Question about GE Spacemaker JVM1640SJ Microwave Oven
I THOUGHT I SET THE TIMER-YET I HAD SET THE
I THOUGHT I SET THE TIMER-YET I HAD SET THE OVEnFOR 35min. ABOUT 8 mins. I REALIZED THAT I HAD MADE A MISTAKE--THERE WAS NOTHING IN THE OVEN. NOW NOTHING WORKS. WE CHECKED THE CIRCIT BREAKER - YET THIS DID NOT WORK.
PLEASE GIVE INDICATION OF THE PROBLEM.
THANKS, CONNIE TAYLOR
    President:
  • 949 Answers
Without food for the microwaves to be absorbed by, the magnetron (heating device) would have most likely overheated. There is a thermal overload switch (safety device) that acts like a fuse and turns everything off if overheating occurs like that. You would need someone that could take the microwave down, disassemble and check to see if the 'fuse' is bad or the magnetron is bad, they can both be checked with an ohmmeter. If you need to hire someone to do this, it may cost you more than the cost of a new unit if the magnetron is the item that has failed.
Posted on May 05, 2010
On the r559y sharp microwave,how do i set the clockl
press,timer/clock ,colon will flash ,enter correct time{i.e. 12:34},press clock/timer again,,all set,if it doesnt work,return it to where you bought it,
Jan 01, 2015 | Sharp Microwave Ovens
Mmv4205ba
You probably fried the magnetron.Unless you have a really high dollar microwave,you're probably better off replacing it.
Aug 24, 2014 | Maytag Microwave Ovens
When I set the timer and close the door, the door latches fine. When I push the start button the timer starts to countdown but the microwave doesn't start. If I push the door release in about 1/8 " ,...
If your model number is in the Sharp R-1500 series, then that's a problem with the bottom door switch or its mount.
See these files:
http://207.234.249.73/mwd/safety.txt
http://207.234.249.73/mwd/disassembly.txt
http://207.234.249.73/mwd/doorsw.txt
Jan 14, 2011 | Sharp R-1511 Microwave Oven
Husband thought he set the timer but actually ran the over for 35 min. This was really hot and now looks dead. No displays, nothing.
Yes, you are probably right... he killed it... :-(
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 16, 2010 | Jenn-Air JMV8208AAS Microwave Oven
I need an instruction manual
press both Hour and Min buttons simultaneously for two seconds. You will hear a beep and the timer will reset. Don't press any other buttons for twenty seconds. The display will now change from the time to the clock. Press the hour botton. The hour digit will blink. Use the Min button to set the hour. Once you have the right hour, press the Hour button again, and the minute digits will blink. Press the Min button to set the minutes. Once you have the correct time, press the hour button one last time and your time is now set.
Sep 16, 2009 | Microwave Ovens
Kenmore 401.8008700 ran 10 minutes thought I'd set on timer
It could be the fuse. You will also need to check the condition and alignment of the door switches.
Eric
Jul 15, 2009 | Whirlpool GH6177XP Microwave Oven
Setting time on Panasonic NN-CD748B microwave
Panasonic's UK site is here and you can choose Support, then search for spares, servicers, downloads and contact info.
Jan 05, 2009 | Panasonic NN-S753 Microwave Oven
When using and setting the timer (i.e. 2:00 mins), microwave would stop after 25 seconds and no heat. Please help. Thanks!
I bet it's 22 seconds. The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 14, 2008 | Panasonic Microwave Ovens
Sharp mdl R-1870 convection microwave runs for 1 min
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo.
We have the service manual and have uploaded it to our site:
http://www.microwavedisplay.com/r1870_r1871_sm.pdf
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
Jun 07, 2008 | Panasonic NN-S254BF Microwave Oven
I think I broke my baby...
If it's dead, it's probably a blown fuse or maybe a blown thermalcouple fuse. a bad magnatron won't make the unit apear dead unless its blowing fuses.
Hope that helps..
Geno
Mar 24, 2008 | GE JES1142SF Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
122 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
