Question about HP Officejet 7210 All-In-One InkJet Printer
Hp office jet 7210 all-in-one printer
My printer is printing everything in red. I have changed out both cartridges and made sure the print set up is for black. I've try realigning the cartridges and cleaning them. Still get red print only
    Problem Solver:
  • 12 Answers
Hi , this is definitely a print head issue of the printer. You can just try one more thing - press set up on the printer - go to print reports - press ok / enter - go to self test report - press ok / enter
If the report comes entirely in red the printer needs servicing from the local service centre.Ithappens only if the nozzles of the cartridges are blocked and they do not let the ink pass out how many ever times you replace the cartridges.
Posted on Apr 08, 2008
HP5550 printer is printing everything in green. We have true HP cartridges
So, your "blue" and "yellow" ink-cartridges are OK, and are mixing to produce "green".
But, either your "red" ink-cartridge is empty, or the ink-jets that shoot that colour onto the paper are BLOCKED.
Run a print-head-cleaning-cycle, using the HP Support Tools that were installed from the HP CD-ROM, and then, if necessary, replace/refill the "red" cartridge.
Aug 30, 2010 | HP DeskJet 5550 InkJet Printer
Am having difficulty removing Black (96) print cartridge from an HP 7210 All-in-one printer/scanner to enable installation of a new (96) cartridge and need help!
on the software on your PC there was a option in the printer setting>> preferencess>> maintenance, which you can select the ink/cartridge replacement..
Jun 25, 2008 | Office Equipment & Supplies
HP Office Jet 7210 Scanner won't work
Try this simple step,
Disconnect the power cord from back of printer ( while printer is on )
wait for 10 seconds and connect it back
let the printer Initialize and Try to scan.
IF this does not work, you probably just need to uninstall and reinstall the drivers.
Jul 06, 2010 | HP Officejet 7210 All-In-One InkJet...
What is the replacement printer for HP Laser Jet
This document provides information about replacing the print cartridge for the HP LaserJet 1010 printer series, including life expectancy and replacement instructions. Print cartridge life expectancy The life of the print cartridge depends on the amount of toner that your print jobs require. When printing text on letter/A4-size paper at five percent coverage, the print cartridge lasts an average of 2,000 pages. This assumes that you set the print density to three and disable EconoMode. (These are the default settings.) See Ordering supplies for information on ordering replacement print cartridges. Changing the print cartridge Follow the below instructions to change the print cartridge:
  1. Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box. Figure 1: Removing old print cartridge c00028312.gif CAUTION: To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
  2. Remove the new print cartridge from the packaging, and gently shake it from side to side to distribute the toner evenly inside the cartridge. Figure 2: Gently shaking new print cartridge c00028313.gif
  3. Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling. Figure 3: Removing tape from print cartridge c00035442.gif
  4. Insert the print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door. Figure 4: Inserting new print cartridge c00028315.gif
Apr 20, 2010 | HP LaserJet 1010 Printer
My hp office jet 7210 takes several minutes to
I suspect that you are looking at a flow control issue and not a printer failure.
You can check the printer driver and make sure your printer options for background printing.
Also, make sure that your document is not too busy. I've had customers complain about slow printing documents and when I examined the documents, I discovered that there were multiple images overlay ed. The data still had to be sent, but only the top image printed.
Nov 05, 2009 | HP Officejet 7210 All-In-One InkJet...
HP officejet 7210 hortizontal white lines
I would suggest you get a set of original HP cartridges .. I have clients trying to save $ all the time by buying refilled and/or refilling themselves to only go and get HP brand. Refills just don't cut it .. leaks, poor print quality, unrecognized cartridges .. there are so many things that I can point out .. save yourself the hassles .. get HP
Mar 30, 2009 | HP Officejet 7210 All-In-One InkJet...
Printer does not print in color
I have the 4315, so I am not sure if the answer is exactly the same. But there is a setting, for only printing in black ink and you need to disable it. Here is how to get to that setting: Go to
"File" "Print" "Properties" "color" UNCLICK "Greyscale" and unclick "Black cartridge only."
Jan 10, 2009 | HP Officejet 4315 All-in-One Printer
Remove and Check Color Cartridge
Last night I spent an hour with HP Technician on-line trying to diagnose the problem with my 2 year old HP Officejet 7210 All-In-One. After trying everything HP came up to resolve the problem, the technician determined it is a hard failure in the electronics hardware. Since my warranty is expired they offered me a deal on the L7680 All-In-One. My 7210 was very lightly used (still on first set of cartridges). If this is the quality of the latest generation of HP hardware, I am probably going to look at something else.
Nov 28, 2007 | HP Officejet 7210 All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
149 people viewed this question
Ben Johnson
