Question about M-Audio BX5a Speaker
Bx5a cracked tweeter, subtle buzzing, popping noises above 50 db. How do I repair it myself? It's out of warranty and shipping/repair is prohibitively expensive.
2 Suggested Answers
  • 149 Answers
SOURCE: no sound from tweeter
First of all, never connect the audio from your receiver directly to the tweeter. You can blow the tweeter instantly. The mid-bass driver can be damaged from a direct connection as well.
Since you get absolutely no sound from either driver, this seems to implicate the crossover. If the crossover has opened, no signal gets through, if it has opened early in the signal path.
But, it is also possible that a short exists, and that perhaps your amp cuts off the output having sensed a short. The short could be in the crossover or one of the drivers.
Here are some troubleshooting tips--
To prevent damage to your amp, turn it off while making or breaking any connections inside the speaker boxes.
Write down which wires get connected to which place on the drivers, so you can get them back where they belong.
With your amp turned off, connect the bad speaker to your amp. You've already verified that no sound is produced when both drivers are connected.
So, with your amp off, disconnect one wire from the tweeter in the bad box.
Briefly turn your amp on and listen for sound.
If you get sound, the tweeter is shorted.
If you get no sound, with the amp off, reconnect the tweeter in the bad box and disconnect one wire from the mid-bass driver.
Briefly turn the amp on and listen before turning the amp off.
If you get sound now, but not before, the mid-bass driver is shorted.
If you got no sound either way, check the DC resistance of the mid-bass driver (only, not the tweeter. Ohmmeters put out a small DC voltage to test resistance. That DC voltage might damage a tweeter, maybe. Don't risk it). Ohm the mid-bass driver while it is not connected to the crossover. If the driver is good, you should read some ohms--a little less than the stated impedance. An 8 ohm driver might read 6.5 ohms, for instance. If you get an open or a short (with the crossover disconnected from the mid-bass driver) you have a blown driver. Two actually, since neither the tweeter nor the mid-bass driver produced any sound in the previous tests.
If you can't get ahold of an ohmmeter, try this--
Open the good, working speaker and place the two side by side.
Connect your amp to the bad speaker box only.
With your amp turned off, disconnect the wires from the mid-bass driver in the bad box and connect them to the mid-bass driver in the good box. Disconnect one of the wires from the "good" mid-bass driver first, so you don't have two crossovers connected to it at the same time--even if only one of them will get powered on. It keeps the confusion down to a minimum when trying to isolate your problem. Oh, and disconnect one wire from the bad tweeter, in case it is shorted.
Turn the amp on and listen briefly before turning the amp off.
If you got sound, the "bad" crossover is fine, but the "bad" mid-bass driver is blown. And, since you got no sound in the previous tests, the "bad" tweeter is blown, as well.
If you got no sound, try it the other way around. Meaning--
With the amp off, disconnect the speaker wires coming from your amp from the bad speaker box and connect them to the good speaker box.
Your amp is now connected only to the good speaker box.
With the amp still off, connect the mid-bass wires from the good box to the mid-bass driver in the bad box. Remember to disconnect one of the "bad" crossover wires from its own driver first, so only one crossover is connected to the "bad" mid-midbass driver. Remember to disconnect one wire from the "good" and "bad" tweeters, so the only sound you hear--if any--is from the "bad" mid-bass driver, powered by the "good" crossover.
If this produces sound, but the previous attempts failed, you have a crossover problem.
If you still get no sound, something went wrong and you need to retest the good speaker by itself and back up a few steps and try again.
Assuming you got sound from the "good" crossover while it was driving your "bad" mid-bass, make sure no wires have come loose inside the "bad" box. Assuming you have sound connections at each end of each wire, you now need to desolder the electrolytic capacitors from the circuit board.
Make sure you mark them first, so you can put them back where they belong.
You can remove only one at a time, if that helps.
Use an ohmmeter to check some components.
The big red coil should read pretty close to a short, maybe one ohm.
The capacitors should read open or infinite resistance, although you might see a steadily increasing resistance while the capacitor charges up from the ohmmeter. If you read a steady low resistance on a capacitor after it has been removed from the circuit board, that capacitor is bad and must be replaced. The markings on the capacitor should give you some clues as to the proper replacement.
All things considered, I suspect that your problem is a shorted electrolytic capacitor. But, I gave you all I could think of so you can narrow it down and isolate the problem, whatever it might be.
I hope this helps.
Posted on Feb 24, 2011
Audio bx5a tweeter
Tweeter just may need to be replaced. Is all the sound coming only from the woofer?
Apr 04, 2014 | M-Audio Audio Players & Recorders
Eurolive B115D Powered PA Speaker
I would guess this is less than 3 years old and assuming you registered you will have a 3 year warranty so they'll probably fix it for you FOC
Jan 07, 2014 | Behringer Eurolive B115D Powered PA...
My compaq mini is making a buzzing noise
If it's under warranty it should be covered. It might be the fan, dvd drive or hard drive that is making the noise.
Jun 01, 2012 | HP Compaq Mini CQ10550CA Netbook
I bought a Comfort Zone (RedCore Concept R-4-20100625) three months ago and already have a problem! The heater makes a loud noise continually once it has hearted up and after I turn the heater off the...
If it's under warranty, the "hassle of shipping it off is small", compared to possibly doing more damage, while trying to repair it yourself and voiding the warranty. Once they repair it, the warranty starts over again. Just make sure you get authorization from Comfort Zone, before shipping it to them..
Mar 21, 2011 | Comfort Zone Heating & Cooling
One of my two year-old BX5a pair started making cracking noise. I am wondering if it's something I can fix myself. I happen to be an amateur radio operator and used to build radios when I was a kid and...
This would be burnt out voice coils. This takes some special tools and material to rebuild them. etech.com or ebay or amazon may have the things you need to rebuild it. It would likely come with instructions as well but there are how stuff works videos and maybe youtube vids as well to watch to see how it's done.
Jan 28, 2011 | M-Audio BX5a Speaker
So I've kept my Studiophile BX5a Deluxe monitors in good shape, but I noticed that every sound I tried to generate via Ableton Live on my Mac, a buzzing sound would accompany the sound. For example, I...
See if you can isolate the buzz to one woofer or tweeter. If a woofer, gently and evenly move the cone in and release to feel / listen for scraping. If you notice any scraping, the voice coil could be shot - a small bobbin of copper wire may have deformed andis now rubbing. Occasionally if a speaker is dropped, the magnet can shift, which will then rub the coil.
In any case, if there is coil rub that causes the buzz, you need to replace that driver.
If the buzz is electronic in nature, assuming these are the powered versions, a qualified service tech will have to diagnose and repair.
Jan 06, 2011 | M-Audio BX5a Speaker
Tweeter not working
Check the continuity of the removed tweeter with a VOM meter (I use an original Heatkit MM-1 available on eBay for $20) and do the 1.5 volt battery click & scratch test mentioned above.
Celestion A3 tweeters (also used in the A1 and A2 speakers) or the replacement diaphragms are no longer available from Celestion. A1 speakers show up regularly on the United Kingdom eBay website for $300 or less and are small enough to economically ship to the USA. You would also end up with a midrange spare speaker (assuming it is the same as in the A3 cabinets)
The part number for the A series 3 bar tweeter is T4969/P. The 3 bars refers to the 3 bars in the casting to protect the dome. I got this number from the box of my spare tweeter I have the earlier 1 bar castings in my A3's.
Go to www.ersatzteil-versand.at do an "artikelsuche" (article search) for the number T4969/P and something extremeley similar shows up except that they list the manufacturer as Onkyo. The part number and description are so similar to what is printed on my spare tweeter box it would be worth 81 euros to see what shows up.
I have designed an adapter plate for either a Scan-Speak Revelator Tweeter D2904/710002 4 ohm, 1" soft dome, 70 mm diameter magnet, $220 or a Vifa D27TG35-06 6 ohms, 72 mm diameter magnet, 91 db, $37.50..Both are available from:
http://www.speakercity.com/ in Burbank, CA
I only modeled the front flange of the tweeter to save time. I have not built any of these yet but the price would probably be $400 for a pair of adapter plates and speaker flange modifications. But when you are done you would have replaceable tweeter for a long time to come. The 2 protective bars are drawer handles available for $3 each.
Other possibilities are:
http://www.audioloudspeakers.co.uk/boultons.shtml voice coil rewinding in the uk
http://www.speaker-repairs.com.au/coils.htm voice coil rewinding in australia
http://www.speakerex.com/diaphragms_new.html in Florida can rebuild the woofer and replace the midrange but no longer have the 4 ohm diaphragm for the tweeter.
If you want the drawings (and 3D geometry file necessary for the machinist to make the curved edges) for the adapter plate and tweeter flange modification contact me at mercedes280se-4@yahoo.com
Feb 11, 2010 | Celestion A3 Speaker
After loud cracking noise no picture on plasma
The most likely the TV has a power supply related problem. A power surge can cause the problem. Last thing you want ot do is void the warranty by opening up the TV. Here's info to get your warranty started:
http://www.lge.com/us/support/repair/support-warranty-claims.jsp
Jun 28, 2009 | LG 50PG6000 50 in. HD-Ready Plasma TV
Replacement KEF Coda III TWEETER Type SP1087
Go here and find a nice substitute. Many to choose from and it may be better to purchase a pair of them rather than have mis-matched ones. They should be inexpensive enough for you, as low as $2 up to $480. You just need the size of the mounting hole to find a replacement though.
http://www.parts-express.com/speakers.cfm
Nov 21, 2008 | KEF Audio Model Three Main / Stereo...
M-Audio BX5a Speaker Logo
244 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
