Question about Boating
I have a 2005 90hp yamaha on a 17' xpress bass boat. i can only turn 5200 rpm when you get to 4800 rpm the boat starts bouncing.
  • mitch May 11, 2010
    Have you tried trimming the motor out or in at 4800 rpm?
  • 677 Answers
Check the running height of the motor.The prop shaft should be about one inch below the straight line of the bottom of the running bottom of the boat.With a cleaver prop it may be lower.A chopper prop is the best and you can run every bit of that.2 inches if pitch is = to about 500 revs.Try a few props 1st before you pay the dollars for a new one.The bouncing is the wrong transom height and prop.You don,t need a cav plate if the boat is set up right.(a cav plate extension like a manta).Bad dealers may want to sell you these.A well set up boat doesn't.I've set up and run a lot of ski racing boats and all have never needed any "bolt on parts".Its mainly a motor height and prop selection thing.Hope this helps
Posted on May 05, 2010
My 1997 yamaha 50 hp outboard rpm's go up and down on its own
Hi Joe
Please Check The Choke Diaphram On Centre Carb
If I Am Thinking Of Your Model This Is Where Your Problem Lies!
Cheers
Gordon
Jun 24, 2013 | Light Outboard Motor Boat Bass Fishing...
What may cause the tachometer to bounce while on idle and sometimes shut off the engine?
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Bouncing idle
Jumping needle on RPM Gauge The Hull Truth Boating and Fishing Forum
Yamaha 2006 YZF R6V Owner Manual
OEM parts for Yamaha
Yamaha YZF R6 2006 Service Manual
Mar 17, 2012 | 2008 Yamaha YZF-R6
I have new 40hp mecury lightining my problem is when i take off feels slugish and does not take off like two stroke should. i was told its the set size origional at 0.80 should be at 0.85 is this the...
I'm assuming that you mispelled and set should be jet. I'm also assuming that you're at a higher altitude. That could mean changing jet would improve performance. Changing your original propeller which was designed for sea level could also help. I know that my 115 horse Merc could only get up to 4200 rpm with the factory prop that was 17 degree prop. I changed to a 15 degree and got to 5200 rpm and a 13 degree got me to 6000 rpm. It's a little expensive but to get to optimal performance for your motor you'll probably need to change jets and prop.
Nov 12, 2009 | Light Outboard Motor Boat Bass Fishing...
2003 yamaha 50hp 4 stroke, won't start
sounds like you are going to have to pull carbs off and clean jets also check tank and line for debries
Sep 03, 2009 | RTO Oar Sockets
Boating Logo
167 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
