration page. This page will tell you if the IP addresss is still intact.
Apr 17, 2008 | HP LaserJet 4 plus Printer
How to correct error message sram error missing E?
Hate to say this but most likely the Print Engine Control Board has failed.
May 09, 2007 | Xerox Phaser 7300DN Laser Printer
Zonet ZPS3611 Print Server Logo
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
