Question about Hitachi Ultravision P50S601 50 in. Plasma HDTV
Stanby light is blinking. when I turn the tv on it turns on for one second and then turns of and the "stand by" light starts blinking
  • 3 more comments
  • francisco167 May 05, 2010
    When I turn on my tv, it turns on for 3 seconds and then turns off and the "stand by" light starts blinking. One blink per second aprox.
    confirmed! I have a P50s601
    Professor are u there?
    ok after I remove the posterior cover:
    1.- What should I see? is there any visual sign of damage?
    2.- you suggest to replace this part(s)? how much are they?
    Got it.. thank you very much my friends
  • 566 Answers
Hi francisco
I`m going to help you with you tv but first;
Could you confirm that your tv is a hitachi P50S601?
In any case it does sound like a power supply problem.
Be waiting for your reply.
Posted on May 05, 2010
  • 1 more comment
  • Jacques Marin
    Jacques Marin May 05, 2010
    O.k , as i said i would suspect the power supply to be the problem and you will need to take the back cover off to take a look.
    In your model there is two capacitors on the p.supply board that may go faulty.
    These are C552 and C553 and they are 3300 microfarads at 100 volts.
  • Jacques Marin
    Well they`re not very expensive 4 or 5$ a piece.
    Unfortunately they don`t always show signs like swollen or puffed up.
    These are the first parts i would try to replace in your case , but you have to keep in mind that there may be other problems that will require replacing parts and unless you feel comfortable with electronics i would suggest that perhaps you get an estimate from a local repair shop.
  • Jacques Marin
    Let me know if you want to give it a shot yourself.
  • 666 Answers
The blinking light signifies to a repair technician with capacitors or circuits are having an issue they can diagnose the problem via the amount of blinks in between pauses however it will require a technician and some specific tools and schematics to fix and it may be cheaper if its no longer under warranty to purchase a new one
Hope this helped
Robb
Tv is in stanby mode. when i turn on power it seems like it wants to start but nothing comes up on screen. stanby light is blinking
The problem is in the main board of the tv, it is either a power supply issue or a high voltage problem. In order to isolate you will need a tv tech to check the set out and cost involved.
Jan 07, 2011 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Picture will not come on
CK Fan! If fan is defective Lamp will not LIGHT for long and set will shut down.
Feb 18, 2009 | Samsung Televison & Video
My sony TV wont turn on.
Un plug and let stand for one minute. If it still does blink then use the reset on the remote and press it while pressing the power button on the TV.
Jan 19, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KF50XBR800 Turn off and on issue
You will need to replace your bulb.
It costs around $ 300.00 for a new bulb.
After you have installed it, your TV will look new once again.
Dec 30, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
No picture blinking stand by light
I hve worked on a number of these units , your description is typical of a shorted blue picture tube. The protection circuits in the tv detect that there is a problem thus shutting the unit down to prevent further damage. Sony had a bad run of picture tubes in this series. The replacement cost of the tube is about $250 plus labor. My estimate would be for the repair about $400-500 depending on where you live and how honest your local technican is. I will caution you however, that you could replace this tube and the red or green could go. These would not be covered by the technicians warranty. When these sets are working, they have a superb picture and it is easy to get lured into fixing them. Scrivitron
Jun 13, 2007 | Sony KP-51HW40 51" Rear Projection...
Hitachi Ultravision P50S601 50 in. Plasma HDTV Logo
470 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
