Question about Seiko 100m Diving Watch SKX033K2 Watch
How to adjust seiko SNZF21J1 watch bracelet - Seiko 100m Diving Watch SKX033K2 Watch
escapement
  • 2334 Answers
SOURCE: Adjust watch band for Seiko 7T94 Stanless Steel Band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 04, 2009
  • 8 Answers
SOURCE: seiko watch band
very tightly
Posted on Jan 02, 2008
VOTIT
  • 2071 Answers
SOURCE: watch
You better prepare a plain cloth to avoid scratch a piece of jewelry screw and ponson pinch ,if you cannot secure a ponson, find a big needle or sharp nail,take your watch put a piece of cloth to protect from scratch,hold your watch firmly that cannot slipt.In the side of links,there is a screw marks, or pinch marks lock,if you see screw marks you should use the screw ,if pinch mark ,use the needle or the nail to punch out the lock and detach it ..Again punch it in so it locks or screw it in.That s all you do patswan...
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Jul 25, 2008
escapement
  • 2334 Answers
SOURCE: how to adjust metal bracelet on casio A168 watch
Job done!
Posted on Apr 05, 2009
gemineye61
  • 831 Answers
SOURCE: I bought the self adjustable bracelet watch but do
Self-adjusting bands usually feature easy to remove links that simply snap out. They usually look just like the main clasp or blend in with the band. Simply locate these links and undo the closures to remove or add them.
Posted on Aug 20, 2010
I need help finding how old a womens Seiko watch it has two set of numbers can u help me
Farrah, Contact Seiko or try Google search your watch Seiko # and see what comes up then try the second #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Ladies Watches
Seiko Ladies Gold Dress Watch Maroon Dial Gold Mesh Bracelet Ca 1970s
Seiko ladies watch Gold with maroon face Google Search
Aug 08, 2016 | Seiko Watches
My Seiko railroad approved bracelet solar power watch stopped, how do I get it running
the advice is to buy a new one, no one is fitting the batteries to these, due to the high part cost.
even if it's in warranty, seiko just send a new watch out.
Apr 23, 2015 | Seiko Watches
Seiko sne039 only runs in direct light
It will be ticking in two second intervals, This is because it is very low on power. It should keep correct time and eventually settle down. It needs a long exposure to a nice bright sunny day and it will be fine once it has a good initial charge.
Jan 15, 2013 | Seiko Solar Quartz Link Bracelet Mens...
I need to get a spare bracelet link for a Seiko SMA075. Where is it available? Thank you.
You can get bracelet links for Seiko watches at Coserv, Seiko's main repair center located in New Jersey. The phone number to Coserv is 1-800-722-4452. If for some reason your links are discontinued occasionally a local watch repairman will have spare links! I hope this helps!
Sep 14, 2011 | Seiko SMA075 Wrist Watch
I have several older Seiko watches and I want to know what the case, caseback and bracelet are made of. How do I research these older watches?
I suggest that you go to the web site"seiko.com" and get the contact number and/or address.
Seiko may be able to dig something out of their archives you ask nicely.
good luck
Jan 20, 2010 | Watches
Seiko kinetic stainless steel bracelet has snapped pin (both snapped ends still visible and flush in last flared bracelet link between watch body and start of bracelet.) How do I remove snapped pin ends...
There are several easy to follow tutorials on u-tube. It's easier for you to look at these than for me to describe how it is done. Just search "adjusting steel watch straps"
Sep 23, 2017 | Omega Seamaster 2541.80 Wrist Watch
Job done!
Apr 04, 2009 | Seiko Watches
Adjust expandable watch bands- Timex watch
Most expandable watch bands aren't sizable. IF it is sizable you will be able to tell when you stretch the bracelet out. If it looks like you can unlatch the links when you stretch it out then you might be in luck, but like I said, most are not sizable.
Dec 29, 2008 | Seiko Diver's Watch
How to remove link from band
The segments of your bracelet are held together with friction pins which have to be removed first in order to adjust it. This is a relatively complicated task requiring experience and a special tool to remove and return the pins and bushings back correctly without compromising the bracelet strength.
I recommend taking your watch to an Omega authorised dealer for adjustment while you wait.
Nov 09, 2008 | Omega Seamaster 2541.80 Wrist Watch
Seiko 100m Diving Watch SKX033K2 Watch Logo
161 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
