Question about Acer Aspire One PC Notebook
Aspire One has a loud noise coming from the fan area while in use
  • 20 Answers
You could try blowing the fan area out with some compressed air. The fan might need to be replaced.
Posted on May 05, 2010
3 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: loud noise grinding sound computer works ok
Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
I would suggest getting a can of compressed air made for computers
take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
While you are in there just check that the CPU cooler itself is not loose
If it is it will have to be re-seated.
If it needs re-seating don't just take it off and put it back on as that might make things worse with your temperature problem they have to be cleaned and new thermal grease put on ($2-5)
DON'T remove the CPU just the fan/cooler assembly.
You must clean both the surfaces without scraping anything off. Use isopropynol alcohol and cotton bud sticks until both surfaces are clean, you can use your finger nail to scrape harder residue if you wish but nothing else.
DON'T pour the alcohol over the CPU
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are
some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business
If it the Powers supply fan then these ase sometimes replaceable.
Beware howeve that even after disconnection high voltage may still be present.in side the PSU.
Better to replace the whole power supply witha the same or greater wattage.
Posted on Oct 05, 2009
SOURCE: a loud grinding noise comes from the fan area
Check if there are dust debris on the fan, it could create a grinding noise, but if the fan is clean, there could be a mechanical problem with it. Hope this helps
Posted on Dec 12, 2009
Loud Noise in Central Dash area, 2000, F-150,,Sounds like a fan hitting against a heavy plastic part.Starts around 45MPH.. I think its either air flow or speed causing it.
Have you checked to see if the heater motor is ok. Sometimes the newer ones have a bearing in the end by the plastic fan and the bearing will allow the fan to drop down and cause a loud noise when running. To check turn off the heater motor fan on the dash and see if the noise goes away.
Apr 18, 2017 | Ford F-150 Cars & Trucks
My Acer Aspire 5551-2036 makes a rumbling noise, like a fan motor, coming through the speakers what can I do?
mayge a blown speaker do you have it playing loud???if this is case easiest solution is headphones,or external speakers.the replacement is not hard but very fiddley
Dec 10, 2013 | Acer Aspire One PC Notebook
Mitsubishi mighty max 3.0 v8 loud noise coming from the fan area
If the fan is attached to the water pump tahe hold of a blade and try back and forward towards the motor. If there is movement there it will be either a fan hub failing or a water pump bearing. Second check remove the fan belt and check for noise.( idle engine for short period of time) If it is gone confirm pump by spinning any adjuster pulleys and check for noise or rough movement
Jan 12, 2013 | 1994 Mitsubishi Mighty Max
Fan makes really loud noise and then computer shuts down by itself i have an acer aspire4530
sounds like the machine is overheating, remove the case and clean out the fan and surrounding area.
May 02, 2011 | Acer Aspire One PC Notebook
Laptop recently started to make noise on start up, feels and sounds like it's coming from the area below the keyboard in the lower left part, it's an acer aspire 5570-2067. it makes noise for a while, then...
Def sounds like the fan , from where you say the sound is coming from . normally the fan should be able to be cleaned the panned holding the fan in the left hand corner . clean the fan with compressed air , or a paint brush . if this fails then you need a new fan .
Nov 23, 2010 | Acer Aspire One PC Notebook
A loud grinding noise comes from the fan area
Dec 11, 2009 | Acer TravelMate 4200 Notebook
Loud fan noise on acer aspire T690 PC
The first thing to do is to clean the PC. More than likely it is just dirty. Remove all cables and take it outside. Remove the side panel and using compressed air give it a good cleaning. Pay special attention to the fan areas. After cleaning check to make sure the fans are all working and that the processor cooling fan is firmly connected. http://reviews.cnet.com/4520-11319_7-6240575-5.html?tag=rb_mtx;wp_body
Oct 13, 2009 | Computers & Internet
Loud noise
The compressor fan is making the noise and causing overheating as well. Easy fix. Call Danby with model # and they can figure out correct fan. Part will cost around $10 and is easy to replace. Plug and play with screws. Good luck
Apr 21, 2009 | Danby Silhouette DWC512BL Wine Cooler
MY ROPER REFRIDGERATOR IS MAKING A LOUD NOISE. POSSIBLY THE FAN OR COMPRESSOR? WHAT CAN I DO TO QUIET IT DOWN?
First find the area the noise is coming from. Does it sound like a fan hitting something? Or is the compressor making the noise? Has dust collected in the condenser coil area that has cause air restriction ? I a paper shroud that is mounted near the fan come loose and striking the fan? Has the noise affected the performance of the refrigerator? Let me know and I will be able to help you solve this.If you find the problem please remember to unplug the refrigerator before putting your hand in an area that could cut or shock you!
Click link below to get more problem solving answers. And if I can help let me know, Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Feb 01, 2009 | Refrigerators
Fan noise is very loud it seems top be coming from side filter area
this unit has 5 fans in it find whitch one is making noise it may be just a foren object if not replace fan--------wewilly w55bb42@gmail.com
Oct 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Acer Aspire One  PC Notebook Logo
162 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
