Question about Cub Cadet Street Sign- tractor lawn riding mower parts
My M48 tank dies on banks
My M48 tank runs and cuts fine, but when I take even the slightest bank, it completely dies. I can do banks fine with the blades disengaged, but when they're running, it just loses power, then dies. It will start right up again, but if I take another bank, same thing happens. Usually this happens when I've had the machine running for 20 minutes or so. I'm baffled.
    Problem Solver:
  • 11 Answers
Does it have a low oil pressure shut down? Are you low on oil?
Posted on May 05, 2010
05 Pathfinder...began having intermittent problem of engine bogging down - feeling similar to a bad miss.
0300 is misfires, 0463 is an issue with fuel levels in the tank, 0174 is bank 2 running too lean(too much air, not enough gas) so the combination points to a fuel issue going to bank 2(one side of the engine). Probably then it's a v6. I'd start with easy stuff. Go to a good gas station(I trust shell, but your area may vary with quality) and fill up, it could have been a bit of bad gas.
May want to check the fuel pump(odd since only one bank is running rough, but possible) check the fuel rail, regulator, and injectors on bank 2(bank 2 will be the three cylinders on the drivers side). You could also check the downstream O2 sensor wires for breaks and cuts, and maybe have the sensor checked, but with P0463 showing a fuel issue I'd lean towards something with the fuel pressure.
Jan 12, 2018 | Cars & Trucks
I have 99 bmw 323i.i ran it hot and got prob fixed and now the eml and a triangle with circle around it comes on dash and car has no power.feels like it has a rev limiter.wats wrong with my car
have throttle body checked also the MDK throttle motor,
make sure that the dealer has followed service bulletin 12 07 99 for procedure to replace the MDK throttle motor
also have them check for codes,here are some codes,
it could be an expensive job,have them check everything,it is most likely the throttle motor,,throttle body is 600 if they switch it,dont let them do it without checking throttle motor,
codes,
MS41, MS42 and MS43 engine DME bmw codes...
• 1 Ignition coil Cyl 2
• 2 Ignition coil Cyl 4
• 3 Ignition coil Cyl 6
• 5 Fuel injector Cyl 2
• 6 Fuel injector Cyl 1
• 8 Air Flow Meter (HFM)
• 10 Coolant Temperature Sensor
• 11 Tank Pressure Sensor (EVAP System) or Radiator Outlet Temp (MS43)
• 12 TPS or Plausibility - Maximum Coolant Temp (MS43)
• 13 Plausibility- Radiator Outlet Temp
• 14 Intake Air Temperature Sensor
• 15 Plausibility - Cut Out Time
• 16 AirCon Compressor - PWM Signal or Plausibility Intake Air Temp (MS43)
• 17 Plausibility - Engine Coolant Temp
• 18 EWS Signal or Camshaft Sensor (MS43)
• 19 Activation VANOS Inlet Valve or Exhaust Valve (MS43)
• 20 "CHECK ENGINE" Light Failure
• 21 VANOS -Electrical Fault or Activation VANOS Inlet Valve (MS43)
• 22 Fuel Injector Cyl 3
• 23 Fuel Injector Cyl 6
• 24 Fuel Injector Cyl 4
• 25 Lambda Sensor Heater -Bank 1
• 27 Idle Control Valve - Malfunction
• 29 Ignition Coil Cyl 1
• 30 Ignition Coil Cyl 3
• 31 Ignition Coil Cyl 5
• 33 Fuel Injector Cyl 5
• 35 Aux. Air Injection System Relay
• 36 DME Main Relay
• 37 DME Main Relay : Delay
• 38 Clutch Switch -Plausibility
• 39 Brake Light Switch or Brake Light Test Switch
• 40 Brake Light Switch or Pedal Value Signal
• 42 Multi Function Steering Wheel- Plausibility
• 43 Multi Function Steering Wheel: Button
• 45 Multi Function Steering Wheel: Port
• 47 Temp Sensor -Downstream of Pre-Cat or Torque Limitation Level 1 (MS43)
• 48 DME Control Unit -Self Test 1
• 49 DME Control Unit or Torque Monitoring Level 2 (MS43)
• 50 EVAP Control Valve or Response Monitoring Level 2 (MS43)
• 51 Shut-off Valve -Charcoal Filter or Request Control Unit Reset (MS43)
• 52 Solenoid Valve -Exhaust Flap
• 53 Idle Speed Actuator
• 55 Lambda Sensor Heater -Bank 2
• 56 Ignition Current Feedback Resistor - Open Circuit
• 57 Knock sensor -Bank 1
• 58 DME Control Unit -Self Test 2
• 59 Knock Sensor -Bank 2
• 61 Lambda Sensor Heater -Bank 2 Post Cat
• 62 Aux. Air Injection System -Switching Valve
• 63 DME Control Unit or Ambient Temp Signal via CAN (MS43)
• 64 Plausibility - Ambient Temperature
• 65 Camshaft Position Sensor (Inlet MS43)
• 66 DME Control Unit
• 67 DME Control Unit
• 68 Tank Venting Valve
• 69 Fuel Pump Relay
• 70 DME Control Unit
• 71 DME Control Unit
• 72 DME Control Unit
• 74 AirCon Compressor Relay
• 75 Lambda Sensor Voltage -Bank 1
• 76 Lambda Sensor Voltage -Bank 2
• 77 Lambda Sensor Voltage -Bank 1 Post Cat
• 78 Lambda Sensor Voltage -Bank 2 Post Cat
• 79 Lambda Sensor Heater -Bank 1 Post Cat
• 80 ABS/ASC interface
• 81 MSR Signal -Active too Long
• 82 ABS/ASC Interface -Advance Adjustment
• 83 Crankshaft Sensor
• 90 Exhaust Temperature Pre Cat Conv - Bank 1
• 91 Exhaust Temperature Pre Cat Conv - Bank 2
• 92 Exhaust Temperature Post Cat Conv -Bank 1
• 93 Exhaust Temperature Post Cat Conv -Bank 2
• 94 Auxiliary Air -Air Mass Flow Sensor
• 95 Auxiliary Air Valve or Auxiliary Air Hose Blocked
• 96 Auxiliary Air Pump - Function
• 97 Auxiliary Air -Flow Rate too Low
• 98 Auxiliary Air -Flow Rate too High
• 99 Auxiliary Air Valve Jammed Open
• 100 DME Control Unit -Self-Test Failed
• 103 VANOS Error -Inlet Camshaft
• 104 VANOS Error -Exhaust Camshaft
• 105 VANOS Error -Position Inlet Camshaft
• 106 VANOS Error -Position Exhaust Camshaft
• 109 Throttle Valve Plausibility
• 110 Pedal Sensor Value Potentiometer 1
• 111 Pedal Sensor Value Potentiometer 2
• 112 TPS Potentiometer 1
• 113 TPS Potentiometer 2
• 114 Throttle Valve Final Stage
• 115 Reference Voltage -Voltage Regulator 1 or Throttle Pedal Adaptation (MS43)
• 116 Reference Voltage -Voltage Regulator 2
• 117 Plausibility -Pedal Position Sensor 1/2
• 118 Plausibility -TPS 1/2 or TPS1/Airflow Plausibility (MS43)
• 119 Throttle Valve Sensor -Mechanical Error or TPS2/Airflow Plausibility (MS43)
• 120 Plausibility Pedal Sensor or TPS
• 122 Engine Oil Temperature
• 123 Map Cooling Thermostat Control
• 124 Activation DISA Solenoid
• 125 Activation Electric Fan
• 126 Activation Tank Leak Pump Solenoid
• 127 Activation Pump Solenoid
• 128 DME/EWS Communication
• 129 CAN Signal SMG 1
• 130 CAN Signal ASC -Timeout
• 131 CAN Signal Instrument Cluster -Timeout
• 132 CAN Signal Instrument Cluster -Timeout
• 133 CAN Signal ASC -Timeout
• 134 SMG Intervention -Plausibility
• 135 Throttle Valve Re-Adaptation Required
• 136 Throttle Valve -Spring Test and Limp-home Position Failed
• 137 CAN Signal -Steering Angle Sensor
• 139 CAN Signal -Tank Level Sensor
• 140 Tank Leak Pump Solenoid - Reed Switch Open or Output Stage (MS43)
• 141 Tank Leak Pump Solenoid - Reed Switch Stuck Closed or Tank Level Sensor (MS43)
• 142 Tank Leak Pump Solenoid - Reed Switch Stuck Open or DMTL Module (MS43)
• 143 Tank Ventilation or Tank Leakage (MS43)
• 144 Fuel System - Large Leak Recognised
• 145 Fuel System - Small Leak Recognised
• 146 EVAP System Leak Detected (Small Leak) or Pedal Sensor Supply Voltage Pot 1 (MS43)
• 147 Pedal Position Sensor Potentiometer Supply Channel 1 (Pot 2 MS43)
• 149 Air Flow Sensor or Pedal Value Sensor Mismatch
• 150 Lambda Post Cat Bank 1 Max Limit
• 151 Lambda Post Cat Bank 2 Max Limit
• 152 Lambda Post Cat Bank 1 Min Limit
• 153 Lambda Pre Cat Bank 2 Max Limit
• 154 Lambda Pre Cat Bank 2 Min Limit
• 155 Lambda Pre Cat Bank 2 No Signal
• 156 Lambda Pre Cat Bank 1 No Signal
• 157 Lambda Post Cat Bank 1 Min Limit
• 159 Lambda Post Cat Bank 2 Max Limit
• 160 Lambda Post Cat Bank 2 (MS41) or Throttle Valve Stuck
• 161 Throttle Valve - Stuck
• 162 Throttle Valve -Control Deviation
• 168 Pedal Position Sensor Pot Supply 1 or MAP Cooling Thermostat Jammed (MS43)
• 169 Throttle Valve Output Stage Cut off after Fault
• 170 DME Control Unit -Self Test Failed
• 171 Plausibility - Throttle Valve
• 172 Pedal Sensor Potentiometer 1/2 Short Circuit
• 173 TPS Potentiometer 1/2 Short Circuit
• 174 Throttle Valve Potentiometer 1/2 Adaptation
• 175 Pedal Sensor 1 Adaptation
• 176 Pedal Sensor 2 Adaptation
• 186 Voltage Post Cat Bank 1
• 187 Voltage Post Cat Bank 2
• 188 Voltage Pre Cat Bank 1
• 189 Voltage Pre Cat Bank 2
• 190 EVAP -Reed Switch Open or Voltage Post Cat Bank 1 (MS43)
• 191 EVAP -Reed Switch Closed or Voltage Post Cat Bank 2 (MS43)
• 192 EVAP -Reed Switch Open
• 193 EVAP -Check Hoses
• 194 EVAP -Large Leak Detected
• 195 EVAP -Small Leak Detected
• 196 EVAP -Electrical Valve from LDP Pump or Barometric Pressure Sensor (MS43)
• 197 EVAP -Barometric Pressure Sensor
• 198 Cat Efficiency during Start -Bank 1
• 199 Cat Efficiency during Start -Bank 2
• 200 Lambda Regulation Bank 1 Pre Cat
• 201 Lambda Regulation Bank 2 Pre Cat
• 202 Lambda Regulation Bank 1 Post Cat
• 203 Lambda Regulation Bank 2 Post cat
• 204 Idle Control System -Idle speed not plausible
• 208 EWS -RPM Signal Error
• 209 EWS -Message Error
• 210 Ignition Feedback Resistor (ZSR)
• 211 Idle Speed Actuator -Mechanical
• 212 VANOS Bank 1 -Mechanical
• 214 Vehicle Speed Signal (VSS)
• 215 Lambda Sensor Bank 1 or ASC/MSR/EML -Interface not plausible
• 216 Lambda Sensor Bank 2 or EGS Position Signal
• 217 CAN bus error -EGS Signal not present
• 218 CAN module -Warning
• 219 CAN module -CAN Offline
• 220 Lambda Voltage Range Bank 1 Sensor 1
• 221 Lambda Voltage Range Bank 2 Sensor 1
• 222 Low Coolant Temperature or Lambda Sensor Control (MS43)
• 223 Lambda Sensor Switching Bank 1 Sensor 2
• 224 Lambda Sensor Switching Bank 2 Sensor 2
• 225 Cat Efficiency Bank 1
• 226 Cat Efficiency Bank 2
• 227 Mixture Deviation Bank 1
• 228 Mixture Deviation Bank 2
• 229 Lambda Sensor Switching Bank 1
• 230 Lambda Sensor Switching Bank 2
• 231 Lambda Sensor Switching Bank 1 Pre Cat
• 232 Lambda Sensor Switching Bank 2 Pre Cat
• 233 Catalytic Converter Overall Efficiency Bank 1
• 234 Catalytic Converter Overall Efficiency Bank 2
• 235 Lambda Heater Bank 1 Post Cat or Pre Cat Signal (MS43)
• 236 Lambda Heater Bank 2 Post Cat or Pre Cat Signal (MS43)
• 238 Misfire Cyl 1
• 239 Misfire Cyl 2
• 240 Misfire Cyl 3
• 241 Misfire Cyl 4
• 242 Misfire Cyl 5
• 243 Misfire Cyl 6
• 244 Crankshaft Interval Timing
• 245 Aux Air Injection System Bank 1
• 246 Aux Air Injection System Bank 2
• 247 Aux Air Injection System -Incorrect Flow Detected
• 248 Pre Cat Converter Efficiency -Bank 1
• 249 Pre Cat Converter Efficiency -Bank 2
• 250 Tank Venting Valve -Function
• 251 Tank Ventilation Diagnosis Error
• 252 Tank Ventilation System Vacuum
• 253 Activated Charcoal Filter Shut-off Valve Stuck Shut
• 254 Tank Ventilation System -Large Air Leak
• 255 Tank Ventilation System -Valve Stuck Open
Apr 03, 2015 | 1999 BMW 323i
What do the following codes mean? PO171,PO174 and PO430. And what is best solution to eliminate them? Is it something I can handle or should I carry it to my local mechanics?
PO171 Fuel System Lean Bank 1
PO174 Fuel System Lean Bank 2
PO430 Catalyst System Low Bank 2
A new fuel filter would be a good start.
Feb 07, 2015 | Cars & Trucks
My 2005 mpv dies while I am driving when I let off the gas quickly. It reads that it is running lean o2 sensor bank one and two.
Running lean means the ur car is not getting enough fuel for complete combustion. Your O2 sensors have picked this up from the readings. Be sure to check what could be causing this problem soon b4 ur catalytic converter is affected. Check ur fuel line, service ur injectors, change fuel filter(it could be clogged) n check, fuel pump pressure n if d tank is really dirty while u re at it **** out d fuel n clean the tank t
Sep 07, 2011 | Mazda MPV Cars & Trucks
My 2006 Chevy Silverado 1500 5.3 L engine surges +/- 200 rpm between 30-59 mph in final drive gear...in lower gears runs fine. No check engine light or computer code generated until recently which showed...
a bank 1 or a bank 2 generally means an 02 sensors bad. or you may simply have a faulty gas cap. i would try the gas cap 1st,make sure it's tight, the engine running for a few minutes,then cut engine off. then open gas cap,do you hear pressure [air] releasing from the fuel tank? ok if not that,then if bank 2 is really bad,your check engine light would be on. but if the idle control sensor is bad,no light would be on at all. and it[engine] would idle up and down.or would'nt idle at all,or would idle up and down,just like what you've described. good luck and thank you for choosing fixya.com and please let me know if i'ved assisted you!
Feb 20, 2011 | 2006 Chevrolet Silverado 1500 2WD
What does the code p1166 mean for a hyundai elantra 2003
P1166 O2 Sensor - controller adaption diagnosis malfunction (bank 1).
Trouble area:
* P1166 is case for HO2S (Bank 1, Sensor 1) Signal line open
* Fuel system (Fuel tank/Pressure regulator/Fuel pump/PSV) failure
* Poor connection to fuel line hose/sealing/cut
* Sealing between purge valve and fuel tank
* Air leakage in exhaust system
* Ignition system (ignition coil, spark plug, cable) failure
* Surge tank and intake port failure
Oct 16, 2009 | Hyundai Motor 2003 Elantra
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
217 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
