Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Ielectical circuit manual for a Snapper
I need the electrical circuit manual for a Snapper riding mower. I'm converting a B&S 8hp to a Tecumseh 13hp engine. Tecumseh doesn't have a recoil starter. I would like to buy a manual with the solenoid and recharge ckts.
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
wadembly
  • 475 Answers
SOURCE: i need a repair manual for a scotts riding mower.drives a few fee
it could be the axel they have spider gears in them & the teath could be sheared or the the rearend is low on fluid
Posted on Jun 05, 2009
mowerman1857
  • 389 Answers
SOURCE: I have a Snapper rear engine riding mower. Mod#28085S
If one goes to the starter, the other has to come from a 12 volt source, either ignition switch or battery
Posted on Oct 04, 2009
bbreton
  • 437 Answers
SOURCE: Snapper Hi-Vac riding mower that won't start with starter
You may need a 300cca battery, an ignition switch or a solenoid to get things going again. I also would check to make sure the starter gear has not locked in the flywheel teeth; it will burn up the starter. You should be able to go to the snapper website and put your model of mower in and find the parts and diagrams you need.
Good Day.
Posted on Oct 26, 2009
  • 35 Answers
SOURCE: i need an owners manual for a murray riding mower.
First off, confirm that the tractor is in Neutral and the deck is not engaged. You also need to be on the seat, and in some cases your foot must be on the brake. Then try it.
If by "jump" you mean essentially connect one end of a jumper cable to the battery power coming to the solenoid, and the other end of the SAME jumper cable to the 6 gauge (+/-) wire on the other side of the solenoid that goes to the starter, and it cranks, this means one of two things.
More than likely it is the solenoid that is bad, but the only way to confirm this is to make certain that when you turn the key, it sends power to the small (18 gauge) wire on the solenoid. This is easy to check with a test light.
If power is goes to the solenoid when the key is turned, but the engine fails to crank then the solenoid is bad.
If no power is there, then the problem has something to do with either the ignition switch or ignition wiring, or more likely it is a failure of one of the safety switches, under the seat, transmission in gear, sometimes if the deck is engaged, or other.
One way to confirm that the problem is with a safety switch or ignition switch and rule out the solenoid would be to jump a wire directly from the positive terminal to the small wire on the solenoid that comes from the ignition. If this causes the engine to crank, then the solenoid is OK.
Posted on May 09, 2010
Where can I get a free wiring diagram for a 1996 12.5hp snapper riding mower
Go to the Snapper Website, enter your Snapper mower serial number, the engine serial number and search manuals. If no success, google it.
Sep 21, 2015 | Snapper Garden
I switched my SR830 mower from the original 8 hp briggs to a 17.5 hp Tecumseh off a later model. I need to know how this engine and starter solenoid wires up
  1. Tecumseh Small Engine Parts - RepairClinic.com
    www.repairclinic.com/Shop-For-Parts/.../Tecumseh-Small-Engine-Parts Huge selection of Tecumseh Small Engine parts in stock. Same day shipping. Open 7 days a week. 365 day return policy.
Jul 20, 2015 | Snapper Garden
Where can I get a diagram of carb choke and throttle linkage set up?
I bought a brand new 13 hp Tecumseh on my rider,was trouble from day one,fought it tooth and nail,finally took to shop,they put a brand new Taecumseh carb on it,couldn't get it to run,went to a dinky lawn mower shop,was told the carb was not the right one,wow,they sold me a used one that looked way different,but it worked super,so try another non-tecumseh carb or fight it forever.
Jun 07, 2015 | Garden
I have a tecumseh 8hp on a snapper handlebar rider. bought it used 2 weeks ago, got it home mowed for about 1 hour and it quit. decide to give it a tune up. noticed the coil wire was almost burnt in half....
If plug is dry than you are not getting fuel to the plug something is plugged up in the carb clean it thoroughly and make your coil gap is correct. But I would lean more towards the fuel not reaching the plug.
Jul 18, 2010 | Garden
Snapper mower electric start problem
On most mowers, that red wire will connect to the battery. that could be your problem.
you didn't say if it is a rider or not, or how old it is.
Touch the wire to positive post on the battery, with the key off, remove quickly if it sparks.
if no spark, hold it to the battery while turning the key.
if the engine tries to start, connect it permanently.
Apr 14, 2009 | Garden
Electric start not working 8hp.mtd. snowblower
Hi, check the starter if it's engaging too the flywheel. there is plastic molded gear on top of your starter some times gets broken.
If this doesn’t work for you please write back. Thanks,
Nov 21, 2008 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
114 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
