Question about Dell Tablets & eReaders
Error:too many arguments in function call: STRCAT in autolisp file
How do I install the app?
If it is in the Play store, just use the install function. If you are downloading an APK file, then you must go to the download folder and install from there by clicking on the APK file.
Apr 23, 2015 | Tablets & eReaders
How do I transfer apps and files to ext SD card on my binatone 7inch tab 744?
To transfer apps to SD card, you will use Settings-Apps, open the selected app, then choose Move to SD Card.
If you meant copying files, then use Explorer or other software with similar functions to copy the desired files. I think you actually meant the above.
Jan 12, 2015 | Tablets & eReaders
How do I fix my Toshiba tablet that won't show me that it is charging?
Have you checked the following:
  1. Power cord for breaks
  2. The power outlet you are connecting into (try at least 2 other outlets before settling, but use different outlets for the sake of argument.
  3. When was the last time you charged and it actually did?
  4. Do you have the correct cord?
  5. Have you tried to replace the cord?
Nov 22, 2014 | Toshiba Tablets & eReaders
How to get my tablet gt-p5113 to resync to other pcs
Even though it reads no driver found, try moving files anyway. Sometimes this happens and it still functions properly.
Oct 26, 2014 | Tablets & eReaders
What can't I download anything on my iPad
iPads do not function the same way you may be used to on your computer. You cannot download files to an iPad. You need to either view the file using an app or the web browser.
Hope that helps!
Oct 20, 2013 | Apple iPad Tablets & eReaders
Hi when i trying to load os it gives crc error sometimes at 4% sometimes at 18 % please help
Issue:
Cyclic Redundancy Check or CRC error.
Cause:
This error message could be generated by any of the below reasons.
1. During the transmission of the file it became corrupt or bad
2. The file was sent inappropriately
3. The device being opened from is bad or contains errors
4. The file itself is bad or the program attempting to open the file is bad.
Jan 05, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might...
If you are able to hear sound while starting PC issue is not with sound card. that is installed and working properly. If you are clicking on any file that is not playing then window media player is not supporting that file. If you are directly opening window media player from start>>Program>>access>>>>window player and it is giving error. It mean that your player is corrupted. You can upgrade that with higher version of player by going this link. www.microsoft.com/windows/windowsmedia/9series/player.aspx
Aug 20, 2007 | Toshiba Satellite R10-S802TD Tablet PC
Tablets & eReaders Logo
154 people viewed this question
Top Dell Tablets & eReaders Experts
Michael Vincent Cruz
brian soufane
Tiffany Tosh
Level 1 Expert
Are you a Dell Tablet and eReader Expert? Answer questions, earn points and help others
